Timing belt kit from Amazon
Is this the kit to use?
The honda dealer is going to charge me 550 to do the timing belt and water pump. But if I buy the kit and take it to my local mechanic It would probably be a little cheaper.
With all due respect to the OP, there are several options other than the link posted which will be lower cost.
Gates kit which several users have installed:
http://www.amazon.com/Gates-TCKWP329-Engine-Timing-Water/dp/B001NYE26U/ref=sr_1_2?s=automotive&ie=UTF8&qid=1369059868&sr=1-2&keywords=timing+belt+kit
Or this kit by AISIN, which is has parts that are all made by the same manufacturers as OEM. It's out of stock from Amazon at the moment, but I bought this for $160.
I was just pricing the same thing. Ill be really thinking about buying one of these 200-2500 kits. As long as the bearings are Koyo they are the same as OEM! Its the water pump and tensioner I question.
Tons of threads on this. The Gates kit is all OEM except for the water pump. I have 30K miles on the Gates kit with no issues.
OP, $550 is not a bad price at all for parts + labor, including water pump and tensioner...
550 was parts only, no labor. +1 on gates. Ill get the belt and pulley kit and just buy an OEM water pump.
Well I went to the honda dealer for my "$550" timing belt and water pump job with my coupon. Let me clarify. I had a coupon for $499 water pump and timing belt. But on the phone the guy said the water pump was a little extra. It ended up being $99 extra. So it just jumped up to $599. I dropped off the car anyway but added on a transmission fluid change also. Two hours later I get a phone call saying my tensioner was on its last leg and if it breaks blah blah blah.. Okay fix it, thanks. The guy replies well while we are here might as well replace your ac belts it only $8. Okay do that too. An hour later they call me again.. your engine mounts are all broken.. you want us to replace them? I say how much, they want $1300...lol no thats okay.." oh well you car is done other wise. I go pick it up and boom, the bill was $919!!! I like " Ummm excuse me how the hell did a tensioner and $8 ac belts take it to $919.. well the belts is $8, but the labor is $40..The tensioner was $127 but the labor was $80.. WHAT!! they bent me over big time.. but on the good side Im good on the timing belt, tensioner, ac belt, water pump, tranny fluid is red with no metals or grit, and a free car wash lol
I'd still go for the AISIN kit from rockauto. All OEM parts without the Honda name on them:
https://www.rockauto.com/catalog/mor...456&cc=1429130
$193.79 + shipping.
$193.79 + shipping.
I'm sure this will come as no surprise, but the replacing the tensioner is literally 2 or 3 bolts once you're in there. The AC belt has to come off and be put back on whether it gets replaced or not, so the $120 in labor is essentially pure profit.
The practice of quoting a repair cost without giving labor charges really pisses me off. Obviously they don't quote them because they are ripping people off.
$193.79 + shipping.
$193.79 + shipping.
So if I plan on keeping my car for probably 5 years, can someone tell me all the parts one should plan on replacing? I heard whats in the kits plus crank and cam shaft seals? Anything else?
Much appreciated
Much appreciated
Here's what I replaced last weekend:
AISIN timing belt kit (TB, water pump, tensioner, idler)
OEM spark plugs
Thermostat
OEM or Goodyear Gator AC drive belt
Gates AC belt tensioner and pulley (i had some noise from the old tensioner and it's easy to replace once you have the car apart for the TB job.)
Also if you haven't done it recently I'd suggest replacing/inspecting:
Power steering fluid
Transmission fluid
Engine oil and filter
Brake fluid
Air filter
Cabin filter
Rotate tires
I also replaced the seals in my power steering pump and changed the transmission filter (only possible on '04 - '06)
I figure I'm good for a while now...maybe I'll try doing a valve adjustment next year if I feel ambitious.
Man I was lucky I grabbed the last Aisin Kit from amazon Today. $155.64 Man I love Amazon.
For some reason this kit is really cheap now.
Amazon says it went down 43% in price since I added it to my Wish List (when this thread was created).
http://www.acuraoemparts.com/delray/jsp/catdisplay.jsp
You can get any OEM part number your heart desires!
$193.79 + shipping.
$193.79 + shipping.
http://www.oemacuraparts.com/oem-par.../19200-rdv-j01
OEM ACURA WATER PUMP (YAMADA) for 2005 ACURA TL | Part number 19200-RDV-J01
Also, almost all Honda timing belts are made by Unitta. Espeically the high performance ones. Unitta is just the name Gates uses for it's Asian market.
On Aisin kits, tb brand is mitsubishi... Is this oem? I read that Gates/Unitta is oem ... Why people keep buying Aisin kits instead of Gates kits? Gates kits oem on everything except Water Pump.
Is this a good option
Buying Aisin kit plus only gates timing belt on Rockauto... So, you'll have oem tb, tensionner, etc. And I read here that Aisin water pump was oem on the earlier built TL so it will make all oem?
My dilemma is wich one is better?
When I took the parts off my 2004 TL, the brand and stamping of every part in the Aisin kit except the TB itself were identical to the OEM. The TB was high quality and I have no doubt it's every bit as good as the OEM belt.
Try not to over-think the parts list...just think about how much money you're saving instead!
Not positive...All parts looked OEM to me. I installed myself with bisimoto stage two cams and beat the shit out of my car and so far have had no issues...that doesn't mean much though lol
Yes, both the Aisin kit and the Gates kit have identical parts. The only difference between the two are the timing belts and water pumps.
