Windows Question
Old Oct 7, 2004 | 05:01 PM
joeshmoe's Avatar
My Home Planet
Windows Question
Does anyone know how to display the time in military time using windows xp? Would I have to just install some separate program? I'd like to get the windows clock in the bottom right corner to display in military time. Thanks in advance.
Old Oct 7, 2004 | 05:22 PM
DDT-TypeS's Avatar
6SPDCLS
easy:
Syntax
time [/t] [/time] [hours:[minutes[:seconds[.hundredths]]][{A|P}]]
Parameters
/t : Displays the current system time, without prompting you to enter a new time.
/time : Same as /t.
hours : Specifies the hour. Valid values are in the range 0 through 23.
minutes : Specifies minutes. Valid values are in the range 0 through 59.
seconds : Specifies seconds. Valid values are in the range 0 through 59.
hundredths : Specifies hundredths of a second. Valid values are in the range 0 through 99.
{A|P} : Specifies A.M or P.M. for the 12-hour time format. If you type a valid 12-hour time but do not type A or P, time uses A for A.M.
/? : Displays help at the command prompt.
When using time without parameters, press ENTER to keep the same time.
Using the /t parameter
The /t command-line option is only available if command extensions are enabled (that is, the default). For more information about enabling and disabling command extensions, see cmd in Related Topics.
Specifying an invalid time format
If you specify the time in an invalid format the following message is displayed and the system then waits for you to enter the time in the correct format:
Invalid time
Enter new time:
Changing the time format
You can change the time format by changing the setting in Date and Time in Control Panel. For just the MS-DOS subsystem, change the country setting in your Config.nt file. Depending on the Country/Region selected, time is displayed in the 12-hour format or the 24-hour format. If you are setting the time in the 12-hour format, specify P for hours after noon.
Examples:
To set your computer clock to 1:36 P.M., type either of the following commands:
time 13:36
time 1:36P
Old Oct 7, 2004 | 05:23 PM
DDT-TypeS's Avatar
6SPDCLS
go here:
http://support.microsoft.com/default...307938&sd=tech
Old Oct 7, 2004 | 06:10 PM
joeshmoe's Avatar
My Home Planet
Originally Posted by DDT-TypeS
BoricuaTL
Apr 8, 2016 01:08 PM
06TLMatt
Oct 2, 2015 08:14 PM
truonghthe
Oct 1, 2015 03:13 AM
datadr
Sep 12, 2015 09:12 PM
ahsm
Sep 9, 2015 08:35 AM
