E-115: '07 mirrors on '06 FYI
Old Apr 8, 2008 | 01:08 AM
SlimTL's Avatar
So, I installed the 07' TL mirrors on my '06 today. It was a simple direct plug in (for the most part....see following story...). To my surprise the flashers worked.....on the drivers side!
I was looking for a good way to run the power wire to the front signal when I decided to test if the mirrors worked. It appears as if my car was pre-wired for the mirror blinkers!? Unfortunately, the passenger side does not light up at all.
In the harness by the mirrors, there is a red wire on driver's side (which was not previously connected to the '06 mirrors) and a white wire on the passenger side (which also was not previously connected to the '06 mirrors) The red wire now powers my driver's side blinkers, but the corresponding white wire doesn't power the passenger side.
I was in the process of doing a DIY writeup for this install when I stumbled upon this minor bump. I guess I will have to tap into the mirror signal and run a wire to the turn signal for the passenger side. This will be difficult because there is a harness in the door by the boot for the door jam...so it won't be easy because my passage for the wire is blocked.
I will keep you guys posted.
Old Apr 8, 2008 | 09:04 AM
SlimTL's Avatar
Bump
Old Apr 9, 2008 | 12:17 PM
Acura3GTL's Avatar
so...any updates? pictures?
Old Apr 9, 2008 | 01:15 PM
rksokol's Avatar
My TL can do this, too!
I have an '06 as well. How much did you pay for your '07 mirrors?
Old Apr 9, 2008 | 08:20 PM
SlimTL's Avatar
$373.90 shipped brand new from Ebay Acura dealer.
Old Apr 10, 2008 | 12:50 AM
SlimTL's Avatar
Cool Install Complete
Pics are posted, but please don't consider this a DIY writeup. Just use it as a guide for your install. Hopefully I made it easier for those wishing to do this mod. Complete install takes about 1.5 hours per mirror (give or take the half hour).
Good luck!
1. Tools used: Philips and flathead screwdriver, 10mm socket from tool case and microfiber towel.
2. Remove plastic cover behind interior door handle
3. Remove screws
4.Remove bumper stop with screw
5. Remove door handle screw
.6 Remove door panel (place an object...in my case, the shipping package.....under door panel so as not stress the cables)
7. Unplug mirror connector from harness
8. Remove the clips for the plastic cover (there should be 4 total)
9. Unscrew the mirror from bolts using 10mm socket.
10. Slowly pull out old mirror
11. Clean area with microfiber towel before putting on new mirrors
12. Install mirrors and plug in connection into harness. Also, test mirror controls at this time.
13. This pink wire w/ black stripe is the LED signal power wire. The light is already grounded within the mirror housing, so just run a tap on this wire to the car's front signal wire(in my case, the rear .... because I found that way easier) to get power when the blinkers are switched on. I do not trust tapping into fuses.
Unfortunately, I was not able to get any pictures of this part of the install due to tight spaces.
14. Reinstall door panels
15. ENJOY!
Old Apr 10, 2008 | 12:59 AM
SlimTL's Avatar
For Comparison
BEFORE
AFTER
Old Apr 10, 2008 | 01:27 AM
ballinfizzle89's Avatar
FizzyStatus!
Damn...sweet DIY with pics..Looks great man!
Old Apr 10, 2008 | 01:32 AM
carlos9827's Avatar
2011 BMW 335i
Very nice!!
Old Apr 10, 2008 | 08:58 PM
ABP_04TL's Avatar
6-SPEED LOVER
very nice...
Old Apr 10, 2008 | 10:04 PM
Acura3GTL's Avatar
does it maintain previous function? e.g. auto reverse tilt
Old Apr 10, 2008 | 10:22 PM
SlimTL's Avatar
Yes, all the functions remain the same. Mirrors are still heated and auto tilt still works.
Old Apr 11, 2008 | 10:09 AM
RedAggie03's Avatar
I used to own a
Hey Slim...So just to be clear...I have an '06 as well, so I only have to custom wire the passanger side?? The driver side blinks and everything like it should? THAT'S CRAZY.
I also see you are in Sugar Land...I'm downtown. I think Bent09 and I are trying to get together one weekend to do a headlight clearing party / mod day...I would like to consider doing this mod as well.
Good job. Thank you for the pictures.
Old Apr 11, 2008 | 04:15 PM
SlimTL's Avatar
Thanks for the comments.
Actually, I'm not sure why the blinkers on the driver's side powered without any modification. I guess I just got lucky. I'm not sure if all '06 TL's came with this wire in the blank spot of the harness, but they were on mine. Maybe if you do this mod, you may or may not notice the same thing.
Just to be clear, I was fully prepared to tap into the turn signals for both mirrors. The driver's side just caught me by surprise.
As far as the headlight mod goes, I'm not too fond of the amber corners, but I would rather order the Type-S headlights and do a complete swap. Just my
Good luck with your plans. Modded TL's are hard to find in the Houston area compared to the others cities on this forum.
Old Apr 11, 2008 | 10:50 PM
mb190's Avatar
Good luck!
3. Remove screws
15. ENJOY!
Hey SlimTL,
Great job!!
Not meaning to side track this thread, but a question for you.
On your pic #4, "remove bumper stop with screw". Do you remember/know how that metal threaded standoff (behind the door panel) is attached to the door frame? Mine is "free wheeling", as I turn the bumper stop screw, that metal threaded standoff turns as well. Just wondering if it's fixable, like by tightening a nut or something, thanks.
Old Apr 11, 2008 | 11:01 PM
SlimTL's Avatar
MB190, mine did the same thing on the passenger side.
