iPhone 3g charging problem
Old Mar 17, 2009 | 03:53 PM
Hockeyman's Avatar
slobalt defender
First I want to say that there is no way in hell apple would replace my phone, my warranty is void since my phone went through the washer and this is why i have this problem.
My iPhone works perfectly besides not charging, battery life is full right now, first time it's been on since i put it through the wash a few weeks ago. Plugged it into a dock and it recognizes it and plays music but will not charge. Will not sync with my computer either. Anything I can do to try and fix this myself or am i SOL?
Old Mar 17, 2009 | 03:58 PM
GIBSON6594's Avatar
My Garage
This sounds odd, if it's syncing/connecting it should be charging. What is the indicator that it's not charging?
Old Mar 17, 2009 | 04:28 PM
Hockeyman's Avatar
slobalt defender
It does not sync, basically the USB cable does nothing whether it's in the wall or computer. I have a firewire wall charger from my old ipod that I plugged into the wall and it said "not compatable with iphone, charging not supported." Also get this message when it's hooked up to any dock.
Old Mar 17, 2009 | 04:30 PM
GIBSON6594's Avatar
My Garage
sounds fucked to me man
Old Mar 17, 2009 | 04:55 PM
astro's Avatar
Community Architect
robb m.
same thing happened to my 1st gen iPod Shuffle...washed it, and it never charged again...I can still use it as a USB drive though...
Old Mar 18, 2009 | 01:38 AM
Mizouse's Avatar
have you tried the regular USB cable?
Old Mar 18, 2009 | 02:25 AM
03aspec's Avatar
return it but don't tell them that you washed it?????
Old Mar 18, 2009 | 03:54 AM
Sarlacc's Avatar
The Third Ball
wow, I mean just brilliant. You are 2 for 2 tonight numbnuts.
Old Mar 18, 2009 | 08:58 AM
NSXNEXT's Avatar
Have you tried cleaning the charging port on the phone. Take some isopropyl alcohol or contact cleaner and try cleaning the contacts on the phone. I have no clue what the charging port looks like but maybe you can get in there with a qtip of something.
Sounds like the contact that supplies power isn't getting a good connection.
Old Mar 18, 2009 | 01:25 PM
v6cord2k5's Avatar
seizure force field!
If I remember correctly firewire cables don't charge the iPhone. If you lost the original 2.0 USB cable and have an Apple store nearby you can try going in and checking if it charges it on the docks on display
Old Mar 19, 2009 | 02:40 AM
Hockeyman's Avatar
slobalt defender
I've tried both the USB cable and firewire cable, water sensors are tripped so can't return it. I'll try cleaning out the port. Went to the at&t store to try their docks and they will not charge it, recognizes it but says unable to charge using this device.
Old Mar 23, 2009 | 01:23 PM
1StGenCL's Avatar
958 & 991
Sounds like your flex cable is fried. I have the first iPhone and it won't charge except with a higher volt iPod charger. Everything I have read points to this problem
The cable is only 20 bucks but really really hard to replace.
Old Mar 24, 2009 | 06:40 PM
Hockeyman's Avatar
slobalt defender
do they make a higher volt cable for the USB port so I can sync it? If I can't sync then it's worthless to me really, i need my music.
Old Mar 24, 2009 | 06:55 PM
e30cabrio's Avatar
LFG RANGERS!!!!!!!!!!!
Mine stopped charging for no reason, called Apple they had me wipe & restore and it was fine.
They did say if that did not fix it to take it to an Apple store for replacement but since it worked I didn't.
Old Mar 24, 2009 | 08:21 PM
Hockeyman's Avatar
slobalt defender
Wipe and restore using a computer or via the phone itself? Can't sync with my computer but i'll see if doing it on the phone does anything.
Old Mar 24, 2009 | 08:24 PM
Jonesi's Avatar
You can't wipe and restore via the phone itself. You need to do it in iTunes on your computer.
Old Mar 25, 2009 | 10:48 PM
e30cabrio's Avatar
Sorry I missed it won't sync. I did it through iTunes.
Old Mar 26, 2009 | 10:50 PM
Hockeyman's Avatar
slobalt defender
ah well I can't do that...
Old Mar 28, 2009 | 09:32 AM
susu's Avatar
haha, sounds like its worth a try
Old Mar 28, 2009 | 07:06 PM
Hockeyman's Avatar
slobalt defender
^tried every cable besides the high voltage ones
Dec 7, 2020 05:39 PM
MoAbbas
Oct 3, 2015 07:44 AM
Sep 17, 2015 09:01 PM
ivegotthenav
Sep 11, 2015 07:51 PM
IndycarFaster
Sep 11, 2015 02:52 PM
