Help, my computer sound isn't working correctly
Old Oct 5, 2009 | 07:07 PM
Costco's Avatar
So recently one of the channels on my 2.1 went bad, but that's another topic (in Home Theater & Electronics)
so while I was trying to figure out if I could fix it or find out what was going on with it, I found some sound settings in control panel. It turns out you can adjust your sampling rate for playback. The default setting for my computer was 16 bit, 44000 Hz (CD Qualiity) which it turns out, is the lowest setting for my computer. So I set it at the highest - 24 bit, 192000 Hz (Studio Quality) expecting drastically improved audio quality
I started listening to iTunes and I didn't notice a difference at all. Hm. Later went to watch stuff on Youtube and not a single sound came out of my speakers. what's going on?!?! now I feel like a dumbass
Old Oct 5, 2009 | 07:16 PM
stogie1020's Avatar
Needs more Lemon Pledge
You have two choices:
1. Go buy a new set of speakers and try them to see if it's the speakers or the computer, or
2. enjoy this thread as everyone posts redonkulous things that are broken, like your Hertz Capacitor, or your 24 bit bus, or the analogue to analogue converter stream bypass filter.
Old Oct 5, 2009 | 08:13 PM
SidS1045's Avatar
dumber than a box of hair
You won't. You can't change the sampling rate of the source material, so that's the limiting factor. If you make your own audio files, you'd have to encode them at 24/192k to hear the difference when you play them back at 24/192k (and believe me, there is an easily audible difference..down side is they take up more disk space).
Does it work if you set it back to 16/44k?
#1 STUNNA's Avatar
Sanest Florida Man
I loled so loud at analog to analog converter!!!
Why can't you just set it back to 44.1/16?
Old Oct 5, 2009 | 08:15 PM
Ken1997TL's Avatar
Jokes aside, 192khz is for DVD audio or something similar in quality. Otherwise you're just screwing up your sound or possibly wasting computer resources.
Old Oct 5, 2009 | 08:16 PM
stogie1020's Avatar
just set it back to what it was.
Old Oct 5, 2009 | 08:17 PM
#1 STUNNA's Avatar
Sanest Florida Man
44.1/16 is CD quality. 192/24 is dvd-audio quality. Most sounds on the interweb and MP3s are 44.1/16 or less.
Old Oct 5, 2009 | 08:56 PM
Gfaze's Avatar
S E L L
Throw your computer out the window and get a new one.
Old Oct 6, 2009 | 02:11 AM
Costco's Avatar
I think this thread made me look dumber than I actually am
Of course I tried setting it back to the default setting... still no luck. I also switched the speakers outputs from left speaker to right channel and vice versa and afterwards it was the right speaker that worked and the left speaker that was silent (the opposite of before). So the right speaker is still good after all
edit: I restarted the computer and it worked again usually I do something that simple but it just went over my head. Anyways, the right channel still doesn't work
Old Oct 6, 2009 | 02:20 AM
Costco's Avatar
Update: Problem is solved, I think
Well, thanks to thunder04 I think I found the solution.
https://acurazine.com/forums/showthr...1#post11376840
I'm 90% sure its the auxiliary cable. No big deal, I'll just swap it out for another one. for AZ
Old Oct 6, 2009 | 07:15 AM
Whiskers's Avatar
Go Giants
Glad I could help...
Old Oct 6, 2009 | 10:43 AM
hANDYcaptd's Avatar
It's the Halladay season!
^ I knew that was coming...
Old Oct 9, 2009 | 09:12 AM
thunder04's Avatar
Sweet!
Originally Posted by Whiskers
Glad thunder04 could help...
Fixed!
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
acurajj
Sep 19, 2015 03:47 PM
Iain MacLeod
Sep 17, 2015 01:01 PM
