HP Computer keeps shutting down automatically
Old Dec 5, 2010 | 09:54 PM
Flipster23's Avatar
Ok so my HP desktop computer keeps shutting down automatically by it self. I will turn the power on it will show Windows XP and then shut off. Dont know what the problems is maybe there is a computer guru on azine trying to avoid taking it to geek squad, good thing I have 2 other computers
Plus this might not be in the right section I didnt see a sub forum for computers
Old Dec 5, 2010 | 10:06 PM
SidS1045's Avatar
dumber than a box of hair
I had one of these last week, and it turned out to be a virus that infects EXPLORER.EXE (the Windows desktop) and WINLOGON.EXE. Remove the hard drive and install it as a slave drive in another PC that you know is clean, then run your antivirus program of choice (making sure it's up to date first) against the slave drive.
Old Dec 5, 2010 | 10:59 PM
AZuser's Avatar
_
Sounds like a hardware issue to me.... maybe a bad power supply or mobo?
My cousin had a similar problem... the pc would boot up and you'd see the Windows logo, but then it'd shut down and restart. I swapped out the power supply and all was good.
With one other person, it turned out to be a bad mobo.
Old Dec 5, 2010 | 11:07 PM
Flipster23's Avatar
ok ill try that this week when I go to my parents
Old Dec 5, 2010 | 11:10 PM
svtmike's Avatar
Could be a corrupted driver too. Can you boot Windows into Safe Mode?
Old Dec 5, 2010 | 11:14 PM
stogie1020's Avatar
Needs more Lemon Pledge
Power supply is most likely item of hardware to fail. Also happens to be a pretty cheep piece. Grab one (keep the receipt) and see if it fixes it. If not, return it.
Old Dec 6, 2010 | 12:27 AM
Gfaze's Avatar
S E L L
Happened to my pc. It also toasted my motherboard twice before I realized what was wrong. Luckily newegg warrantied the replacement MB the power supply toasted.
Old Dec 6, 2010 | 12:33 AM
Flipster23's Avatar
ill get a new power supply this week and try that out to see what happens
thanks guys
Old Dec 6, 2010 | 01:48 AM
#1 STUNNA's Avatar
Sanest Florida Man
Seems like an overheating issue to me. Crack open the case and see if all the fans are spinning when you turn it on. The ball bearing in your CPU fan may have gone bad and its shutting down. Or it could be power supply too. Recently I had a client having the same issues, the pc would only be on for a few minutes and then shutdown. It ended up being the APC battery backup that it was plugged into was messed up and would crap out under load. But in my experience it's usually the cpu or power supply overheating.
But then I talk out of my ass a lot sooooo........
Old Dec 6, 2010 | 02:15 AM
stogie1020's Avatar
Make sure you use enough conductive gel when you put the new power supply in. Can have a dramatic effect.
Old Dec 6, 2010 | 07:14 AM
fsttyms1's Avatar
I had 3 HP desktops at work do something similar and it turned out that the motherboards were done.
Old Dec 6, 2010 | 07:56 AM
Whiskers's Avatar
Go Giants
Boot up in safe mode and see how long it stays on...
Old Dec 6, 2010 | 08:05 AM
fuzzy02CLS's Avatar
Could be anything. Bad RAM, MB, power supply, HD, video card, Virus, bad driver....
Have to go through process of elimination.
Old Dec 6, 2010 | 08:29 AM
doopstr's Avatar
Originally Posted by whiskers
boot up in safe mode and see how long it stays on...
+1
Old Dec 6, 2010 | 09:37 AM
lazytik's Avatar
Used to happen to my old PC. Turns out it was a bad power switch...got a new one and it worked fine till I got rid of it. I'm sure I could've fixed it with duct tape...
Old Dec 6, 2010 | 10:37 AM
thunder04's Avatar
Sweet!
Old Dec 6, 2010 | 10:56 AM
evilone's Avatar
COME AT ME BRO!
I am having a similar issue on my Hp desktop. I keep getting sent to a blue screen, then the comp shuts down. I can boot up in safe mode. I also managed to run avast and found 3 viruses and got rid of them. Seems to be working fine right now. You tech guys think that the virus I found would do that? It was virus exe file type.
Old Dec 6, 2010 | 12:13 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Get a Mac.
Old Dec 6, 2010 | 12:20 PM
Flipster23's Avatar
thats my next purchase in a couple of months keep the HP at my parents and the Mac at my house
Old Dec 6, 2010 | 12:21 PM
Majofo's Avatar
More than likely a corrupt driver/s since it starts the boot process before shutting down.
Old Dec 6, 2010 | 01:20 PM
stogie1020's Avatar
Originally Posted by princelybug
Get a Mac and Cheese dinner and continue to use the computer that 90% of the free world uses.
Old Dec 6, 2010 | 09:46 PM
Gfaze's Avatar
S E L L
Old Dec 6, 2010 | 09:52 PM
EuRTSX's Avatar
It refuses to turn on because it's not a mac
Old Dec 6, 2010 | 09:55 PM
Ken1997TL's Avatar
Safe Mode listing the loaded files is your friend
Old Dec 6, 2010 | 10:04 PM
Papa_Sean's Avatar
Can we get a Tech or PC help subforum on AZ?
Old Dec 7, 2010 | 01:52 AM
AZuser's Avatar
_
Yes. I've seen it happen with infected PCs
Even after hooking up the HDD to another PC, scanning and cleaning it, it still wouldn't boot. So fresh install of Windows was only solution. Too many corrupted files I guess....
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
Jinkazetsukai
Nov 21, 2015 05:28 PM
Joe Avesyan
Sep 29, 2015 03:57 PM
rockyboy
Sep 29, 2015 12:05 AM
AcuraKidd
Sep 25, 2015 11:18 PM
