I need recommendations for audio installation!!!
So i have a sub/amp now, and I need any recommendations to a good place that can do a quality job for a good deal. Just a quick hookup is all thats necessary... already got the box.
If it came from Tim's setup then it should be easy. You need a power wirring kit then just mount exact like the setup from Tim's car. Basicly, the + wire connect from batter, goes to fuse holder, then goes to firewall, under the front and rear door sills, goes under rear seat into the trunk. The - wire can connect to the frame in the trunk. Remote on power can be tap into the stock sub power in the trunk. Bass signal can tap into the stock sub using RCA converter. Hook all power and RCA converter to the amp, hook audio cable from the amp to the sub, then you done.
Did the OP get this done?? Adding a sub to a TL should be pretty quick and easy
I could help after I get my son's system installed. He just bought a 92 civic and wants to get his audio taken care of.
I think even circuit city could do this with out f'ing it up....but, if got 10 asian dudes willing to help, just make it happen Just don't let them all supervise, then it probably will get f'dmup
Any of yu guys going to the Iasca Car Audio Competition in Huntington Beach Aug. 8th? It's going to be a tough meet, some real good systems. Even if you don't compete you'll learn a lot and get great ideas checking these cars out...I'm coming down...
BoricuaTL
04-08-2016 01:08 PM
johnpancakes014
04-08-2016 06:47 AM
Pegon95
09-15-2015 01:54 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
