I need the torque specs for front and rear brake caliper bolts for a 2006 TL.
I have a 2006 Acura TL and I am replacing the brake pads and rotors. I need the torque specs for the caliper bolts front and rear and also the torque specs for the bolts that hold the calipers on when I take off the rotors. Ant help would be appreciated.
Word of caution, I think the service manual recommendation for front brembos is really high. I don't think you should be going over 70 or 80 ft lbs on brembos, but hopefully someone can chime in here.
Front A/T
Front M/T
Rears
Front A/T
Front M/T
Rears
Brembo is a brake company, most notably known for "performance" brakes. The manual transmissions and Type-S models came with Brembo front brake calipers, but if your car is automatic/base mode then you won't have these.
D1no (12-22-2018)
DO NOT torque to 125 lbf-ft this probably why most brembo has stripped thread since the caliper is made by aluminum. I last torque mine down to 50 lbf-ft and drive the car for 5 years, no issue with the brake, caliper bolt etc... I will be changing new set of rotors soon and I will find out if my thread is stripped or not.
rockyfeller
02-17-2018 05:39 PM
PDumond
07-23-2017 07:29 PM
