SQL Help
Old Nov 16, 2010 | 10:29 AM
hornyleprechaun's Avatar
Bent = #1
SQL Help
Each Vendor has a Vendor ID & Tax ID. I was able to query it so it would display any vendor record with duplicate Tax IDs in the system.
I'm trying to get the last payment date for each vendor by using MAX(). This works, but if a vendor with a duplicate Tax ID has never been paid it won't show up because the MAX() treats that as nothing.
How do I have the code include the payment date if no payment has ever been made? It's an Oracle server... Thanks!
Code:
SELECT V.VEN_ID, V.NAME, V.FED_ID, V.VEN_STAT_CD, APMT.PAID_DATE, APMT.FORM_ID
FROM VENDOR V
LEFT JOIN AP_PH_BASE APMT ON V.VEN_ID = APMT.VEN_ID
WHERE V.FED_ID IN (
 SELECT V2.FED_ID
 FROM VENDOR V2
 GROUP BY V2.FED_ID
 HAVING COUNT(V2.FED_ID) > 1
AND APMT.PAID_DATE = (
 SELECT MAX(APMT2.PAID_DATE)
 FROM AP_PH_BASE APMT2
 WHERE (APMT2.VEN_ID=APMT.VEN_ID)
GROUP BY V.FED_ID, V.VEN_ID, V.NAME, V.VEN_STAT_CD, APMT.PAID_DATE, APMT.FORM_ID
Old Nov 16, 2010 | 10:55 AM
rza49311's Avatar
What do you want it to say?
DO you want a line then some text like "No Payment"?
Old Nov 16, 2010 | 11:03 AM
Bent = #1
If there has not been a payment I want the record to still be displayed, but have the cell that would contain the Tax ID to be empty.
Old Nov 16, 2010 | 11:04 AM
Bent = #1
For instance.. I have a list of all Vendors with duplicate Tax IDs. However, when I try to match the vendors with their last payment, and they've never been paid around 80-100 of those disappear. Since they have no payment I'd like the records to still be displayed, but have nothing for the Tax ID.
Old Nov 16, 2010 | 11:15 AM
rza49311's Avatar
I have a hard time writing code for tables I can't see and test with but almost seems like a virtual table and another left outer might work. See if this does anything.
SELECT V.VEN_ID
, V.NAME
, V.FED_ID
, V.VEN_STAT_CD
, APMT.PAID_DATE
, APMT.FORM_ID
FROM VENDOR V
LEFT JOIN (SELECT VEN_ID, MAX(APMT2.PAID_DATE) as MaxPayDate FROM AP_PH_BASE GROUP BY VEN_ID) APMT2 ON APMT2.VEN_ID = APMT.VEN_ID AND APMT.PAID_DATE = APMT2.MaxPayDate
WHERE V.FED_ID IN (SELECT V2.FED_ID
FROM VENDOR V2
GROUP BY V2.FED_ID
HAVING COUNT(V2.FED_ID) > 1)
GROUP
BY V.FED_ID
, V.VEN_ID
, V.NAME
, V.VEN_STAT_CD
, APMT.PAID_DATE
, APMT.FORM_ID
Old Nov 16, 2010 | 11:28 AM
rza49311's Avatar
Just had another idea as well. in this part of the code,
Are you saying it fails because there is no paid_date in the AP_PH_Base table? is it a NULL? If so, you could do an isnull(). Well I say that, thats a MSSQL command but i'd imagine oracle should having something like it. Lets say the field paid_date is NULL, in MSSQL you would do...
AND ISNULL(APMT.PAID_DATE,'') = (
SELECT ISNULL(MAX(APMT2.PAID_DATE),'')
Old Nov 16, 2010 | 11:34 AM
Bent = #1
Oracle doesn't use isnull but I tried using NVL and it won't work.. guess those cells aren't null.. may be a space in them.
Old Nov 16, 2010 | 11:38 AM
Bent = #1
SELECT V.VEN_ID
, V.NAME
, V.FED_ID
, V.VEN_STAT_CD
, APMT.PAID_DATE
, APMT.FORM_ID
FROM VENDOR V
FROM VENDOR V2
GROUP BY V2.FED_ID
GROUP
BY V.FED_ID
, V.VEN_ID
, V.NAME
, V.VEN_STAT_CD
, APMT.PAID_DATE
, APMT.FORM_ID
This gave me invalid expression.. tried changing some stuff but still didn't work
Old Nov 16, 2010 | 11:42 AM
rza49311's Avatar
I see an error, should be unless you changed that already
LEFT JOIN (SELECT VEN_ID, MAX(PAID_DATE) as MaxPayDate FROM AP_PH_BASE GROUP BY VEN_ID) APMT2 ON APMT2.VEN_ID = APMT.VEN_ID AND APMT.PAID_DATE = APMT2.MaxPayDate
I had the alias inside the select where there was no alias yet.
