*228 on Verizon
Old May 15, 2006 | 01:14 PM
Always Dirty's Avatar
*228 on Verizon
What does this do exactly? Why is it "recommended" that Verizon users do it monthly?
Old May 15, 2006 | 01:36 PM
Whiskers's Avatar
Go Giants
It supposely finds the closest tower and leeches to it...
Old May 15, 2006 | 01:40 PM
Viking's Avatar
Quattro in.....
Originally Posted by Verizon Wireless FAQ
1. Why do I need to perform this update on my wireless phone?
By performing this update your phone will stay on the Verizon Wireless network and/or digital service whenever possible. Also, for most price plans after 2/1/2002 the phone roam indicator will turn off/on in accordance to the price plan you have chosen.
4. What benefits will this update provide?
Benefits of this update may include:
- Longer battery life
- Fewer dropped or blocked calls
- Clear, crisp connections in even more areas across the United States
- Roaming indicator will reflect the price plan you have chosen (available on most price plans after 2/1/2002).
http://www.verizonwireless.com/b2c/d...PIC&topicID=47
Old May 15, 2006 | 01:42 PM
doopstr's Avatar
What it really does is save Verizon money by having your phone pick the cell tower that is currently price friendly with Verizon. It does not mean that it will pick the closest tower to you.
Old May 18, 2006 | 01:23 PM
brianlin87's Avatar
ASM I.S. Design FTW.
does sprint have somethin like this?
Old May 18, 2006 | 02:45 PM
Slooo97CL's Avatar
i thought it updated the IRDB (Intelligent Roaming Database)
Old Jun 2, 2006 | 10:55 AM
bigman's Avatar
'Big Daddy Diggler'
all phones have this feature, there are just different ways to do it depending on the provider. What it does is connect you to the closest tower, if you are having reception problems.
Old Jun 2, 2006 | 11:06 AM
moeronn's Avatar
is learning to moonwalk i
I've never done this in the nearly 2 years with Verizon (granted, I never heard of it before today) and even after reading this have no intensions of doing so.
Old Jun 3, 2006 | 09:55 AM
Slooo97CL's Avatar
see post above.
Old Jun 4, 2006 | 08:03 PM
Chopsie's Avatar
Beware of leakage
I do it monthly
Old Jun 4, 2006 | 08:31 PM
iamhomin's Avatar
04 remembrance
Monthly? I do it like, never.
Old Jun 4, 2006 | 09:49 PM
Teh Jatt's Avatar
The Oracle of Acurazine!
how about t-mobile?
Old Jun 4, 2006 | 10:07 PM
kensteele's Avatar
all [cdma] carriers have a method where they can update the PRL in the phone. but you don't really need it.
Old Jun 5, 2006 | 10:42 AM
CKcentral's Avatar
i have had verizon for just over 2 years and have never done this.
Old Jun 11, 2006 | 06:31 PM
Sclass88's Avatar
I've done it maybe 5 times in the 5 years that I've had Verizon.
Old Jun 17, 2006 | 12:23 AM
suXor's Avatar
Still trolling
*228 initiates what is called an OTASP call to the current network. OTASP is Over The Air Service Provisioning. This enables the network to push multipe things to your hadnset including your directory number, mobile identification number (MIN), system ID (SID), PRL (prefered Roaming List), etc.
This is important as carrier add, change and build out thier networks, the handset needs to know these changes. It can be as simple as chaning the priority of the roaming partner order of priority, to adding additional channels in certain markets to increase capacity.
Not updating your PRL may limit your coverage in comparrision to what is truely available to you.
Now, it is also important to note that most handsets today also support OTAPA. OTAPA is like OTASP, however you do not have to initiate it. The carrier can push this informatino to your handset whenever they feel it is necessary.
Lastly, and a bit more geeky, *228 is a shortcut. What is actually happening is that you are dialling one of the following:
*22800 - Cellular A
*22801 - Cellular B
*22802 - PCS A Block
*22803 - PCS B Block
*22804 - PCS C Block
*22805 - PCS D Block
*22806 - PCS E Block
*22807 - PCS F Block
When you dial *228, the handset determines which of the above network blocks you are in, and appends the last two network digits.
Old Jun 17, 2006 | 12:33 PM
kensteele's Avatar
so i said it wrong. i said "all [cdma] carriers have a method where they can update the PRL in the phone. but you don't really need it." i should have said to clarify "all [cdma] carriers have a method where they can update the PRL in the phone. but you don't really need to do this yourself, your carrier will do a great job in making sure your handset has the best prl." there are times when you DO definitely need a better PRL and sometimes it is mandatory. but we don't force the customer to determine that.
example: the best analogy i can relate it to is your navigation and your map disk. if version 2.05 is the latest, you can still drive around town and get to where you need to go just fine with version 2.04 or even version 2.03 but if there is a major change like target changes their name to daytons for all the stores in the midwest, we'll need a new map version 2.10 and since we know everyone will want to go to daytons, we can push 2.10 to all of our customers in the midwest. people in california will do just fine with 2.04 still.
IndycarFaster
Sep 11, 2015 02:52 PM
