Need some Excel help!
Old Dec 15, 2005 | 01:34 PM
Scrib's Avatar
Administrator Alumnus
Exclamation Need some Excel help!
I'm trying to count the numbers of 1s, 2s, and 3, in particular cells.
The values are in cells in the same column, however there is data between these cells, so I can't say somethiing like =countif(C2:C240,"1")
It has to be somelike like =countif(C2,C6,C10,C14,C19,C37,C42,C98,"1")
^^^but the above clearly doesn't work.
The cells are all over the place.
Ideas?
Old Dec 15, 2005 | 01:36 PM
Nugs3's Avatar
I'm lost
Old Dec 15, 2005 | 01:38 PM
ccannizz11's Avatar
My Work is Done Here
It should still count the number of 1's even if there is other data in other cells.
Old Dec 15, 2005 | 01:40 PM
doopstr's Avatar
I would quit that job and take the new one.
JimmyCarter's Avatar
likes it raw
Unless there are 1's in the other cells that aren't related to what he's counting?
Just set up another column which contains only the selected cells you want and run your count formula then
Old Dec 15, 2005 | 01:43 PM
Scrib's Avatar
I would set up another column, but the spreadsheet can't be altered easily. This is a pretty complex model and a genius manager has decided she wants a count of some data points. I'm sensing we're fucked... I haven't found any way to do this easily...
Old Dec 15, 2005 | 01:47 PM
knight rider's Avatar
Rooting for Acura
Whats wrong with your example?
If you know which cells have the 1s, 2s, and 3s you can do...
=sum(c2,c6,c10...) for 1s
=sum(c3,c5,c11...) / 2 for 2s
=sum(c4,c7,c12...) / 3 for 3s
This would work only if 1s, 2s and 3s are not interchangeable in the same cells of coarse.
Old Dec 15, 2005 | 01:48 PM
rise's Avatar
werd.
copy the cells the you want into a new spreadsheet (paste special - values)...then do your count there.
or copy the whole column to another spreadsheet and do it that way.
i think we need more info on your limitations...
Old Dec 15, 2005 | 01:52 PM
likes it raw
If he could easily tell which ones had 1s and 2s he wouldn't need the count function
ccannizz11's Avatar
Old Dec 15, 2005 | 01:59 PM
Rooting for Acura
shut up
Old Dec 15, 2005 | 02:11 PM
YOTH's Avatar
Thriller
Is this the same guy who asked an Excel question and pissed everyone who tried to help?? Doesn't sound like it but just wondering.
Old Dec 15, 2005 | 02:12 PM
Scrib's Avatar
Do all the count functions in excel work for continuous ranges?
Old Dec 15, 2005 | 02:20 PM
likes it raw
the problem is the comma separator makes the formula think you're into the criteria when you're still setting the range - not sure how to fix it.
You sure you can't do the whole range? What's between the cells?
Old Dec 15, 2005 | 02:30 PM
likes it raw
Are the cells you want to count evenly spaced?
Old Dec 15, 2005 | 04:53 PM
suXor's Avatar
Still trolling
Dude, you were right the first time.
=countif(range,criteria)
=COUNTIF(B2:B28,1)
=COUNTIF(B2:B28,2)
=COUNTIF(B2:B28,3)...etc
Old Dec 15, 2005 | 05:04 PM
fuckleberry's Avatar
=COUNTIF(B2:B28,1)
=COUNTIF(B2:B28,2)
www.readthefuckingoriginalpost.com
Dec 7, 2020 05:39 PM
Aug 15, 2019 12:58 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
InFaMouSLink
Oct 27, 2015 06:52 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