Old Nov 16, 2010 | 11:50 AM
Bent = #1
Invalid identifier
Old Nov 16, 2010 | 11:54 AM
rza49311's Avatar
I'm using all MSSQL, does Oracle support the AS command?
Might need to just remove that perhaps?
SELECT VEN_ID, MAX(PAID_DATE) MaxPayDate FROM AP_PH_BASE GROUP BY VEN_ID
Old Nov 16, 2010 | 11:58 AM
rza49311's Avatar
Also, the more I think about it, that second left join would probably give you both records if it does work since you are still displaying APMT.PAID_DATE in the select.
If the query does work, you would need to replace APMT.PAID_DATE in the resulting select and the group by to APMT2.MaxPayDate instead.
PS. I may be wasting your time since I don't know Oracle, just tell me to shut it if I'm hurting more than helping
Old Nov 16, 2010 | 12:02 PM
Bent = #1
LOL all help appreciated.. I'm on Day 3 of using SQL & Oracle
Tried your solutions and nothing
Old Nov 16, 2010 | 12:03 PM
rza49311's Avatar
Ok, does this statement by itself run?
Old Nov 16, 2010 | 12:07 PM
Bent = #1
AHHHHH figured it out... The vendors that weren't showing up had no accounts payable entered which means they weren't in the AP_PH_BASE table...
*bangs head into desk several times*
Thanks for the help rza..
Old Nov 16, 2010 | 12:09 PM
Bent = #1
From not where expected.
rza49311's Avatar
Old Nov 16, 2010 | 12:27 PM
Bent = #1
RZA.. if the following shows all vendors with duplicate TAX_ID that have an invoice entered for the vendor..
Code:
FROM VENDOR V
WHERE V.FED_ID IN (
 SELECT V2.FED_ID
 FROM VENDOR V2
 GROUP BY V2.FED_ID
What would I do to get the vendors with duplicate TAX_ID that DON'T have an invoice entered for the vendor..
Old Nov 16, 2010 | 12:37 PM
Bent = #1
Nevermind got it..
Code:
FROM VENDOR V
WHERE V.FED_ID IN (
 SELECT V2.FED_ID
 FROM VENDOR V2
 GROUP BY V2.FED_ID
AND APMT.PAID_DATE IS NULL
Old Nov 16, 2010 | 02:20 PM
rza49311's Avatar
You're going good with the language if its only your third day
Old Nov 16, 2010 | 02:35 PM
Bent = #1
Well kinda.. 3rd day working with my company's Oracle server.. Late last year I created a web site using php & sql queries that I learned from the internet, so not a complete newbie
Old Dec 8, 2010 | 12:03 PM
Bent = #1
Trying to create an agings report for our receivables... I've tried everything IMO and searched forever, but can't figure it out.
I need the following columns based on the same Date Field.. Current, 31-60, 61-90, Over 90. Can anyone help with what the SQL query should look like?
Old Dec 8, 2010 | 01:35 PM
stogie1020's Avatar
Needs more Lemon Pledge
Man am I glad Quickbooks does this for us...
Old Dec 8, 2010 | 01:50 PM
Bent = #1
Yeah I don't even want to go into it, but our software already has a report that does this, but it's crap. Our software program is crap. I have been given access to the database so I'm free to create anything and everything I want to make the Accounting department's jobs easier.
I've gotten a couple files done, but I just can't figure out the damn Agings Receivable one! I have a work around, but I know it's not the correct thing to do.
Old Dec 8, 2010 | 06:16 PM
Anachostic's Avatar
Without knowing the tables and columns I can only point you in the right direction.
Your columns will be something like:
Code:
sum(case when datediff(dd,invoiceDate,getdate()) between 1 and 30 then invoiceAmount else 0 end),
sum(case when datediff(dd,invoiceDate,getdate()) between 31 and 60 then invoiceAmount else 0 end),
sum(case when datediff(dd,invoiceDate,getdate()) between 61 and 90 then invoiceAmount else 0 end)
So what that's doing is summing all the invoices per column but if the invoice date is not between the specific day range, it substitutes zero and doesn't affect the total.
From there it's just a matter of doing the proper GROUP BY to get the rows in the increment or group that you want.
Old Dec 8, 2010 | 06:29 PM
Bent = #1
I'll give it a try tomorrow.. I messed around with cases today, but didn't have any luck. From what I read datediff doesn't work with Oracle, but I know what does. My cases looked a little different though, so I'll give it a shot tomorrow. Thanks.
Old Dec 8, 2010 | 06:35 PM
Anachostic's Avatar
Looks like in Oracle, you just subtract the two dates to get the number of days between them. Sorry about using getdate() for current date since that's T-SQL as well, but I'm sure you know the equivalent by now.
The concept is what you want to go for: a series of columns that sum up part of the invoice amounts based on varying date ranges.
