Urgent: MS Excel question
Old Jul 3, 2008 | 10:30 AM
AcuraKidd's Avatar
The Talk of New York
Exclamation Urgent: MS Excel question
I have an excel document with about 16,000 lines of data. The problem is that the data is on every other line. Is there a fast way to get rid of all the blank lines?
Old Jul 3, 2008 | 10:34 AM
GIBSON6594's Avatar
My Garage
sort it?
Old Jul 3, 2008 | 10:38 AM
Beelzebub's Avatar
Originally Posted by GIBSON6594
sort it?
Might work
but other than that
I know of no quick way in excel to do that.
I would convert it to csv file and then use grep -v to get rid of the blank lines.
Old Jul 3, 2008 | 10:41 AM
AcuraKidd's Avatar
Originally Posted by Beelzebub
Might work
but other than that
can u please be a bit more specific on this method
Old Jul 3, 2008 | 10:50 AM
65 Fury Convert's Avatar
Just sort it
Old Jul 3, 2008 | 10:53 AM
Beelzebub's Avatar
Well
You need to have unix tools on your machine, or there might be a freeware grep utility out there.
convert to CSV as long as there isn't special formatting in the file you will be ok
grep , filename.csc > newfilename.csv
re-import back into excel.
Old Jul 3, 2008 | 10:54 AM
AcuraKidd's Avatar
Originally Posted by 65 Fury Convert
Just sort it
can u give exact directions, cause I have 4 columns of info and it can't be mixed up
Old Jul 3, 2008 | 10:55 AM
NSXNEXT's Avatar
If you want to keep the rows in the order they are in now (without the blank rows)
Add a new column A
Number it sequentially (1 - n)
Sort on column B
Now the the blank rows will be at the bottom (depending if you choose ascending or descending - doesn't really matter either way)
Delete blank rows
Resort by column A
Delete column A
Done
Old Jul 3, 2008 | 11:07 AM
svtmike's Avatar
Add a new column A
Sort on column B
Delete blank rows
Resort by column A
Delete column A
Done
Old Jul 3, 2008 | 11:10 AM
NSXNEXT's Avatar
Originally Posted by svtmike
Thanks.
I spend probably 6 hours a day manipulating Excel spreadsheets.
Old Jul 3, 2008 | 11:11 AM
Billiam's Avatar
Big Block go VROOOM!
Sounds like another classic case of Excel being used as a database.
Old Jul 3, 2008 | 11:17 AM
AcuraKidd's Avatar
Add a new column A
Sort on column B
Delete blank rows
Resort by column A
Delete column A
Done
AMAZING
this method worked, thank you very much
but now I have another dilema...
I'm in MS Word, I imported that excel doc into mail merge, everything came out fine, and I have 291 pages of labels. Now my dilema is that I gotta insert "Queens, NY" into each label right before the zip code. Any fast way of doing that?
Old Jul 3, 2008 | 11:19 AM
NSXNEXT's Avatar
Originally Posted by AcuraKidd
AMAZING
Insert a new column?
You'll have to rerun the mail merge to grab the new column.
Old Jul 3, 2008 | 11:20 AM
#1 STUNNA's Avatar
Sanest Florida Man
find and replace zip code with queens ny + zip code?
Old Jul 3, 2008 | 11:26 AM
AcuraKidd's Avatar
problem is that the zip code is on the same line with the address, cause in excel the zip was in the same column with the address
Old Jul 3, 2008 | 11:34 AM
#1 STUNNA's Avatar
Sanest Florida Man
I think it should still work if you don't include the rest of the address. It should leave the rest of the field alone. Try it on one field and see if it works.
Old Jul 3, 2008 | 11:37 AM
gr8ness97's Avatar
Quarterlife Crisis....
sort?
Old Jul 3, 2008 | 11:46 AM
NSXNEXT's Avatar
Redo the mail merge so the address is on one line and Queens and the zip is on the other.
Old Jul 3, 2008 | 12:57 PM
AcuraKidd's Avatar
what I did do far was go back to he excel doc and added a new column with Queens ,NY.
now when I crest a new mail merge, I insert all the fields, but when I try to insert the queens ny field between the address and zip, I hit the button to update all labels, and it doesnt include the queens ny field
what now??
Old Jul 3, 2008 | 01:00 PM
Shalooby's Avatar
Secret Agent
Use Access.
Old Jul 3, 2008 | 01:02 PM
AcuraKidd's Avatar
Originally Posted by Shalooby
Use Access.
right now thats not an option
Old Jul 3, 2008 | 01:14 PM
meaphool's Avatar
Are you familiar with TEXTPAD (freeware, though if you look you can register it...)?
Using textpad you could do it 1 of 2 ways:
1) Block copy.
2) Find and Replace using Regular Expressions.
Old Jul 3, 2008 | 02:16 PM
Shalooby's Avatar
Secret Agent
Should have Used Access to begin with.
fixed.
Don't use a screwdriver to hammer a nail.
Old Jul 3, 2008 | 04:14 PM
moeronn's Avatar
is learning to moonwalk i
Split the current address into two cells:
Code:
A                                B                                C
1234 Main Street 01101           =(LEFT($A1,(LEN($A1)-6)))        =(RIGHT($A1,5))
That should give you the stree address in column B and the zip code in column C
Old Jul 3, 2008 | 04:52 PM
AcuraKidd's Avatar
Code:
A                                B                                C
this is exactly what I was looking for at the time, but me and a few other co workers figured out an alternate solution that worked out very well
thanks alot for all your help guys, you're the best
Old Jul 3, 2008 | 04:56 PM
moeronn's Avatar
You'll get the bill in the mail.
Old Jul 3, 2008 | 08:44 PM
JS + XES's Avatar
I drive a Subata.
wow, AZ FTW again. great job guys...
Old Jul 3, 2008 | 09:27 PM
#1 STUNNA's Avatar
Sanest Florida Man
Do people actually use access? I thought it wasn't that popular of a database program.
Old Jul 3, 2008 | 11:16 PM
svtmike's Avatar
I use it all the time... and I can get things done much faster than those who are bound by Excel. I can also do analytics with Access that are simply impossible with Excel.
It handles much larger data sets than Excel, is consistent with types, and can of course do the relational database things that Excel can't.
Old Jul 3, 2008 | 11:51 PM
#1 STUNNA's Avatar
Sanest Florida Man
Well I know it's better than excel but I mean compared to other db programs, is access the most popular? If so is that cause it's actually the best or because it comes with some versions of Office?
Old Jul 4, 2008 | 12:01 AM
svtmike's Avatar
The interoperation with the other Office applications is a huge benefit for the type of work I do with it.
I don't know of another desktop relational database that is as easy to use, much less one that offers the integration with Office that Access has.
Note that I use it on my desktop for the relational engine, and never implement a GUI front end or any kind of multiuser access / security.
Old Jul 4, 2008 | 07:06 AM
rza49311's Avatar
Just an FYI here but there's another way to get rid of the blank rows that doesn't require any new columns or formulas.
1. Highlight the affected area only
2. Click Edit > Go To
3. Click "Special" button
4. Tick "Blanks" and hit OK
5. You should see all the blank row highlighted now.
6. Edit > Delete > Shift cells up
7. Done. Blanks gone! Used this many times.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
rboller
Sep 23, 2015 02:49 PM
