Apple: iPhone News and Discussion Thread
the ratio of cases/bumpers should greatly out-number the amount of phones...
yet, you can go in the store and buy a phone today, but cases and screen protectors are nowhere to be found...
i dont know why everybody waits for stuff
here is my local best buy on screen protectors and cases...
Unavailable Baton Rouge LA 5913 Bluebonnet Blvd, Baton Rouge, LA 70836
i have this half assed thing on my phone right now...
its the first part of a incipio case without the plastic backing (you get two rubber pieces with each case)
so im using my co-workers yellow piece to at least protect the back.. the screen is making me nuts though... i hate the thought of a huge scratch... i'd be happy with a front/back screen protector...
^ I'm always in limbo about protective cases. If you are going to cover your beautiful phone in a crummy yellow plastic, it kind of defeats the purpose of the beautiful design.
I think I would rather use mine until it's beat to hell and then put a case over it to cover up the dings and marks.
but its gonna be a while before it comes in.
i did not choose nor buy the yellow craptastic cover...
ps. i dont buy my phones for their "beautiful designs"
i buy them for functionality... if you bought the phone b/c it was pretty, you should be put down...
Which is why I love the bumpers, look good on the phone and has some half assed decent protection.
I just need some screen protectors for the back and front and I'm set.
Also already got a tiny tiny tiny scratch (you need the right angle in the right light to see it) on the screen
how i did it. Never dropped or shared pocket w/ keys
Apple: iPhone 4 reception problem is a software issue, fix coming in 'a few weeks'
Posted Jul 2nd 2010 8:32AM by Thomas Ricker
46
diggs
digg
Whoa, Apple just admitted that there's an issue with the iPhone 4's reception, but it might not be what you think:
Upon investigation, we were stunned to find that the formula we use to calculate how many bars of signal strength to display is totally wrong. Our formula, in many instances, mistakenly displays 2 more bars than it should for a given signal strength. For example, we sometimes display 4 bars when we should be displaying as few as 2 bars. Users observing a drop of several bars when they grip their iPhone in a certain way are most likely in an area with very weak signal strength, but they don't know it because we are erroneously displaying 4 or 5 bars. Their big drop in bars is because their high bars were never real in the first place.
To fix this, we are adopting AT&T's recently recommended formula for calculating how many bars to display for a given signal strength. The real signal strength remains the same, but the iPhone's bars will report it far more accurately, providing users a much better indication of the reception they will get in a given area. We are also making bars 1, 2 and 3 a bit taller so they will be easier to see.
We will issue a free software update within a few weeks that incorporates the corrected formula. Since this mistake has been present since the original iPhone, this software update will also be available for the iPhone 3GS and iPhone 3G.
Sure, the odd way Apple calculates bars has been noted before, but what's troubling is that this is the second time Apple has blamed signal strengh / reception issues on software and it doesn't fully explain calls dropping and data degradation when the iPhone 4 is held in a very particular (but common) way. It's also worth noting that Apple in no way admits to an antenna design flaw. Read the full press release after the break.
46
diggs
digg
Didn't Apple do the exact opposite with the iPhone 3G when people were claiming bad 3G coverage so Apple came out and said that they were under-reporting signal coverage and after a software update everyone go more bars. Now they're saying the exact opposite.
Here's why some of you weren't able to replicate the death grip issue where you were located.
this is why I couldn't replicate the problem at work is cause the signal was so good that even with the attenuation caused by my hand I'm still getting a signal in the 5 bar range.
http://www.anandtech.com/show/3794/t...one-4-review/2
that logic makes no sense...
if the antenna isnt the problem.. how come i can go from streaming high quality videos to "searching for signal" by touching the phone.. in the same exact position and place...
what a load of bullshit...
we bought the phone anyways apple.. just admit you fucked up..
ps. can anyone tell me if its better battery-wise to leave the phone on wifi signal or 3G when not in use?
does one take more "trying" than the other to stay connected?....
^I wouldn't bother switching settings. I'd turn wifi off though if you aren't using it and leave 3g on. I only turn 3g off if my battery is real low but this has much better battery life than my iPhone 3g so I haven't had to do that yet.
thanks, i havent come close to killing the battery yet, i've taken it off the charger every morning around 5.45 and when i go to bed at 10 p.m. or so it still has 40-50%.. just noticed i drained it a bit faster today with watching the world cup on mobiTV..
just wanted to know for the future if i could conserve it...
seen 3G's goin for 100...
people are panicking trying to sell their phones to buy the new one and prices are hitting rock bottom..
i saw two 32gb 3Gs for $250 the other day.
but i only need one
Try this srika, try restoring your current 3GS, of course backing it up
And then set it up as a new phone, try it and see if it helps, if not then you can easily restore back to your backup.
