Windows XP help.....
Old Aug 18, 2005 | 10:13 AM
S A CHO's Avatar
That was uncalled for...
So I reforatted my laptop and the reformat went good but now when it boots up there are 2 Windows XP's to choose from, Im thinking the other one is my previous version but am unsure and am not willing to go into it as it was seriously fawked up...so how do I go about getting rid of that other "Windows XP" at start up?
Old Aug 18, 2005 | 10:18 AM
Whiskers's Avatar
Go Giants
Look for the file boot.ini and edit it.
Old Aug 18, 2005 | 10:20 AM
Vector02's Avatar
start->run->msconfig
click the boot.ini tab->check all paths->follow directions
Old Aug 18, 2005 | 10:24 AM
S A CHO's Avatar
Ok, I see 2 in the list, how do I get rid of the one I dont want?
Old Aug 18, 2005 | 10:26 AM
Whiskers's Avatar
Go Giants
You may need to remove the read only property first.
Old Aug 18, 2005 | 10:33 AM
Vector02's Avatar
Click "check all paths" and you should be prompted for an automatic cleanup.
If not, you "probably" should delete the last line...
Old Aug 18, 2005 | 10:35 AM
YOTH's Avatar
Thriller
Instead of taking a chance of deleting something you can just try to change your default boot-up.
Right-Click on My Computer then Properties>Advanced (TAB)
In Startup and Recovery click on Settings
In the new window choose the default OS that you want. This will make the appropriate changes in the Boot.ini for you.
Its been a while since I've worked hands on problem solving pc's. So if you f*** it up don't blame me! I think that should help up though.
Old Aug 18, 2005 | 10:40 AM
S A CHO's Avatar
Ah excellent, Thanks alot, works great now
Old Aug 18, 2005 | 10:41 AM
Vector02's Avatar
And also, let me preface... You delete too much and your machine won't boot. So be carefull.
le^2
Mar 17, 2026 05:06 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
AcuraKidd
Sep 25, 2015 11:18 PM
