powerpoint 2002 question
Old Sep 10, 2004 | 10:50 AM
riceboy's Avatar
Darth Tator
i am working with a master slide and was wondering if there was a way to insert a picture into a master slide so that picture shows up on every slide
i looked into f1 help for this and came up with nothing
thanks
Old Sep 10, 2004 | 01:17 PM
miner's Avatar
Sure, insert> picture> from file. Then click on the picture and drag the handles to size it. I do this all the time with our company logo.
Old Sep 10, 2004 | 01:21 PM
riceboy's Avatar
Darth Tator
um, i know how to insert a picture, i wanted to know how to make it appear on the same place on every slide just by inserting it into the masterslide
Old Sep 10, 2004 | 01:23 PM
ib_jimmy's Avatar
just insert it into the master slide...thats what miner was trying to say.
Old Sep 10, 2004 | 01:24 PM
riceboy's Avatar
Darth Tator
thanks for ur reponse
hmm... but its not working for me
Old Sep 10, 2004 | 01:31 PM
ib_jimmy's Avatar
just like adding a picture on a normal slide, u just add it to the master slide.
ib_jimmy's Avatar
what picture format are u using?
Old Sep 10, 2004 | 01:36 PM
riceboy's Avatar
Darth Tator
its a gif file, and its not animated or anything
Old Sep 10, 2004 | 01:38 PM
ju5tchi11in's Avatar
roomate has a CL too
yeah should work all you need to do is paste the picture on the master slide and then ur set. put it where you want it and it will show up on all the other slides you make. like a template... which is what you want.
Old Sep 10, 2004 | 02:03 PM
riceboy's Avatar
Darth Tator
damn, something must be busted
Old Sep 10, 2004 | 03:36 PM
miner's Avatar
If all else fails then insert onto one slide and then copy/paste onto the others.
Old Sep 10, 2004 | 03:47 PM
suXor's Avatar
Still trolling
Well, you might be inserting it under something else:
View-->Master-->Slider Master
Insert your graphic and position/size it
Right click your graphic, and select Order-->Bring To Front
Sometimes people get the title master and slide master mixed, make sure they each get the graphic you want.
Old Sep 10, 2004 | 03:52 PM
riceboy's Avatar
Darth Tator
yup u were right
ur a genius
prop points for u
and everybody else
Old Sep 14, 2004 | 11:57 AM
suXor's Avatar
Still trolling
Glad I could help.
TypeS860
Jan 10, 2026 11:11 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
navtool.com
Sep 25, 2015 05:15 PM
