Can i run two iPods on the same itunes?
The Bearwok
..With SEPERATE libraries. Or is there a way to install two instances on the same pc. Come on apple guys, support your product
The Bearwok
It's for a buddy of mine who has 3 daughters though, and he just bought two of them mini's, it worked fine when they had their own login's but when i rebuilt their computer i made it one login so i can control ram usage and spyware better.
www.ipodlounge.com i believe will help you but i also think that if you set it to manual update then it will work
Originally Posted by mt6forlife
I think you'd need to have one library, then have different playlists go to different iPods.
You have one library.
Then you make playlists. If you choose to copy an entire library into the playlist, then go for it.
And yes....more then one ipod can be hooked up at a time.
Just make sure to name everything so it doesnt get all confused.
4drviper
Apr 23, 2025 07:13 PM
