Help.... Laptop w/ vista trouble
Old Jan 30, 2009 | 01:00 PM
onebadna1nsx's Avatar
Hello Friend
So Last night I turned off my laptop fine.. but this morning when I went to school I started it up and saw it took longer than usual to boot up... after I type in my password , I noticed it say: preparing your desktop...
I thought how strange... so then the welcome screen shows up, and I see this text pop up from the bottom right sidebar with power options, etc....
it says:
Your user profile was not loaded correctly! You have been logged on with a temoprary profile. Changes you make to this profile will be lost when you log off. Please see the event log for details or contact your adminstrator.
First thing I noticed was my background was gone, and my pictures and file folder is gone.. and then I check my documents... and all my documents are missing... wtf is going on?!?!
I tried system restore to yesterday, but it didn't work... so in short, all my schoolwork and pictures are gone... any way to resolve this problem? Is there a way I can somehow dig up my pictures and word documents?
Old Jan 30, 2009 | 01:08 PM
LIPPSTUH's Avatar
Unregistered user
u have to successfully load into ur own profile or u won't have access to your files from my understanding.
this is why mac>windows
maybe this will help: http://support.microsoft.com/kb/947242
Old Jan 30, 2009 | 01:11 PM
Hello Friend
I've tried:
logging off, and re logging in
restarting the computer a few times
starting up in safe mode
any other ideas?
Yeah I think you're right Phillip... i rechecked how much disc space I have left and it is the same as it was yesterday.
Old Jan 30, 2009 | 01:14 PM
Silver_Surfer's Avatar
Happy Holidays!
I think Windows XP pro sp3 can help you out there.
Old Jan 30, 2009 | 01:16 PM
TeknoKing's Avatar
See this, http://cherrybyte.blogspot.com/2007/...-in-vista.html
Old Jan 30, 2009 | 01:24 PM
Hello Friend
wow, thanks TeknoKing, I can see my files there still! I just have to recover my account!
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList... any idea how I can get there??
Old Jan 30, 2009 | 01:28 PM
TeknoKing's Avatar
Start -> type regedit
You'll see the folder tree on the left, scroll thru it, or use the search in regedit to find your key...
BACK UP regedit prior to saving any edits.
Old Jan 30, 2009 | 01:29 PM
Hello Friend
I figured out I prolly need to get a secondary administrator acct... so i'll try to set up one with the secret administrator acct.
Old Jan 30, 2009 | 01:30 PM
Hello Friend
how do I back it up? I've never backed up before..
Old Jan 30, 2009 | 01:31 PM
TeknoKing's Avatar
In regedit, click File, then Export.. type a name you want, hit Save, you're done.
Old Jan 30, 2009 | 01:32 PM
TeknoKing's Avatar
You should be able to log in under (secret) Administrator when booting to Safe Mode.
Old Jan 30, 2009 | 01:34 PM
LIPPSTUH's Avatar
Unregistered user
the link i posted should have the fix.... follow it
Old Jan 30, 2009 | 01:42 PM
Hello Friend
I THINK I found my two problems:
Ensure the RefCount value is 0
Ensure the State value is 0
my refcount is 0x00000001 (1)
and my State is 0x000080000 (32768)
Do I just do Modify, or do I click on Modify Binary Data?
TeknoKing's Avatar
Lippstuh, Microshaft did provide proper info, they forgot to realize that you will be loaded into a default user profile, where you can't change shit. So the other link, will show him how to log in properly to make the change he needs to.
Old Jan 30, 2009 | 01:44 PM
TeknoKing's Avatar
Double click, type in value, hit enter...
Go for it, you have the back up anyways.. you have nothing to lose.
Old Jan 30, 2009 | 01:46 PM
Whiskers's Avatar
Go Giants
Log in with an admin account.
Hello Friend
Roger that! Did it... so do I have to export this again, or do I just restart my computer?
Old Jan 30, 2009 | 01:48 PM
TeknoKing's Avatar
^ Just restart... What you've exported is your original back up, do not touch it, just in case you've just deleted another profile
Old Jan 30, 2009 | 01:50 PM
Hello Friend
gonna give it a shot... be back soon!!
Old Jan 30, 2009 | 01:53 PM
TeknoKing's Avatar
If something goes wrong, Whiskers did it.
Old Jan 30, 2009 | 01:59 PM
TeknoKing's Avatar
ooops, he's been gone too long....
Must of not reverted to a) Ensure the key name doesn't end in ".bad"
Old Jan 30, 2009 | 02:03 PM
TeknoKing's Avatar
I'm assuming you've only edited the profile that did not work... not all.. right?
Old Jan 30, 2009 | 02:04 PM
Hello Friend
yeahh, only the one that didn't work. It was a "bak" file, so left it alone, changed the 2 values to 0, and no workyy. Should i remove the .bak?
Old Jan 30, 2009 | 02:05 PM
TeknoKing's Avatar
Under the ProfileList subkey, delete the subkey that is named SID.bak.
(HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList)
Old Jan 30, 2009 | 02:08 PM
Hello Friend
okay I deleted it, will restarttt now!
Whiskers's Avatar
Go Giants
Old Jan 30, 2009 | 02:21 PM
TeknoKing's Avatar
and the verdict is?
a) yay, it worked
or
b) f*ck, at least now I can try Windows 7
A or B?
Old Jan 30, 2009 | 02:24 PM
Hello Friend
something is still not working.... double checking
Old Jan 30, 2009 | 02:26 PM
TeknoKing's Avatar
^ what is something?
Revert to
Restore the registry from the back up, and now only delete the SID.BAK file, and Log Off and Log On, do not reboot.
Old Jan 30, 2009 | 02:28 PM
Hello Friend
Every time I put the State to 0 and restart, it goes back to 0x00008000 (32768)
Do I need to change the temp one along with this?
there's a c:\users\eric (which is the one i am editing)
and a c:\users\TEMP.eric-PC
Old Jan 30, 2009 | 02:29 PM
TeknoKing's Avatar
Eric, you are asking me what your user name is?
Change it for all expect Default.. And again, change the value, but do not reboot, just log off and on...
Old Jan 30, 2009 | 02:30 PM
Hello Friend
oh no, i named the account eric
Old Jan 30, 2009 | 02:36 PM
TeknoKing's Avatar
Dude, if you have other means of chatting AIM/Google/ etc.. it will be easier than posting here every sec...
What exactly is happening are you getting the error? Or no error, but nothing is coming back as it was before?
I just think someone delete the account files...and if that's the case the short cuts are gone.
Now if you see all of your documents from before, then everything is ok, just create a new user, and log in under it. Since nothing was deleted, you still have access to it. You will only lose your preferences and short cuts.. Not a big deal.
Old Jan 30, 2009 | 02:37 PM
Hello Friend
do you have AIM or MSN?
aim- onebadna1nsx
msn- onebadna1nsx gmail com
Old Jan 30, 2009 | 02:51 PM
Hello Friend
Got it solved, thanks TeknoKing!!!
Old Jan 30, 2009 | 02:52 PM
TeknoKing's Avatar
^ You're welcome. Enjoy.
Old Jan 30, 2009 | 02:57 PM
EuRTSX's Avatar
Come on Airwick, you're asian, you're supposed to know computers..
08KBP_VA
Oct 22, 2019 01:55 PM
baelim
May 10, 2018 09:53 AM
Jinkazetsukai
Nov 21, 2015 05:28 PM
CWOVette
1/2G MDX (2001-2013)
Sep 27, 2015 02:29 AM
