Another Windows XP Question
Old Sep 1, 2004 | 07:26 PM
Amoeba's Avatar
Best D-Line in the NFL
From: Gainesville, Fl for college, Palm Beach Gardens, Fl at Home
For some reason, on my taskbar about 15 items have to load, and I will use msconfig, but for some reason the icons are not hidden and can not be brought back up by hitting that blue button with the white arrow like it usually does, so there is no autohide and 15 taskbar icons showing. How do I change it to autohide the icons to show only 4-5 or so like it normally does.
Old Sep 1, 2004 | 07:31 PM
zamo's Avatar
Houses Won't Depreciate?
right click on taskbar
Properties
check Hide inactive icons
Customize accordinlgy
Old Sep 1, 2004 | 10:24 PM
Amoeba's Avatar
Thanks, by the way the system starts up quick, then it pauses for about 45secs-1 minute and then the ethernet icons come up in the taskbar and norton antivirus turns from disabled to enabled. Is norton causing this slow startup?
Old Sep 1, 2004 | 11:12 PM
anothercls's Avatar
Yup, Norton be the issue, do you have the whole internet security suite running? If so, I would remove it, but that is just my opinion. TrendMicro is supposed to make an excellent internet security suite, but I have only used the AV, which finds stuff norton misses.
Old Sep 1, 2004 | 11:49 PM
Amoeba's Avatar
It is systemworks 2004, just running norton utilities and antivirus.
BoricuaTL
Apr 8, 2016 01:08 PM
06TLMatt
Oct 2, 2015 08:14 PM
truonghthe
Oct 1, 2015 03:13 AM
datadr
Sep 12, 2015 09:12 PM
ahsm
Sep 9, 2015 08:35 AM
