Windows 8 tip...Fast boot
Old Nov 8, 2014 | 06:51 PM
fuzzy02CLS's Avatar
DISABLE IT! Google how to do it.
Window 8 has something called fast boot. Basically uses RAM to actually never shut down all the way. This is great when windows 8 starts, it starts fast...problem is if you ever need to access the HD using a Linux or other boot utility without booting into windows, the HD is locked & unable to mount.
Found this out this week when I tried to reset a password for a company laptop that wasn't setup right with the Admin account not enabled. Couldn't do a damn thing because the fast boot locked the file system & couldn't mount the drive to get access to the windows partition.
Old Nov 9, 2014 | 06:45 PM
stogie1020's Avatar
Needs more Lemon Pledge
Fuzzy,
What boot disk were you trying?
While not convenient, I wonder what would have happened if you have pulled the drive from the laptop and tried to attach it as a second drive on a different machine?...
Also, is Fast boot enabled by default or is that something someone turned on for that machine?
Old Nov 9, 2014 | 08:42 PM
fuzzy02CLS's Avatar
Everything I had...I even tried the overwrite of the utilman.exe with command prompt...couldn't do it because the drive was locked. PITA.
It's default....
Didn't try to remove the HD...it's under warranty so I couldn't void that.
Old Nov 10, 2014 | 09:56 AM
stogie1020's Avatar
Thanks for the info Fuzzy!
Will have to do some testing....
Old Nov 10, 2014 | 12:50 PM
TLin401's Avatar
'13 Hyundai Sonata
Interesting ....
Very, very interesting. Thanks for the info!
Jul 16, 2017 07:33 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
jmaxima03
Sep 27, 2015 10:22 AM
