Apple: iPhone News and Discussion Thread
Received 2,797 Likes
The Third Ball
Received 5,056 Likes
why refuse? I ran 10 on my 6 Plus and it was perfectly fine.
I have the 6 Plus and it was covered, just this past October. Take it to Apple Store and have them run the battery test, if it shows the failed battery they will replace the device under recall.
iSeeYouTwo (01-11-2017)
Worth a shot, but no guarantees.
My girlfriend had the same battery issues, dying randomly at 20%. Only to turn the phone back on and it's back at 20%... or even higher. Went to two different Apple stores and they said her battery was almost perfect still.
Q('.')=O
It is a 6s and I checked the serial number but it isn't one that they said they will replaced the battery.
I'm thinking I should definitely go to the Apple store and run a battery test. Even if it isn't under that battery warranty I assume they will still replace it if it fails, right? Maybe I should let the battery run down to 25% when I go to the store so hopefully it fails when I am there?
LFG RANGERS!!!!!!!!!!!
With battery issues like this let the battery go below 18%, then fully charge. If that does not work do a back up and set up as new, install apps one by one until all the apps you want are there or the issue returns (showing which app it was or that it was the os) This worked on my Wife's 10 month old 6S.
Apple can run a diagnostic over the air. No need to go to the store.
Happened again yesterday. I went for a run.. had my GPS tracker app and music running. As soon as the battery got to 20% it said if I wanted to set it to low power mode, I selected yes and it immediately shut off. I tried to turn it back on but it kept showing me I had to plug it in to charge it. As soon as I got to my car I plugged it in and it turned on with 21% battery.
When I was there last time getting mine fixed, I overheard one of the managers telling a technician that it's their policy to not let a customer leave without a satisfactorily working iPhone.... I mean, if they have touched it. This battery issue is VERY FAR from satisfactory...
Any long term review from you guys of those new earpods or whatever they call them?
Go Giants
AirPods
Yeah those
The Third Ball
They instantly pair to your phone when you first open them. They hold a great charge, including the charging case. they instantly hook up when you put them in, and they sound great. I use them at the gym and I love that they stay out of the way everything. Even with my old BT jaybird buds...the wire connecting the earbuds would stick, catch, and in general be annoying.
Airpods 10/10
Costco (01-19-2017)
That post was mostly a beacon for Sarlacc, I'm glad you're subscribed . Pretty glowing review there , i may have to get a set for myself now..
Thanks!
Thanks!
How is the fit/comfort? Same as the factory iPhone 7 wired earbuds?
The Third Ball
They are supposed to be but I can't stand the fit/comfort of the EarPods...I have to use silicon earskinz on them, and I only them around the condo to talk on the phone.
For whatever reason the Airpods fit and feel fine. no issues.
Friend has them, he said wireless convenience is great and they connect fast, but sound quality not much better than the (shitty) old ones. A quick google search confirms this assessment. Grade: C- (stays out of the D range because of the wireless convenience)
The Third Ball
Funny, this came up as #3 on a google search.
Everyone's ears are different and there will lots of division on what "sounds good"
But count on srika to take the immediate dismissive with no actual experience.
AirPods review: Apple's AirPods bring true intelligence to wireless earbuds - Review - Macworld UK
The AirPods sound really good - as long as they're in properly. You lose a bit of quality when they come loose, although that's to be expected. While the earphones sounded slightly flat when we first got our hands on them, after using them for a few weeks (long enough for them to be 'broken in') they produced rich, balanced, warm tones and rather impressive levels of bass perfect for a wide range of music. It doesn't quite have the clarity of, say, the Bose QC35's but at £289 compared to £159, you can't really expect it.
The AirPods are also the only Bluetooth headphones we've ever used that haven't 'dropped out' over a wireless connection. While this should be expected with most high-end wireless headphones, even the Bose QC35s drop out every now and again, making it all the more impressive that Apple's tiny wireless in-ears don't. It's a small factor to consider, granted, but being hit with a few seconds of silence at your favourite part of the song you're listening to is a rather frustrating experience - especially when it happens more than once.
Despite all its praises, it's worth mentioning that there is zero noise cancellation. It wasn't mentioned as a feature, granted, but if you were expecting it, be warned: you can almost always hear environmental noise, especially when in noisy environments like on the London Underground.
AirPods review: Audio quality
Here's the million-pound question: do the AirPods sound good enough to justify that high price tag? In a word, yes.The AirPods sound really good - as long as they're in properly. You lose a bit of quality when they come loose, although that's to be expected. While the earphones sounded slightly flat when we first got our hands on them, after using them for a few weeks (long enough for them to be 'broken in') they produced rich, balanced, warm tones and rather impressive levels of bass perfect for a wide range of music. It doesn't quite have the clarity of, say, the Bose QC35's but at £289 compared to £159, you can't really expect it.
No noise cancellation huh...
Wait are they talking the mic portion or the earphone portion for that
Re reading sounds like earphone. I figure the mic noise cancellation would be done on the phone itself. Disregard last question
The Third Ball
No, these are not noise cancelling. I'll impressed if/when they get that tech into these small things.
That said, havent had an issue. Haven't been anywhere "loud" with them like an airplane, either. Just walking to and using the gym.
First time using a car with apple CarPlay.
omg, don't try to use google maps and CarPlay at the same time
siri was overriding all the prompts for google maps.
also when you have the iPhone screen on showing google maps and you want to reply to a text, it'll switch to the text message app.
when I switched over and started using Apple maps, everything worked more smooth.
The Third Ball
Its also the flaw of CarPlay...Apple needs to swallow their pride and allow google, waze, and other apps be allowed for use through the interface.
Yea, I know. Thought I could still use google maps, guess not.
i did read in the past they allowed google maps, but I think iOS 10 blocked that.
Car play sucks. For now
The Third Ball
I'd like to think they will eventually "get it" and let others in . Else they're not going to last very long.
Sanest Florida Man
Might be in 10.3?
Go Giants
Theater Mode
Airpods not available in store until Mar 8
I ordered them and will have them shipped to me instead, ETA 6 weeks. I'll check in the middle of February to see if stores have them in stock.
I just did a spot check across the country and all the availability for pickup is March 9
Needs more Lemon Pledge
Sarlacc (02-03-2017)
Went to go download the logo brain teaser and it showed 99 cent just missed it
Not news.. but moreso rumors:
Wireless charging and OLED screen?
Forbes Welcome
Also they may break the $1000 price point
Forbes Welcome
You should stick with Fisher Price, only about $15
Azine Jabroni
Forbes Welcome
Forbes Welcome
It almost doesn't matter. People will buy iPhones regardless. There's a rather large subset of consumers who don't cross shop other phones... the question isn't "which phone am I getting next?", it's "which iPhone am I getting next?"
Registered but harmless
Received 1,148 Likes
l'm surprised that there is no Android competition for the iPhone SE small smart phone market- it has no competition from Samsung, LG, etc. I'm an iOS user by default.
There are plenty of Chinese Android phones and Motos that compete price-wise with the SE ($400 starting) but I think they're all around 5" but not full flagship size.
