Turn Signal Mirrors
Old 05-23-2010, 11:56 AM
5th Gear
J72989's Avatar
Turn Signal Mirrors
Hello I was wondering if anyone attempted to place the side mirrors from an 07-08 TL on a 2005 TL, if it's an easy swap, and maybe what it entails as far as modifications. Also, is it a direct plug in? Thanks.
Old 05-23-2010, 11:59 AM
Received 16,260 Likes on 11,971 Posts
It fits, you just have to wire it up.
Old 05-23-2010, 12:52 PM
shellready's Avatar
there's a DIY somewhere here for that, you just have to search for it
Old 05-23-2010, 01:41 PM
SlimTL's Avatar
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/e-115-07-mirrors-06-fyi-637014/
Old 05-23-2010, 02:08 PM
Fear and Loathing in my
Timb227's Avatar
I believe the driver side is plug and play, but you need to run one wire for the passenger side.
Old 05-23-2010, 03:26 PM
donaldso718's Avatar
I read that only 2006 had the driver side plug and play because it was wired differently than the 04-05. I could be wrong though.
Old 05-23-2010, 10:38 PM
SlimTL's Avatar
Correct.
Old 05-24-2010, 08:54 AM
gatoferoz25's Avatar
you need to run a wire for the blinkers just one in each side to have power for them...
Old 05-24-2010, 06:44 PM
Where Did My Garage Go?!!
lucnex's Avatar
Its really easy, I did it on my 05. Be careful when you put the new mirrors on though, you have to really tighten down the bolts so the mirrors sit flush. Just run the wire and tap it to the turn signals. I ran mine above my wheel well and to the mirror.
pplcrew
01-30-2021 08:59 AM
Ty-Sama
09-21-2015 05:45 AM
09-17-2015 09:01 PM
Greengecko
09-16-2015 08:19 PM
JnC
09-11-2015 06:06 AM
Quick Reply: Turn Signal Mirrors
