Can't Connect Two Laptops to Same Home Network
Old Sep 4, 2011 | 11:00 PM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
I have a Linksys WRT54GS wireless router at home. I recently got a new laptop, and I tried to use the wireless feature on my new laptop. All of a sudden both my laptop and my wife's laptop could not connect to the internet, and the Orange "Cisco" light was slowly blinking on and off.
I think it might be because my new laptop said my wife's laptop and my new laptop we had the same IP address. WTF?! We're using the same wireless point!
I have my laptop's wireless function turned off right now. How can I connect both computers?
Also, when I try to set up and encrypt my home network, I tried WPA Personal, what shared key do I put in for the WPA Shared Key? I wrote down a 26 alpha-numeric key before, and when I do this, it immediately kicks me off the network.
I can deal with the security, but I want to solve problem #1, which is both computers having the same IP address.
Old Sep 4, 2011 | 11:23 PM
#1 STUNNA's Avatar
Sanest Florida Man
make sure you don't have a static IP assigned to one of the PCs or if you do that it's outside of the DHCP range.
make sure you DHCP range isn't too small, if its set to only 1 IP address then it will only give out one, though I've never seen a router do that. Me thinks your router sucks and you need a new one or were you messing around with the settings of the router and you messed it up and don't know how to fix it?
Old Sep 4, 2011 | 11:34 PM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Stunna, thanks for the quick reply, but you're going to have to explain the setup to me like you're talking to a five year old.
I went to http://192.168.1.1. At the Setup tab, what should I have as the Maximum number of DCHP addresses? Right now it's set at 50? Maybe 10?
Old Sep 4, 2011 | 11:43 PM
#1 STUNNA's Avatar
Sanest Florida Man
50 is normal and plenty. Actually my friend is complaining of the same thing happening to her router. I'll probably have to go over there and look at it, I've never dealt with this problem but it seems like a faulty router. I don't think there's a setting you can change that will fix this, this isn't a feature of the router.
The fact that it's giving both PCs the same IP address means to me that the router has gone haywire.
Old Sep 4, 2011 | 11:51 PM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Hell. I wonder what the frickin' blinking Cisco light means then. I can't find a definitive answer on the Internet for it and why it's doing that.
Old Sep 4, 2011 | 11:52 PM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
How do I check to see if I have a static IP address then? And why the hell am I getting a problem now, seeing that I had a third fucking laptop that worked fine on the Internet? Why is it that this new laptop makes everything go haywire?
Old Sep 4, 2011 | 11:56 PM
#1 STUNNA's Avatar
Sanest Florida Man
You'd probably know already because it's something you have to do manually.
http://portforward.com/networking/staticip.htm
Old Sep 5, 2011 | 12:06 AM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
OK, so if I had to set up a static IP address manually, it's safe to frickin' assume I didn't do that. I had two laptops connected to the internet before. Why now that I decided to add a third laptop am I having problems?
How do I fix it using http://192.168.1.1 so all laptops work well and can access the Internet at the same time.
Old Sep 5, 2011 | 12:08 AM
Ken1997TL's Avatar
Make sure each laptop is obtaining their IP addresses automatically rather than demanding a specific IP number. This ensures that the router is the boss.
Old Sep 5, 2011 | 12:11 AM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Ken, you're talking to an engineer. I need step-by-step instructions please
Old Sep 5, 2011 | 12:12 AM
Bearcat94's Avatar
AZ Community Team
We had the same (or similar) router.
There are a couple of different settings to look for. 1 is the maximum number of Connections allowed. The other was (iirc) the range of IP addresses to use.
As long those are both large enough to accomodate all your PC's (i.e. at least 3 connections and 3 IP addresses), it's probably not the issue.
Don't forget that you have to count not only wireless connections, but any PC with a wired connection as well.
Old Sep 5, 2011 | 12:13 AM
Ken1997TL's Avatar
This should help
http://www6.nohold.net/Cisco2/ukp.as...ur_network.xml
Old Sep 5, 2011 | 12:17 AM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Number was set to 5. Only have three (soon to be two) laptops connected.
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Stand by....
Old Sep 5, 2011 | 12:30 AM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Well I'm already connected to the internet with this laptop because the other one was turned off.
This laptops IP address is 192.168.1.109. The other one 192.168.1.101
Old Sep 5, 2011 | 12:33 AM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
No dice. As soon as the second one powered up and I tried to access a webpage, I got a blinking light on the Linksys wireless router.
What the hell is going on?!
Old Sep 5, 2011 | 12:35 AM
#1 STUNNA's Avatar
Sanest Florida Man
get a new router
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Wireless is set to automatic configuration - DHCP.
Old Sep 5, 2011 | 12:36 AM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
get a new router
Come on man. I want to try to fix what I have if at all possible. I'm asking for genuine help here...
