What does contrast ratio?? LCD problem
Old Aug 22, 2003 | 08:38 PM
Type S's Avatar
Powered By HONDA
What is contrast ratio?? LCD problem
LCD monitor has the contrast ratio
what does that mean?
the bigger the better?
what is the function of contrast ratio?
most 15" lcd monitors have 300:1 contrast ratio
Old Aug 22, 2003 | 09:31 PM
AztecRol's Avatar
The Screeching Toyo's
Contrast ratio: The ratio between between the brightest and darkest areas of an image. With a larger contrast ratio, a projector has a greater ability to show subtle color details and tolerate extraneous room light.
AND,
Contrast ratio describes the ratio between black and white on the screen. The larger the contrast ratio, the better subtle color differences will be displayed on the screen. Contrast ratios start at 200:1 and 250:1, while the best models are as high as 400:1 or 500:1.
That should answer your questions.
Get the HIGHEST contrast ratio that you can get.
Old Aug 22, 2003 | 09:41 PM
Type S's Avatar
Powered By HONDA
ok..thanks dude.
now i have some idea..
i know which lcd i am going to get.
thanks lol
Doc.Booty's Avatar
Also, if you're doing gaming, make sure you get one with a low response time - as in 20ms and lower.
Old Aug 22, 2003 | 10:48 PM
KavexTrax's Avatar
if u can get your hands on a Dell 1702FP, its a SLEEPER!
Even though its advertised with a 500:1 contrast, it has been tested to have a ratio of 892:1!!!
http://www.pcworld.com/news/article/0,aid,110483,00.asp
Right now, Samsung makes some of the most impressive LCDs in my opinion.
Mike Pilipenko
Mar 26, 2024 09:21 PM
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
