1.Brand of Rim - XXR 530
2.Rim size (diameter and width) - 18x8.75
3.Offset - +20
4.Brand of tire - Continental DWS06
5.Tire size - 225/40/18
6.Drop Type and Amount - H&R Sport kit 50106 - Front 1.4 Rear 1.3
1. Brand of Rim - DR-66
2. Rim size - 18x8
3. Offset - +35
4. Brand of tire - Michelin
5.Tire size - 245/40/18
6. Drop Type and Amount - Tein Street Advance, not sure how much
7. Do they rub - No
8. Transmission type - 6mt
1.Brand of Rim- 2008 Shelby cobra SVT
2.Rim size (diameter and width) - 18 x 9.5
3.Offset - 45mm
4.Brand of tire - Nankan
6.Drop Type and Amount - Raceland coil overs
7.Do they rub - No rubbing
8. Transmission type (use of spacers if 6MT) - 5AT
Updated - same wheels from initial post, but got new tires -
1.Brand of Wheel- Varrstoen MK2
2.Wheel size (diameter and width) - 18 x 10
3.Offset - +25mm
4.Brand of tire - BFGoodrich Sport Comp 2 A/S
5.Tire size - 255/35/18
6.Drop Type and Amount - BC Coils sitting 24" from ground to fender lip in front, 24.5" ground to fender lip in rear, front fenders rolled flat, and slightly pulled, rear quarters rolled and slightly pulled
7.Do they rub - only on the front on dips, need to massage the front fenders a bit more
8. Transmission type (use of spacers if 6mt) 5AT slush
1.Brand of Rim - Verde V99 Axis satin black
2.Rim size (diameter and width) - Staggered: Front 19x8.5 +32mm, Rear 19x9.5 +38mm
3.Offset - See above
4.Brand of tire - Lionheart LH Five
5.Tire size - Front 235/35R19, Rear 265/30R19
6.Drop Type and Amount - None, stock suspension
7.Do they rub - Nope, and they clear the Brembos perfectly
8. Transmission type (use of spacers if 6MT) - 6MT, no spacers. Just bolt em on and ride.
1.Brand of Rim - Enkei RPF1
2.Rim size (diameter and width) - 17" x 9"
3.Offset - 22mm
4.Brand of tire - Firestone Firehawk Indy 500
5.Tire size - 255/40/17
6.Drop Type and Amount - No drop
8. Transmission type (use of spacers if 6MT) - 5AT Type S - No spacers
Hopefully this helps some people out, I know I did a lot of research regarding fitment with these wider tires and appreciated any pics I could find.
Now
1.Brand of Rim - Advan RS
2.Rim size (diameter and width) - 18 x 9"
3.Offset - +29
4.Brand of tire - Kumho Ecsta
6.Drop Type and Amount - Tein SS maxed low
8. Transmission type (use of spacers if 6MT) -6MT (no spacers)
Hey this maybe a dumb question but what kind of lug nuts are those? Brand or any link? Specs (is it 52mm or whatever)? many thanks!!
First post, just picked up an 06 TL 6MT as a daily driver. Completely new to the Acura/Honda world. Installed the springs on Saturday, hoping the front settles a little bit because the rear already looks tucked.1.Brand of Rim - Enkei RC-T4
2.Rim size (diameter and width) - 18x9
3.Offset - +35
4.Brand of tire - Michelin Pilot Super Sport
1. Brand of Rim - Avid.1 AV-30 +35 offset 2. Rim size - 18x8.5 all around 3. Offset - +35 (now "+20mm" due to 15mm spacers) 4. Brand of tire - Michelin Pilot Super Sport 5.Tire size - 235/40R18 6. Drop Type and Amount - Tein SS, slight drop 7. Do they rub - Yep, when hitting bumps 8. Transmission type - 6MT with 15mm spacers all around
1. Brand of Rim - Wedssport SA10r 2. Rim size (diameter and width) – 18x8.5 all around 3. Offset - +35 all around 4. Brand of tire – Continental DWS06 5.Tire size - 245/40/18 all around 6. Drop Type and Amount – stock 7. Do they rub – No 8. Transmission type - 5AT no spacers
1. Brand of Rim - Rays Gram Lights 57CR 2. Rim size - 18x9.5 all around 3. Offset - +22 4. Brand of tire - Hankook Ventus V2 5.Tire size - 255/35/18 6. Drop Type and Amount - Megan Racing Coilovers 7. Do they rub - Fender Roll, only on bumps. 8. Transmission type - 5AT
1. Brand of Rim - Weds Kranze ERM 2. Rim size (diameter and width) – 18x10 all around 3. Offset - +25 all around 4. Brand of tire – BFGoodrich Comp 2 A/S 5.Tire size - 255/35/198 6. Drop Type and Amount – BC Extreme Low Coilovers 24" from ground through hub to fender lip in front, 24.5" in rear 7. Do they rub – Fenders/Quarters rolled and slightly pulled - no rubbing 8. Transmission type - 5AT
1. Brand of Rim - Rays Engineering Forged (Yes, 370Z wheels) 2. Rim size (diameter and width) – 19x9 Front/19x10 Rear 3. Offset - 47mm + 20mm spacer Front/30mm Rear 4. Brand of tire – Toyo Tires 5.Tire size - 235/35 and 255/35 6. Drop Type and Amount – Tein Flex-Z Coilovers - Just removed wheel well gap. 7. Do they rub – Fenders/Quarters rolled - slight rubbing in rear with big bumps 8. Transmission type - 5AT
Do you have camber arms front and back to run 255s? Often seen people run 235s with 9.5 +22 with rolled fenders.
