HOok up your 6000 with midi ringtones!!
Old Dec 5, 2003 | 11:31 AM
mikeymobiles's Avatar
Movin on up...
HOok up your 6000 with mp3 ringtones!!
This simple step by step detailed guide will teach the novice user how to place MP3’s onto their LG VX6000 phone. I am doing this because I was a novice looking for a tutorial, but I kept getting confusing responses from other members that were experts.
Prior to installing MP3’s onto your LG VX6000 phone you must have the following:
1. A USB data cable for your phone with the correct installed drivers.
2. BitPm version 0.62. Free Download here…
http://www.cowger.us/bitpim-0.62-forVX6000-setup.exe
3. Sound Forge 7.0 Free Download HERE
http://www.pcworld.com/downloads/fi...ileidx,1,00.asp
Detailed Step by step process…..
1. Select the MP3 that you want onto your phone.
2. Open Sound Forge 7.0
3. Go to “File”
4. Select “Open”
5. Navigate to your MP3
6. Press “Open”
7. Sound Forge will open a 2 bar line display of lines going up and down.
8. Bring your mouse to the black line in between the 2 bars.
9. Locate the start point of where you want the mp3 clip to start.
10. Click on the start point of the clip and drag right around 30-60seconds depending on what you want.
11. Be careful not to drag over more than 80 seconds of MP3 music, because that MAY compromise your phones internal integrity. 60sec’s should be the most.
12. Verify that both sections of the music are highlighted. (It should take up all of the display area.
13. Press “Play” to preview what you highlighted.
14. Hold down “Ctrl” and press “T”
15. Go to “Process”
16. Go down and click on “Resample”
17. Set the “New Sample Rate to 22,050 Hz
18. Press “Okay”
19. Click on “File”
20. Click on “Save As”
21. Click on “Customize”
22. Click on “Convert to mono”
23. Click on “Bit Rate”
24. Find and click on 32kbps, 22050 Hz
25. Click “Ok”
26. Go to “File Name” and rename your clip with a short title.
27. Click “Save”
28. You mp3 clip is now ready to be placed on your phone!
29. Open BitPm V 0.62 ß must be this version
30. Make sure your phone is on and connected to you computer. All usb drivers must be already installed for the phone.
31. Click on the “Ringers” folder tab
32. Click “Add”
33. Locate you mp3 clip that you saved.
34. Click “Open”
35. Click on “Data”
36. Click on “Send Phone Data”
37. Click on the white box (check) to the left of “ringers”
38. Click on the “Add” button on the right of “ringers”
39. Click “Okay”
40. Wait a minute until BitPm says “Ready”
41. On you phone go to the menu.
42. Press 7
43. Then, press 2
44. Find you song and it will play automatically.
45. Click on “Set As” to set the ringer as “Caller Id” or “Restricted”
46. Your finished!
Note: Your phone will handle 20 ringers max. There are other methods of getting mp3’s to your phone, but this was the easiest way for me.
Old Dec 5, 2003 | 12:03 PM
mantis23's Avatar
Moderator Alumnus
so i assume i can use the same method for my 4400?
Old Dec 5, 2003 | 12:07 PM
AgentDSS's Avatar
Black is a ***** to Clean
Does the MP3s sound pretty decent? Does it play on the external ringer speaker or through the earpiece like some deadringers?
Old Dec 5, 2003 | 12:52 PM
Movin on up...
Na, odds are it wont work.....
Old Dec 5, 2003 | 12:53 PM
Movin on up...
I stole this from a cell phone forum..figured it would help, i havent tried it yet but i will tell u when i do...
Old Apr 30, 2004 | 05:34 PM
Mike 350Z's Avatar
Waking this one up from the dead....
Bitpim doesn't let me add .mp3s to the ringer part, just .qcp and .mid files. I renamed my mp3 to each one, and the qcp worked on the computer, but neither worked on the phone. Is there a way i can get bitpim to accept mp3 files?
Old May 1, 2004 | 01:04 AM
Movin on up...
not sure about the details...better off posting on the other forum..i know you have to cut up the mp3 to a ceartin size and how loud it is so it dosent blow your speaker..but dont have the exacts
Old May 1, 2004 | 08:14 PM
Mike 350Z's Avatar
oh i solved my problem. I found a tweaked version of BitPim specifically for the VX600 that supports mp3s, so I'm good to go
tj19855
Dec 5, 2016 09:16 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
AcuraKidd
Sep 25, 2015 11:18 PM
Eggs999bacon
Sep 24, 2015 10:08 AM
datadr
Sep 2, 2015 06:46 PM
