Excel Question... Again.
Old Apr 5, 2010 | 05:18 PM
stogie1020's Avatar
Needs more Lemon Pledge
I have a workbook with 12 worksheets. Each is identical but named for the month it is to be used in. I restrict what can be done in each sheet and where a user can click, resize, etc. by protecting the sheet.
My problem lies in the fact that when I need to make a change, I need to make it 12 times, and I have to go through each sheet and unprotect, make the change, and the protect again with the password.
Is there an easier way to do this?
Small annoying problem: I have to unprotect each sheet individually and then re-protect them.
Large problem: I have to make 12 identical sheets and adjust each one when I want a change made...
Old Apr 5, 2010 | 05:37 PM
svtmike's Avatar
You can only protect/unprotect sheets one at a time.
To make an identical change in several sheets at a time, select the tabs (through standard click + shift-click or ctrl-click methods) and type the change in once. It will occur in all of the selected worksheets.
Old Apr 5, 2010 | 05:54 PM
stogie1020's Avatar
Thanks. Unfortunately the time consuming task was the un-protecting and re-protecting each sheet...
Old Apr 5, 2010 | 06:08 PM
Pure Adrenaline's Avatar
Dragging knees in
This might not work, but...
Delete all sheets except one.
Make changes.
Copy the sheet 11 times.
Rename each sheet for corresponding month.
Would that not work?
Old Apr 5, 2010 | 06:20 PM
Anachostic's Avatar
Just because it's you...
Open Excel, Hit Alt-F11, open ThisWorkbook, paste this code in.
To run these, view the macros.
Code:
Sub ProtectEach()
    Dim s As Worksheet
    Dim pw As String
    pw = InputBox("Enter password")
    For Each s In Me.Worksheets
        s.Protect pw, True, True, True, True, True, True, True, False, False, False, False, False, True, treu, True
    Next
    MsgBox "Done."
End Sub
Sub UnProtectEach()
    Dim s As Worksheet
    Dim pw As String
        s.Unprotect pw
    Next
    MsgBox "Done."
End Sub
Old Apr 5, 2010 | 07:39 PM
#1 STUNNA's Avatar
Sanest Florida Man
^ he hid a macro virus in white text!
What if you just renamed the spreadsheet once a month?
Old Apr 5, 2010 | 07:46 PM
stogie1020's Avatar
Anachostic, that looks awesome!
Wait, why does it appear to round up the fractions of a penny and put them into your account?
Old Apr 5, 2010 | 08:05 PM
#1 STUNNA's Avatar
Sanest Florida Man
Didn't they do that in Superman 3?
Old Apr 6, 2010 | 07:00 AM
Whiskers's Avatar
Go Giants
4?
Old Apr 6, 2010 | 07:22 AM
rza49311's Avatar
I was going to say you could probably make a macro to unprotect the sheets then another to protect the sheets.
Old Apr 6, 2010 | 11:27 AM
Bearcat94's Avatar
AZ Community Team
Brilliant.
Old Apr 6, 2010 | 12:08 PM
MWalsh9152's Avatar
all work and no play
if you wrap it up when you bring home the nasties, you wont have to worry about protecting the sheets
Old Apr 6, 2010 | 12:33 PM
GIBSON6594's Avatar
My Garage
officespace
Old Apr 6, 2010 | 01:10 PM
johnnysquire's Avatar
In the spirit of teaching the OP how to fish - other repetitive tasks can be automated using the "record macro" function under the Tools->Macro menu. The recorded macro will look a lot like the one posted above.
Old Apr 6, 2010 | 03:22 PM
stogie1020's Avatar
Thanks guys, I have experience recording and using macros, but I was concerned about the macro being accessible to the other users, whom I do not want to be able to un-protect the sheet. Every time I keep the macro in my personal workbook, it seems to end up being available to the general masses...
Old Apr 6, 2010 | 03:33 PM
Anachostic's Avatar
You have to provide the password. The macro is just automating a manual process.
Old Apr 6, 2010 | 03:40 PM
stogie1020's Avatar
Oh, OK. Thanks.
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
InFaMouSLink
Oct 27, 2015 06:52 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
c1souk
Sep 28, 2015 11:20 AM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