Old Sep 5, 2011 | 12:38 AM
Bearcat94's Avatar
AZ Community Team
Sounds like something with the other laptop, not the router.
Old Sep 5, 2011 | 12:39 AM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Do you know what it could be?
Old Sep 5, 2011 | 12:43 AM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Is it a problem that when I go to Network Connection Details, the IPv4 Default Gateway is 192.168.1.1 for both laptops?
Old Sep 5, 2011 | 12:46 AM
Bearcat94's Avatar
AZ Community Team
No. I'm just saying your router seems to work like it's supposed UNTIL the other laptop is connected.
You've checked the router settings and if all is well, then maybe it's the laptop itself.
What happens if you use a wired connection for the "rogue" laptop? Does that work?
Is the problem laptop set up to share it's internet connection? If so, disable that.
Otherwise, .
Old Sep 5, 2011 | 12:51 AM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Otherwise, .
I think it works with a wired connection. Not sure how to check whether it's a shared connection....
Old Sep 5, 2011 | 01:05 AM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Wife's Laptop #1
Connection-specific DNS Suffix: hsd1.fl.comcast.net.
Description: Broadcom 802.11n Network Adapter
Physical Address: ‎78-E4-00-4E-60-43
DHCP Enabled: Yes
IPv4 Address: 192.168.1.100
IPv4 Subnet Mask: 255.255.255.0
Lease Obtained: Monday, September 05, 2011 1:31:33 AM
Lease Expires: Tuesday, September 06, 2011 2:02:09 AM
IPv4 Default Gateway: 192.168.1.1
IPv4 DHCP Server: 192.168.1.1
IPv4 DNS Servers: 68.87.74.166, 68.87.68.166
IPv4 WINS Server:
NetBIOS over Tcpip Enabled: Yes
Link-local IPv6 Address: fe80::149a:c5e2:1025:cbca%11
IPv6 Default Gateway:
IPv6 DNS Server:
Old Sep 5, 2011 | 01:07 AM
#1 STUNNA's Avatar
Sanest Florida Man
I was serious.....
Old Sep 5, 2011 | 01:09 AM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
My laptop:
Description: Atheros AR9285 Wireless Network Adapter
Physical Address: ‎90-00-4E-BF-C6-2E
DHCP Enabled: Yes
IPv4 Address: 192.168.1.101
Lease Obtained: Monday, September 05, 2011 1:27:33 AM
Lease Expires: Tuesday, September 06, 2011 2:05:48 AM
IPv4 WINS Server:
Link-local IPv6 Address: fe80::90f6:52fa:504e:45ba%11
IPv6 DNS Server:
Old Sep 5, 2011 | 01:10 AM
Ken1997TL's Avatar
Default gateway is fine. Make sure both laptops are automatically being assigned rather than having a predetermined ip address.
Old Sep 5, 2011 | 01:15 AM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Both are automatically being assigned...
Old Sep 5, 2011 | 01:17 AM
YeuEmMaiMai's Avatar
we had the same router and it did the same thing with my Wii and my laptop..... you could attach 2 wireless devices and then after that no more. The end solution was to replace the router with a better one. Have not had any issues since it's replacement. I even went as far as to hard reset the device and reload the firmware.....
Old Sep 5, 2011 | 01:21 AM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Screw it. I still can't get both laptops to get on the internet at the same time. It's almost 2:30. I'm going to bed. Little will my wife know how I tried to help her out...
Old Sep 5, 2011 | 01:22 AM
Gfaze's Avatar
S E L L
Have you upgraded to the latest firmware? I had the same router and upgrading the firmware solved a few glitches I was having trouble with.
Old Sep 5, 2011 | 11:47 AM
phee's Avatar
I got the Shifts
I would check to see if you have a limit on how many wireless ip's are assigned.
Old Sep 5, 2011 | 11:55 AM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
I'm calling Comcast right now...
Old Sep 5, 2011 | 12:09 PM
Gfaze's Avatar
S E L L
http://homesupport.cisco.com/en-us/support/linksys
Old Sep 5, 2011 | 12:10 PM
Bearcat94's Avatar
AZ Community Team
I think thats a router thing, not an ISP thing.
Old Sep 5, 2011 | 12:11 PM
Gfaze's Avatar
S E L L
As far as they're concerned, you're only using one IP. Your router is assigning private IPs on your network.
Old Sep 5, 2011 | 12:59 PM
slvrdrgn123's Avatar
Have you tried assigning different static IPs to each laptop? Or try pressing the reset button the router itself. Maybe it'll help. Good luck.
Old Sep 5, 2011 | 01:03 PM
phee's Avatar
I got the Shifts
Yup. It would be in your wireless security. All comcast will tell you is they can't help you unless you buy their router
Old Sep 5, 2011 | 01:11 PM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
That's what they told me.
