Please help me with printer networking between Windows 98/XP
Old Feb 9, 2004 | 09:24 PM
Amoeba's Avatar
Best D-Line in the NFL
From: Gainesville, Fl for college, Palm Beach Gardens, Fl at Home
Ok here is the situation. Please try and help. and no im not upgrading my windows 98 comp to XP.
I have a Windows 98 Computer connected with a HP Photosmart 1100 Printer through a usb connection. I then set up the printer as sharing and a network printer. Here is where the problem lies:
I have a notebook and desktop running windows XP. I connected the HP to both as a network printer. The printer only WORKS when the Computer with Windows 98 (The one with the printer attached) is on. How Can I print from my windows xp computers right to the printer on the windows 98 computer, without the windows 98 computer being on. Thank you.
Old Feb 10, 2004 | 10:54 AM
swclown's Avatar
4-8-15-16-23-42
if the printer in question is hooked up locally via usb, you can't. the 98 machine will always have to be on in order to print to it. a true "networked" printer is connected directly to your network via cat5 cable/jet direct and is managed through a print server
Old Feb 10, 2004 | 11:41 AM
Ashburner's Avatar
He is correct. No can do boss.
Old Feb 10, 2004 | 12:14 PM
acur8ly's Avatar
You could use a parallel cable and a print server to network you printer. Print server being a Hp jet direct, a router with a parallel port on the back etc...
Old Feb 10, 2004 | 12:16 PM
anothercls's Avatar
Agreed
You can always get a new router that allows for your USB printer to be hooked up and truly networked. I was unable to find the one with a USB printer hookup, but they do exist. Here is one that uses a parrallel to centronix hookup. http://www.cdw.com/shop/products/def...spx?EDC=454031
Old Feb 10, 2004 | 12:17 PM
anothercls's Avatar
They make less expensive things than jet-direct cards. JD cards usually only fit in larger bulkier laser printers.
le^2
Mar 17, 2026 05:06 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
AcuraKidd
Sep 25, 2015 11:18 PM
