Heeltoe Automotive INSTALLATION PRICES
See some of our happy installation customers here!
http://www.heeltoeauto.com/pages.php?pageid=7
I am in Socal. Zip Code 92691. Mission Viejo.
We offer a 10% discount on labor when items are purchased through
Heeltoe Automotive!
Suspension:
All TSX, TL, CL, and Accords
Springs: $220
Shocks: $220 (TL-S w/ Koni add $20)
Springs & Shocks Combo: $220 (TL-S w/ Koni add $20)
Coilovers: $220 (add $140 for EDFC)
EDFC: $230
Camber kits, front or rear: $75 ($35 if done with a shock/spring/coilover install)
Rear Sway Bar: $45 ($24 if done with a shock/spring/coilover install)
Brakes:
Rotors, Front or Rear: $60/pair
Pads, Front or Rear: $40/set
Pads and Rotors, Front or Rear: $60
Pads and Rotors, All 4: $120
Change Fluid: $60 (+ fluid cost)
Brake Lines + change fluid: $120 (+ fluid cost)
Engine:
TSX/Accord 4-cylinder
-Intake manifold gaskets: $120
-All Cold Air Intakes/Icebox: $80
-All short ram intakes: $45
-DC5-R Valve Covers, incl spark plug cover and dipstick: $35
-TSX Headers: $140
-3-Pulley kit: $100
-Crank pulley alone: $60
TL/CL/Accord V6
-TL manifold spacers: $80
-J-Pipe: $60
-Pre-cats: $120 (with J-pipe add $20)
-2G CL/TL Headers: $200
-Crank pulley: $60
Exhausts:
-All Exhausts: $65
-Under-car Cats: $35 (with J-pipe add $40)
Drivetrain:
-All short shifters: $50
-All shifter shifter bushings: $75
-HT-Spec Drivertrain Package: $100
-Clutch Hose: $45 (+ fluid)
Exterior:
Headlight-swap: $60
Taillight-swap: $40
Decklid/roof spoilers, no drilling- $20
Window Visors: $60
TSX
-USDM TSX Foglight Kits: $150
A-Spec or Euro-R lip kit: $125 each, front, rear, or $40 for sides, $260 for a complete kit
TL
-3G TL & TL-S A-Spec lip kit: $125 each, front, rear, or sides, $300 for a complete kit
If there is anything not listed let me know!
Keep in mind that buying parts from me, or getting multiple things
installed will get you a little break in price
Marcus
949-295-1668
Originally Posted by m733l
how much for headers and a rotora BBK (front) on a acura cl-s (6mt)? whats the warranty?
Hmmm...well, I am going to say for the V6 cars, headers are going to be $250. I have not done it before, but I imagine it will probably be a real pain. If it is easy I will charge less. If it is hard, I will charge more....
And a front brake kit will be $75. Not including lines. Unless I need to assemble two piece rotors, then it is more.
Warranty is, If I fuck it up I will fix it. If the part fails and it is not my fault, you need to pursue a warranty claim with the manufacturer.
thanks. still deciding on bbk system and headers. i'll be etting back to you as soon as i figure that out.
A bbk is a waste of money if you ask me....
Get some UP rotors....these are the last ones you'll ever need.
https://acurazine.com/forums/sponsored-sales-group-buys-10/racingbrake-rotors-available-here-now-316102/
I'm Cool
Why not do all 4? And are we changing the fluid to a different brand or something? Or just putting clean fluid in the lines?
Marcus
Marcus
Originally Posted by Bobbydoedoe
i only have 2 lines to swap with. I didn't bother ordering extra lines from rotora for the rear. and i need clean fluid in the lines because its turning dark and would like to get all the bubbles out
Still going to be $150.
If I buy new HID bulbs could you install those too? How much? And do you know how to smoke out the headlights?? I'm sure many want to smoke out their lights but are afraid to do it themselves. I have a '05 TL.
B A N N E D
wait those prices are for part and installation?
do you offer shocks or suspension that offer a luxury comfort ride? i dislike stock TL suspension, its too bumpy on the freeway.
Installation only....
Hmm, well, the Tein CS should be out soon. It is supposed to be pretty comfortable. It is not for your car, but it probably can be made to fit....
Marcus
you konw anything that gives a smooth luxury feeling ride?
You mean, besides the CS? Pretty much everything out there is firmer or similar to stock.
Maybe you shoulda gotta lex... Most Hondas and Acura do ride a little sportier than the competition...
Marcus
Originally Posted by civic2000
Dudes, I got mine done for $100 and four wheel alignment.
Doesn't make sense, why $20 more for removal of shocks, its the same assembly.
Well, hopefully you got a good job done. And I do give discounts when people buy the parts from us too.
Originally Posted by LacViet
Hey Marcus, would you consider to install thermoblocker and HID light bulb on 03 TL-S? I'm not good with installation at all.
Have not done the thermoblocker before on a V6....I have to research the install before quoting.
On the bulb, that should be pretty easy, right?
Originally Posted by TLheaven
how much for a pulley install.
