Timing belt hydraulic tensioner
Hello
I have a 2006 acura tl and i'm setting things up to change my timing belt, water pump and tensioner, I have a extra brand new hydraulic tensioner from my 1999 Acura tl and wanted to know if i can use that style of tensioner instead of the grenade style tensioner, Thanks.
Now there's an interesting question. I've changed from OEM tensioners on motorcycles (from hydraulic to manual) with good results. And my first thought is that it should work as long as everything lines up and proper tension is set...
But my next thought is why risk it? The OEM part is relatively inexpensive and you will have peace of mind knowing it's right...
But I'm just a garage mechanic do it yourselfer. Maybe a more experience technician can explain better...
The 2nd generation TLs and 6th generation Accords vary from the "good" tensioner and the grenade style.
Everyone I've ever talked to has told me that the grenade style tensioners are junk because the seals wear out and the fluid leaks out.
roman1998
11-07-2015 11:32 PM
99CL23
10-27-2015 04:35 AM
