Simple Hard drive recovery question
Old Aug 26, 2010 | 09:47 AM
  #41
Mizouse's Avatar
Ok. Will have to check when I get home.
If not maybe I can just reinstall windows xp and not run windows update
Old Aug 26, 2010 | 10:18 AM
  #42
rza49311's Avatar
If its still a problem and you can't seem to figure it out, I'd imagine the restore does not have SP3 included. You could reinstall, then download the SP3 install, run that, then do windows update. I've seen machine not want to do SP3 first and its pointless IMO not to do SP3 first as it supercedes and/or includes most updates its trying to load.
Old Aug 26, 2010 | 10:45 AM
  #43
Shalooby's Avatar
Secret Agent
Jeebus - buy a mac and be done with it all. Sheesh.
Old Aug 26, 2010 | 10:33 PM
  #44
Mizouse's Avatar
... hard drives fail regardless if they are in a mac or pc...
Old Aug 26, 2010 | 10:34 PM
  #45
Mizouse's Avatar
i figured it out. its a thing called msmpeng.exe that is eating up all the cpu when the computer boots up.
i guess the most recent set of automatic windows updates installed a newer version since the computer seems to run a bit faster at boot.
it was all because i installed the stupid windows live essentials bullcrap.
Old Aug 26, 2010 | 10:55 PM
  #46
stogie1020's Avatar
Needs more Lemon Pledge
Yeah, they never fail...
Old Aug 26, 2010 | 10:59 PM
  #47
Mizouse's Avatar
actually its still there, but the cpu drops from 99% to like 3% or 0% pretty fast.
its only an issue at startup so it doesn't matter anymore.
Old Aug 26, 2010 | 11:02 PM
  #48
stogie1020's Avatar
Hey Miz:
http://www.processlibrary.com/directory/files/msmpeng/
Old Aug 26, 2010 | 11:07 PM
  #49
Mizouse's Avatar
yea i saw that.
i think i read that the reason for the slow down is that its scanning itself.
and to fix it would be just to exclude it from being scanned.
Old Aug 26, 2010 | 11:09 PM
  #50
stogie1020's Avatar
Yeah, it's the startup scan..
Old Aug 26, 2010 | 11:33 PM
  #51
#1 STUNNA's Avatar
Sanest Florida Man
Yup! I've noticed it to on a few PCs, it seems to eat up some resources right after boot but then it goes back to normal afterwards.
Old Aug 27, 2010 | 06:03 AM
  #52
rza49311's Avatar
Yep, that'll do it, as Stunna stated, I've seen quite a few machines have the same issue. I was hoping the 2.0 beta might be better but I'm seeing it spike as well.
Old Aug 31, 2010 | 10:26 PM
  #53
Papa_Sean's Avatar
Contacted HP and luckily the HD is still under warranty. They're sending me a new one Windows 7 comes pre installed so it should be an easy set up. Now on to investigating free ways to recover her pics from that piece of junk....
Originally Posted by JediMindTricks
i had the exact same problem a month ago.
my laptop's hard drive crashed after BSODs. i took the HD out of the laptop and connected it to my old laptop with a similar universal adaptor. once i plugged it into my old laptop, i got the same error message saying i need to format the drive.
basically, after weeks of research and experimenting, i came across a program called testdisk at cgsecurity.org.
after playing with it a few times, i saw that my files are still there (it's a DOS-like tool). i was eventually able to copy all of my files into a 1TB external HD i bought. whew!
i don't remember the steps i took, and it was mostly by chance. good luck!
I'll give this a shot....btw I posted this topic on 3 diff forums and Azine is the only one that came thru! Thanks again guys
Old Sep 1, 2010 | 12:20 AM
  #54
#1 STUNNA's Avatar
Sanest Florida Man
free and data recovery do not usually mix. The question is how much are those pics worth to her? $100? Most data recovery programs let you install and run them for free just to see if it's possible to recover the data using them but if you find out that you can use said program to recover data then that's where they make you pay for the program before it'll allow you to actually recover that data.
but as with all of my advice take this with a grain of salt, see sig below...
Old Sep 1, 2010 | 01:25 PM
  #55
Papa_Sean's Avatar
thanks, I'll keep that in mind
Old Sep 1, 2010 | 01:46 PM
  #56
rza49311's Avatar
Mentioned before, plenty of free tools on Hiren's Boot CD
Old Nov 11, 2010 | 10:45 AM
  #57
stogie1020's Avatar
Less than one year old WD Caviar Blue drive in a Dell desktop just failed... Yay me...
Old Nov 11, 2010 | 10:46 AM
  #58
doopstr's Avatar
^Time for an SSD!
Old Nov 11, 2010 | 11:08 AM
  #59
The Dougler's Avatar
Unofficial Goat
ouch. I've had great success with their drives.
Old Nov 11, 2010 | 11:14 AM
  #60
stogie1020's Avatar
I have had nothing but problems with them. For years. Should have swapped it out the day it arrived...
Old Nov 11, 2010 | 05:28 PM
  #61
Papa_Sean's Avatar
I always hear problems with WD. I bought an external HD from them almost 4yrs ago and still runs flawless *knocks on wood*
Old Nov 11, 2010 | 08:54 PM
  #62
stogie1020's Avatar
In my experience, consistently across their range of products and historically for the last 10 years or so, they are more likely to fail than others. Many people have them and have had no trouble, but I will not willingly buy one and I buy several hundred drives per year.
Old Nov 11, 2010 | 09:36 PM
  #63
Gfaze's Avatar
S E L L
Odd, they've been rock solid for me. I've had one Maxtor and one Seagate fail me but all my WD's have been very reliable.
Feb 25, 2020 09:57 AM
wusty23jd
Sep 24, 2015 11:41 AM
PortlandRL
Sep 14, 2015 12:01 PM
ja17
Sep 7, 2015 06:08 PM
