computer advise
Hi all,
Ok so I have a Dell Dimension desktop and I have been having problems with it. I have called for technical support numerous times and on different occasions with the same problem occuring. My computer will work fine, but the next day when i try to turn it on i get a message saying, "Alert thermal event has occured!" I assume this is some sort of hardware issue, but Dell tries everything other then replacing the needed parts. One time they actually had me open it and try to move a micro processor or something like this.
It is working again but I am now trying to clean it up so it runs a little better since this is what they suggested. I deleted limewire off of my computer but i know the songs are still on there somewhere, I need to know how to get them off of my computer. I can't find them.
Cliff notes:
-computer is a piece of shit
-dell costumer service is useless
-tried cleaning up the hardrive
-removed limewire but need to know how to get all the songs off of my computer.
Thanks in advance for any help you guys can provide.
Cliff notes:
Dell has had a LOT of problems with motherboards, overheating, and leaking capacitors for like two years now. "Thermal" event doesn't sound good. Heat=bad.
not sure what to tell you to do about this other than keep trying Dell.
Your limewire files are in the shared folder for the particualr user who was logged on during installation.
Go to my computer, c drive (assuming), documents and settings, find the user (you more-than-likely) and there will be a "shared" folder with yo stuff ( :
PC Guru at your service.
If one of your system fans is toast, they're very cheap to purchase and easy to replace. If it's the heatsink/fan over the CPU that is very dangerous to the life of your CPU. You can check the CPU temperature by downloading shareware diagnostics or within your BIOS. Usually 35-37 Celcius is about right.
If the PC isn't crashing or suffering blue screens of death I'd look into flashing the BIOS to see if makes the error upon boot-up disappear.
I'll be happy to reply if you provide some more info.
G
Thumbsdown to the knuckleheads above him....
Yes, the PC is running hot. Remove the cover and see if that help. Also, is the PC is an open area (are the vents and fans clear, if not clear them.....If all else fails, get a better fan.
The fan is working, right?
Thanks guys...yea the fans working, I can hear it. There is only one fan though. Probably because its a smaller unit. I'm just frustrated because I have called Dell a few times with this problem and they are pretty much useless. I have the extended warranty and maintness plan (or w/e it is called) and they try to instruct me how to fix it over the phone. I think bs they should have me send it in or come an dfix it. I want to have these problems resolved before school starts, I need my computer at school.
Also the computer makes a loud quickly repeating clicking noise. Anyone know what that could be?
Hard Drive failure.
Good luck.
G
i resemble that remark
Originally Posted by GBockers
Clicking sound you hear is your system hard drive dying, if you can, backup your data to CD, DVD, flash drive, etc. They can replace the hard drive but your data is toast unless you have it backed up. If you can afford one buy a USB 2.0 external Hard Drive and move your vital data to that.
Good luck.
G
Good luck.
G
rockyboy
Aug 4, 2024 10:35 AM
AcuraKidd
Sep 25, 2015 11:18 PM