Old Dec 8, 2010 | 06:47 PM
Bent = #1
Yeah that's what I had going yesterday/today, but it just wasn't getting all the same results that our actual report did. I wasn't using cases though when I did that, I just had sub-queries. It's amazing how fast time flies when I'm trying to figure stuff out
Old Dec 8, 2010 | 06:58 PM
Bent = #1
This is what I had that worked, but wasn't 100% accurate.
Code:
SELECT AR.JOB_ID, AR.DISTR_DATE, AR.CUS_INVOICE_NUM,
(SELECT SUM(AR2.AMT) FROM PTI_PROD.AR_BH_BASE AR2 WHERE (AR.JOB_ID=AR2.JOB_ID) AND (AR.DISTR_DATE=AR2.DISTR_DATE) AND (AR2.DISTR_DATE > '2010/10/31') AND (AR2.DISTR_DATE <= '2010/11/30')),
(SELECT SUM(AR3.AMT) FROM PTI_PROD.AR_BH_BASE AR3 WHERE (AR.JOB_ID=AR3.JOB_ID) AND (AR.DISTR_DATE=AR3.DISTR_DATE) AND (AR3.DISTR_DATE > '2010/10/01') AND (AR3.DISTR_DATE <= '2010/10/31')),
(SELECT SUM(AR4.AMT) FROM PTI_PROD.AR_BH_BASE AR4 WHERE (AR.JOB_ID=AR4.JOB_ID) AND (AR.DISTR_DATE=AR4.DISTR_DATE) AND (AR4.DISTR_DATE > '2010/09/01') AND (AR4.DISTR_DATE <= '2010/10/01')),
(SELECT SUM(AR5.AMT) FROM PTI_PROD.AR_BH_BASE AR5 WHERE (AR.JOB_ID=AR5.JOB_ID) AND (AR.DISTR_DATE=AR5.DISTR_DATE) AND (AR5.DISTR_DATE <= '2010/09/01'))
WHERE (AR.AR_TYPE_CD='J') AND (AR.AR_STAT_CD='A') AND (AR.DR_OU_ID='2035')
GROUP BY AR.JOB_ID, AR.DISTR_DATE, AR.CUS_INVOICE_NUM
ORDER BY AR.JOB_ID
Old Dec 8, 2010 | 07:02 PM
Bent = #1
Code:
I got the following error "Incorrect column expression.
Old Dec 8, 2010 | 07:58 PM
Anachostic's Avatar
Do you need to alias the column? Obviously my solution is not Oracle-compatible, but you should be able to do a CASE in a SUM
Maybe Oracle doesn't like BETWEEN. You could try it with > and <
Old Dec 8, 2010 | 09:03 PM
kona's Avatar
Added to_date function.
Code:
(SELECT SUM(AR2.AMT) FROM PTI_PROD.AR_BH_BASE AR2 WHERE (AR.JOB_ID=AR2.JOB_ID) AND (AR.DISTR_DATE=AR2.DISTR_DATE) AND (AR2.DISTR_DATE > to_date('2010/10/31','YYYY/MM/DD')) AND (AR2.DISTR_DATE <= to_date('2010/11/30','YYYY/MM/DD'))),
(SELECT SUM(AR3.AMT) FROM PTI_PROD.AR_BH_BASE AR3 WHERE (AR.JOB_ID=AR3.JOB_ID) AND (AR.DISTR_DATE=AR3.DISTR_DATE) AND (AR3.DISTR_DATE > to_date('2010/10/01','YYYY/MM/DD')) AND (AR3.DISTR_DATE <= to_date('2010/10/31','YYYY/MM/DD'))),
(SELECT SUM(AR4.AMT) FROM PTI_PROD.AR_BH_BASE AR4 WHERE (AR.JOB_ID=AR4.JOB_ID) AND (AR.DISTR_DATE=AR4.DISTR_DATE) AND (AR4.DISTR_DATE > to_date('2010/09/01','YYYY/MM/DD')) AND (AR4.DISTR_DATE <= to_date('2010/10/01','YYYY/MM/DD'))),
(SELECT SUM(AR5.AMT) FROM PTI_PROD.AR_BH_BASE AR5 WHERE (AR.JOB_ID=AR5.JOB_ID) AND (AR.DISTR_DATE=AR5.DISTR_DATE) AND (AR5.DISTR_DATE <= to_date('2010/09/01','YYYY/MM/DD')))
ORDER BY AR.JOB_ID
Old Dec 9, 2010 | 08:34 AM
rza49311's Avatar
Can you post how you applied this code to the query? I would be using this like Anachostic mentioned but you would need to make sure your FROM statement is correct. I wouldn't be using subquery's in the select for this code.
Old Dec 10, 2010 | 10:35 PM
dudeinaTL's Avatar
What if you reboot, that's what I usually do when my computer doesn't work.
CHICKEN204
4G TL Photograph Gallery
Feb 8, 2020 07:50 PM
goose25
Technology
Dec 23, 2009 07:31 AM
