Service A13 Cost
Old 04-21-2012, 01:10 PM
06TLASM's Avatar
Service A13 Cost
Does anyone know how much Service A13 cost (i.e. Dealer vs Independent)? Also, can you guys recommend a shop around Diamond Bar/Chino Hills? Thanks!
Old 04-21-2012, 01:39 PM
_
AZuser's Avatar
Received 3,097 Likes on 1,867 Posts
A = replace engine oil
1 = rotate tires
3 = replace transmission and transfer fluid
You can do everything yourself. It's pretty easy and will probably run you $80 max. But if you can't,
Dealer (approximate):
A = $35-$40
1 = $15-$20
3 = $150
Independent shop? I'd say about 30-40% less.
Old 04-22-2012, 01:21 AM
SpiderX1016's Avatar
At a dealer, around $200. Well, that's what we charge.
You could probably get it around $100-120 through an independent shop.
Old 04-23-2012, 01:33 PM
7th Gear
kdawg123's Avatar
does anyone know what and how much B 1 2 will cost?
same area. thanks!
Old 04-23-2012, 01:53 PM
_
AZuser's Avatar
B = replace engine oil and filter
1 = rotate tires
2 = replace air cleaner element, replace dust and pollen filter, inspect drive belt
B = same as A, $35-$40
1 = same as above, $15-$20
2 = $140+ which is a major rip off since it's so easy to do yourself. both are like $20 (max) parts, and takes a few mintues.
how to replace dust and pollen filter:
MrHeeltoe
20
02-23-2023 01:54 PM
Mike734
12-10-2021 01:25 PM
08KBP_VA
10-22-2019 01:55 PM
MrHeeltoe
09-29-2015 10:43 PM
thegipper
09-28-2015 01:01 PM
Quick Reply: Service A13 Cost
