Service A13 Cost
Does anyone know how much Service A13 cost (i.e. Dealer vs Independent)? Also, can you guys recommend a shop around Diamond Bar/Chino Hills? Thanks!
A = replace engine oil
1 = rotate tires 3 = replace transmission and transfer fluid You can do everything yourself. It's pretty easy and will probably run you $80 max. But if you can't, Dealer (approximate): A = $35-$40 1 = $15-$20 3 = $150 Independent shop? I'd say about 30-40% less. |
At a dealer, around $200. Well, that's what we charge.
You could probably get it around $100-120 through an independent shop. |
does anyone know what and how much B 1 2 will cost?
same area. thanks! |
B = replace engine oil and filter
1 = rotate tires 2 = replace air cleaner element, replace dust and pollen filter, inspect drive belt B = same as A, $35-$40 1 = same as above, $15-$20 2 = $140+ which is a major rip off since it's so easy to do yourself. both are like $20 (max) parts, and takes a few mintues. how to replace dust and pollen filter: |
