installing wordpress into my site
The way the install works is that you choose a folder in which you wish to install the blog, that folder is typically how you access the blog. I can't say for certain because I don't know how your host installed the blog.
For example, if they installed the blog in a folder called "blog" at the root level of your site, the path would be "www.yourdomain.com/blog" in order to access the blog.
Have you poked around the admin area to see what the path is to your blog? It's set in there.
Yeah, when one of my customers wants WP installed in their site, I typically will just download and install a sandbox theme (completely stripped) and then use the site's CSS to implement the style.
Example:
Site theme (yes, I completely coded from the designer's files):
http://www.constructivecommunication.com/
Implemented WP theme:
http://www.constructivecommunication.com/news/
Yes, it is a BITCH.
Example:
Yes, it is a BITCH.
If there is one thing I would HIGHLY suggest, is look into changing the administrator username AND password.
I believe the default username for the Administrator is "admin", which every hacker knows to try first, then try a variety of methods to hack into the site.
Changing the username for the Administrator is a little bit more involved and requires direct database access. If you aren't familiar with this, or don't want to mess with it, contact your host.
http://www.google.com/search?source=...AAAKoEBU_QpgbA
Just be sure that any account on your blog that is set as an "admin" isn't the default username "admin".
I don't know how your host set up your blog. For all you know they may have set it up so that there is an "admin" account, and another account that you login with that has admin privileges. Just ensure that there is not default account with the name "admin".
alan_rich
09-09-2015 11:38 AM
SUPRMN84
09-02-2015 11:50 PM
