Help with 64 bit incompatability... (Vista Premium)
Old Jan 20, 2009 | 11:42 AM
Eggplant-EX's Avatar
so, I bought my new Dell laptop yesterday and downloaded a program I use for work. It gives me a 64 imcompatabilty error message. I call the Tech Support for this software and was told they do not support Vista. Ugh! Got the brush off and told to call Microsoft. I googled Microsoft and it seems like they want alot of $$$$$ for Tech Support.
does anyone have any suggestions or is there a telephone # for Microsoft that can help?
thanks.
Ken1997TL's Avatar
What program is it?
Some programs and/or hardware devices simply do not work in 64-bit environments.
Old Jan 20, 2009 | 11:48 AM
STL+3.0CL's Avatar
Matt
If that program is REQUIRED for you to use for work, then you're gonna have to call Dell and see what they can do to get XP for you.
Old Jan 20, 2009 | 12:06 PM
TeknoKing's Avatar
Ok, so you are installing a software on your Vista 64..
Locate the setup.exe file on the cd-rom (or where ever the install files are)...
Right click, select properties.
Click on Compatibility Tab, and select it to run as Vista 32 Bit or plain XP.. click apply.. try it again.
The 32/64 bit nuisance should not be an issue any more with new processors..
Let me know if the above works, if not we'll try other things... What's the program anyway?
Old Jan 20, 2009 | 12:07 PM
Ken1997TL's Avatar
There is always the possibility that the program is older and has a 16-bit installer too, those do not work in 64-bit Windows OS's
Old Jan 20, 2009 | 12:09 PM
#1 STUNNA's Avatar
Sanest Florida Man
try enabling comparability mode. Right click on the applications icon and choose properties and select the comparability mode. Check the box that says enable compatability mode and choose windows xp sp2 and see if that works
Old Jan 20, 2009 | 12:11 PM
#1 STUNNA's Avatar
Sanest Florida Man
to uninstalling and reinstalling using compatability mode.
Old Jan 20, 2009 | 12:18 PM
that was exactly what the Tech Support at MetroScan tried and no luck. Brushed me off to Microsoft. Ugh!
I just noticed on the specs that it says Microsoft Vista Home Premium Edition 64-bit with Service Pack 1 (SP1)
Does the Service Pack 1 make a difference?
Ken1997TL's Avatar
Whats the name of the program? :damnit:
Old Jan 20, 2009 | 12:23 PM
MetroScan
facorelogic.com
Old Jan 20, 2009 | 12:25 PM
F-C's Avatar
F-C
Yup, I tried installing P3 on my Vista at home the other day and couldn't install at all.
Old Jan 20, 2009 | 12:27 PM
#1 STUNNA's Avatar
Sanest Florida Man
Try reinstalling it but run the setup.exe installation program in xp compatability mode.
Old Jan 20, 2009 | 12:28 PM
Ken1997TL's Avatar
Originally Posted by Eggplant-EX
MetroScan
facorelogic.com
Here's a guy who can help you if all else fails.
https://solutionfinderbeta.microsoft...4-bdbd8f3d81f1
He's even in Federal Way AND specializes in Real Estate software
Old Jan 20, 2009 | 12:30 PM
Whiskers's Avatar
Go Giants
Its should install in the Program Files(32) directory!!
Old Jan 20, 2009 | 12:32 PM
Ken1997TL's Avatar
Ok looking over the FAQ and installation guides, i'm almost certain that its a 16-bit installer. You need Vista 32-bit or XP to run this. Sorry
Old Jan 20, 2009 | 12:34 PM
ugh! Thanks all...
Old Jan 20, 2009 | 12:35 PM
Ken1997TL's Avatar
Yeah, this program seems to have some ancient roots. As in, you could run it on Windows 98, thats not a good sign when it comes to running it on Vista 64-bit.
Old Jan 20, 2009 | 12:37 PM
STL+3.0CL's Avatar
Matt
Shitty! Like I said, call Dell and see what they can do to get you XP instead of Vista. Unless you're set on Vista.
Old Jan 20, 2009 | 12:41 PM
#1 STUNNA's Avatar
Sanest Florida Man
Look into dual booting xp and vista or running xp in a virtual machine
Ken1997TL's Avatar
Old Jan 20, 2009 | 12:45 PM
I am always amazed at the help here. I did email him and see what he wants to fix my problem. That would be a start.
