Windows 7 and Sleep
Old Nov 7, 2014 | 05:44 PM
stogie1020's Avatar
Needs more Lemon Pledge
Windows 7 and Sleep
I have a machine on my network that sometimes I want to be able to go to sleep, and sometimes I want it to not go to sleep (anticipating a remote login, FTP server running, etc).
Rather than accessing the power menu each time, I wrote two batch files to enable one of two custom power configurations. One config allows sleep after 5 minutes and the other prevents sleep entirely.
Problem is, the computer does not seem to care and does what it wants, sometime sleeping and other times never going to sleep regardless of the power profile I have activated. I confirm that the correct profile is the active one, however in the sleep=ON profile, the machine often never sleeps and inthe sleep=OFF profile, the machine often goes to sleep.
Does anyone know of a good, surefire program/method to toggle sleep on and off? I have tried a few and they are unreliable at best, and disabled WOL/MagicPacket at worst.
Old Nov 7, 2014 | 06:22 PM
jupitersolo's Avatar
nnInn
Old Nov 7, 2014 | 06:52 PM
Will Y.'s Avatar
Registered but harmless
Rather than accessing the power menu each time, I wrote two batch files...
The sleep function is at most three mouse clicks into the start bar menu, and it works 99% of the time on my computers.
Are you talking about a program that you can remotely access?
Old Nov 7, 2014 | 07:32 PM
Ken1997TL's Avatar
Make sure your BIOS settings are configured properly. A flash/update may be in order.
Old Nov 8, 2014 | 04:53 PM
Anachostic's Avatar
Always use the sleep profile and run a sleep blocker like NoSleep when you want to prevent sleeping.
Download
Old Nov 8, 2014 | 05:17 PM
RenoTL's Avatar
If 3 clicks are too many you can create a shortcut on your desktop ("C:\Windows Shutdown Dialog.js"). If this file doesn't exist in your Windows folder (I can't remember if it was there in Win 7 or I had to make it) the "Shutdown Dialog.js" file can be created in NOTEPAD with the single line of, "(new ActiveXObject("Shell.Application")).ShutdownWindow s();" - without the quotes - and save the NOTEPAD file to your Windows directory with this file name.
Old Nov 8, 2014 | 06:40 PM
fuzzy02CLS's Avatar
Is this on a domain? Group Policy in place?
Do you have another PC you can access? You can access that PC & run a powershell command to disable the power save on the other PC when you need it. If they are on the same subnet & you have admin rights.
le^2
Mar 17, 2026 05:06 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
AcuraKidd
Sep 25, 2015 11:18 PM