I used a needle nose pliers and held the washer behind the door panel as I screwed the bumper stop back in. Once you hold that washer the screw will tighten enough to hold everything in place as before.
Also, use a cloth or some soft fabric against the metal portion because you will scratch the paint as you pull out your pliers. I scratched mine slightly, but no biggie.
Old Apr 11, 2008 | 11:07 PM
mb190's Avatar
HaHa, That's exactly how I tighten it back. But I was wondering how that standoff is attached to the door frame?
Old Apr 11, 2008 | 11:38 PM
SlimTL's Avatar
Talking More pics...cleaner car!
Old Apr 11, 2008 | 11:44 PM
SlimTL's Avatar
Old Apr 12, 2008 | 12:21 AM
fluxcapacitor3000's Avatar
how much were the mirrors? is it possible they can come painted AM?
Old Feb 16, 2009 | 06:29 PM
melvin2816's Avatar
05 TL NBP 6spd S front
great write up
Old Mar 4, 2009 | 02:13 AM
SlimTL's Avatar
Originally Posted by melvin2816
great write up
Old Mar 4, 2009 | 03:19 AM
firstacuratl's Avatar
邵樂百
I think AM ended in '06?
Nice mod Slim ... you're NBP is looking CLEAN!
Old Mar 4, 2009 | 11:19 AM
PeterUbers's Avatar
anyone know if satin silver metalic was still produced in '07-08
Old Mar 4, 2009 | 01:18 PM
Carlito Benito's Avatar
I fixed the glitch
That seems easy enough. I haven't planned on doing any mods but that seems like a nice little upgrade.
Old Mar 4, 2009 | 01:58 PM
myron's Avatar
no it wasn't
Old Mar 9, 2009 | 06:12 PM
EVOLICARUS's Avatar
bumpy on old thread
what wire do you hook up the pink/black wire to? whats easier? the rear or front? and what color wire on the front or rear do you tap the pink/black wire into?
i ask, because i'm going to install these tomorrow
Old Mar 11, 2009 | 09:45 PM
DeltaCTU24's Avatar
would this work on a 2004?
Old Mar 21, 2009 | 03:59 AM
SlimTL's Avatar
Thanks. Here's a link to my updated pic thread.
https://acurazine.com/forums/showthr...=633032&page=2
Originally Posted by EVOLICARUS
bumpy on old thread
Sorry dude, I've been out of town on business and just saw your post. If you haven't already connected your mirrors, the pink/black wire is the mirror l.e.d. light power wire. Tap this connection with a seperate wire that you are running to the vehicles actual turn signal. Both front and rear are a pain in the ass. I preferred the rear because it has its own independent signal wire. The front shares it's signal with the parking lights. Plus the front is more difficult to reach and time consuming. PM with any further questions and good luck.
Yes
Old Mar 21, 2009 | 09:15 AM
EVOLICARUS's Avatar
^^it was a PITA, i ran it to the front signals. took me almost 4 hrs to complete the install.
Old Mar 22, 2009 | 12:29 PM
SlimTL's Avatar
Glad everything worked out for you. Yeah it's a PITA, but well worth the effort IMHO. It's one of those mods that make me appreciate this car so much more. BTW, pearl white is my second favorite color for the TL.
Old Apr 10, 2009 | 06:33 PM
r3n3gad3II's Avatar
hey just wondering on # 13 but how do you tap the front or rear turn signal. i wanted to try this but not familiar with tapping wire. or is this a sign i shouldnt do it lol.
Old Apr 11, 2009 | 08:36 PM
SlimTL's Avatar
It's been a while since I did the mod, so I don't remember the color of the positive wire to tap into. All you have to do is run one wire from the harness in the door to the turn signal wire. You only need the positive wire connection because the mirror is already grounded as is. Just get some wire taps to tap the signal after you run the wire to the signal, and your good to go.
Old Apr 13, 2009 | 02:24 PM
jmkiang's Avatar
zaino'd
Question:
If I tap into the front signal wires, will the LED mirrors stay ON when my parking lights/low beams are on and flash ON/OFF when I'm signalling or have my hazard light on?
Old Apr 13, 2009 | 03:07 PM
jmkiang's Avatar
zaino'd
^ Nevermind... tapping into the rear signal wires would do the same thing...
<-- dumbass
Old Apr 13, 2009 | 06:56 PM
Yungwallstreet08's Avatar
Proud Acura Owner
thanks
Thanks alot, I just completed this mod, it looks great. I had to have mirrors painted for AM though, but they look great.
Old Apr 13, 2009 | 09:14 PM
NYC04TL's Avatar
OREO
how did u get the pass. side to work.......??
Old Apr 14, 2009 | 11:15 AM
SlimTL's Avatar
Definitely one of the nicest "update" mods out there. Plus, it's functional for safety
Old Apr 14, 2009 | 11:40 AM
SlimTL's Avatar
It's the same as the drivers's side. I had to run a single positive wire to the rear taillights on the passenger side and the driver's side of the car for each mirror. Just tap into the signal wire from the mirror and it will work.
Originally Posted by jmkiang
Question:
Depends on which wire you connect to. I don't know if it will stay constant on with the parking lights if you connect it the parking wire. I suppose it will. But, these mirrors were designed to flash. I preferred the rear because there is no parking signal wire to worry about.
Old Apr 14, 2009 | 11:52 AM
jmkiang's Avatar
zaino'd
^ Where did you opt to route the wire? Thinking thru possibilities now so I can attempt this tonight.