I cannot understand how MetroScan can say we do not support this and it is not our problem....
Old Jan 20, 2009 | 12:47 PM
Ken1997TL's Avatar
You'd be surprised how common this is. I have a computer with Vista 64 on it. It can't run a lot of the older hardware I have. The drivers simply are out of date and the companies don't give a shit.
Old Jan 20, 2009 | 01:11 PM
#1 STUNNA's Avatar
Sanest Florida Man
they make more $$$ buy making you buy a new product instead of losing $$$ to take the time to develop drivers, etc for an old product.
Old Jan 27, 2009 | 10:00 AM
just thought some of you might be interested in the reply I got from Microsoft. I am going to have a Computer buddy look at it and see if he can make sense of it.
I would like to apologize for the delay in responding to your support request. Please be assured that you have successfully contacted the correct support team and I will be working with you to address your concerns as quickly as possible.
From your description, I understand that when using Metroscan, it prompts the application is not compatible with 64 bit Windows Vista. If there has been any misunderstanding, please let me know.
I understand the inconvenience you have experienced. Please be assured that I will do my best to help you.
Based on the symptoms you described and the research results, this issue can be caused by third-party products. Please understand we have no direct information about how the application is developed and therefore our help to troubleshoot this issue is limited. Please note that if this issue is determined to be related to third-party software only, it will be better for you to contact its distributor for direct assistance.
I would like to explain that in 64 bit version of Windows Vista, there are two program files folders, "Programs Files(x86)" folder and "Programs Files" folder. When installing 32 bit application in Windows Vista, we can try to install it to Programs Files(x86). Some applications that are not compatible with 64 bit system will work properly.
At this point, I suggest uninstall the application and install it into "Programs Files(x86)". After that, please check whether the application will work properly.
If you have any problem when installing the application, please let me know.
Old Jan 27, 2009 | 10:06 AM
Whiskers's Avatar
Go Giants
Fock, I meant to say Program Files (x86)...
Old Jan 27, 2009 | 10:12 AM
LOL! Whiskers, you knew the problem then and did have the fix.....
Thanks.
Old Jan 28, 2009 | 12:05 AM
" I would like to explain that in 64 bit version of Windows Vista, there are two program files folders, "Programs Files(x86)" folder and "Programs Files" folder. When installing 32 bit application in Windows Vista, we can try to install it to Programs Files(x86). Some applications that are not compatible with 64 bit system will work properly. "
ok. Sorry to be a PITA, but what must I do when I download the program from the Internet?
Old Jan 28, 2009 | 12:14 AM
#1 STUNNA's Avatar
Sanest Florida Man
run the install program and it may ask you during the process where you'd like to install the programs at. Make sure it's directed to "C:\Program Files(x86)\" and not "C:\Program Files" Someone want to explain to me why that would make a difference. I understand that 32bit are installed in x86 and 64 bit are not but why does that make a difference? It seems that it is Windows that is supposed to recognize the program is 32bit and put it in the right folder and nothing about the installer needs to be 64bit aware so that it tells windows which folder to install too.
Old Jan 28, 2009 | 12:24 AM
thanks. Will give it a try right now.
Old Jan 28, 2009 | 06:08 AM
Whiskers's Avatar
Go Giants
Backwards compatibility...
Old Jan 28, 2009 | 09:05 AM
Doom878's Avatar
Looks like it worked since Eggplant hasn't replied again. If so, then it's pretty retarded that the program company didn't know how to troubleshoot and AZ did.
Old Jan 28, 2009 | 10:03 AM
no it did not. Could not figure it out but did not want to bother you guys any more.
Could not figure out where to change C:\Program Files(x86)\ on the download. Will keep trying though if I have time tonight.
Old Jan 28, 2009 | 10:10 AM
Whiskers's Avatar
Go Giants
Download doesn't equal installing. Where are you downloading it from?
Old Jan 28, 2009 | 10:35 AM
facorelogic.com
trying to download MetroScan
When I installed, I did not see a place to change the link...
Old Jan 28, 2009 | 10:43 AM
Doom878's Avatar
Don't download it again. Re-install it. Double click the .exe file that you downloaded. Don't fly through the menus for the install. One of them will ask you where you want to download the file to. Then do what #1 Doucher says.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
08KBP_VA
Oct 22, 2019 01:55 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
ceb
ILX
Sep 27, 2015 10:56 AM