1. Brand of Wheel - Avid.1 AV27 2. Rim Wheel - 18x8.5 3. Offset - +35 4. Brand of Tire - RikenRaptor 5.Tire size - 235/40R18 6. Drop Type and Amount - Tein SAZ, out of the box height 7. Do they rub - Nope 8. Transmission type - 5AT
1. Brand of Wheel - Aodhan LS007 2. Rim Wheel - 18x8 3. Offset - +35 (3mm spacers front to clear Brembos, 5mm back) 4. Brand of Tire - Firestone Firehawk Indy 500 5.Tire size - 225/40R18 6. Drop Type and Amount - Tein Flex Z, between 1.75 and 2 inches 7. Do they rub - Nope 8. Transmission type - 5AT
1. Brand of Wheel - Superspeed RF05RR
2. Rim Wheel - 18x9.5
3. Offset - +38 (10mm spacers, so effective +28mm)
Ended up changing my wheels for the same kind of design, but wider and rotary forged wheels. Fenders rolled.
1.Brand of Rim - Rays Gram Lights 57DR 2.Rim size (diameter and width) - 18x9.5 3.Offset - +22mm 4.Brand of tire - Falken RT615+ 5.Tire size - 245/40r18 6.Drop Type and Amount - None, I swapped these from my 240 to chase a vibration 7.Do they rub - Oh yeah, see 2nd pic 8. Transmission type (use of spacers if 6MT) - auto
So, currently i have 245/35 on aodhan ds09 18x9.5 offset +30. It's too stretched for my liking and I'm really not sure what size tire to go for now, (these are older tires i had lying around so i put them on) but i wanna go for a 245/40 and lower my car a little bit when i eventually get coilovers but I don't want to need to roll my fenders right away. Do y'all think there would be any rubbing that would cause issues? Pictures are of my current set up
SInce you don't seem to be lowered (and if you don't plan on being), you could easily fit 255/40 or 255/35, but since your wheels are already poking quite a bit, that might not be ideal. Do you have spacers?
245 isn't very stretched on a 9.5, I'm on 235/40 and it's not that bad, still within the tire manufacturer's specs. You could try 245/40, it will give you a bit more sidewall so it won't look as stretched. But if you're into meaty tires, then your wheels probably aren't suited to that. Going wide often means having to stretch your tires so they fit your fenders.
I don't have spacers no, the offset of +30 just puts them there unfortunately that's the only part I'm not super happy about with these wheels. But yeah i was hoping to lower it maybe an inch in the future, but the main reason i would like less stretch than what i have is I'm just not a big fan of the lip of the wheel sticking out past the tire, i had the same specs on my old wheels and the lip didn't stick out THIS far so i figured the same tires would be fine. So that's why i wanted to go to a meatier tire set up, what do you think would be preferred route in this situation for a new tire size?
Lower first, then see what can fit.
If you change tires now and lower within a year, you'll probably end up having to change your tires again.
Yeah that's fair, I'll go ahead and do that and see what's up. Plus going lower naturally will give slight camber so maybe I'll be into how it looks with this size on it just being lowered, thank you for your help
1. Brand of Rim - ESR RF2 Graphite 2. Rim size (diameter and width) - 18x8.5 3. Offset - +30mm 4. Brand of tire - Continental ExtremeContact DWS06+ 5. Tire size - 235/40R18 6. Drop Type and Amount - Mild ~1.5in drop on Tein Street Advance Z coilovers, natural camber 7. Do they rub - No rubbing 8. Transmission type (use of spacers if 6MT) - 6MT no spacers. Tight clearance, about 2mm between spokes and face of the caliper.
The TL is sitting pretty despite turning 20 years old! Just finished up with new wheels, tires, and a complete suspension refresh w/ Tein coilovers, lower ball joints, control arms, axles, tie rods, and sway bar end links. Figured I'd post some pics since while I was researching these wheels I couldn't find any TLs running ESR RF2s in this size. Overall I'm super happy with how they look after installing coilovers. They poke a little too much at the stock ride height which looks kinda goofy.
Fitment is almost perfect in my opinion. The fronts are flush with the fender at the current ride height. The rears could maybe use a 5mm spacer. However I will be adding camber arms in the rear which, in addition to bringing the rear camber back into spec, should make the rear sit more flush.
