Any software testers?
Old Feb 27, 2004 | 10:21 PM
mc222's Avatar
I hate the Mets
Well,
I finally have an opportunity to get out of hell and work with a solid company, which I am extremely excited about...I interview on Wednesday!!!!!!!!
One of the small details states:
Proactively work to clarify documentation, including; use cases, test scripts, user doc etc.
I am experienced with UCD and documentation - but I have never seen a test script, much less written one!
I don't want to blow it because of that one detail - and there is a laundry list of other requirements which I am well suited to handle...but
Anyone have any resources I could read up on just so I have some familiarity with test scripts?
Thanks!
Old Feb 27, 2004 | 10:31 PM
AK_MOBBER's Avatar
VOTE OUT THE BUSH REGIME
test scripts are easy!
think of it like a database. You designed this database and you wanna see if will work correctly. You make a test script to load the database with data.
Once the database is loaded with data you can measure its performance and design.
The same kinda thing goes for software. You make a script with a list of commands that executes and tests the output from the application.
does this make sense now?
I'm sure other software guys will chime in here... GOOD LUCK ON THE INTERVIEW!!
Old Feb 28, 2004 | 02:06 AM
underdog's Avatar
I am #76,361,211,935
Test scripts are easy, but tedious!
For a given feature: (ie: user has the ability to do such-and-such)
  • Describe the test-harness setup - what hardware/software
    platform combination in use; what data needs to be
    pre-loaded to perform the test, etc.
  • Provide a step by step procedure to exercise the feature
    - enter integer in field X, push button Y
    - pulldown menu Z, selecting option Q
    - and on ..
    - and on ..
    - and on ..
  • Describe the expected result
mada51589
Jan 9, 2025 04:40 PM
Gary3N
5G TLX Problems & Fixes
35
Feb 25, 2016 06:31 PM
thegipper
Sep 28, 2015 01:01 PM
AcuraKidd
Sep 25, 2015 11:18 PM
mcdata
Sep 15, 2015 05:01 PM
