BT45-HON3 bluetooth streaming (quick install)
Old 12-31-2016, 01:57 PM
williamv_ovoxo's Avatar
This is just a very quick and easy way to install your HON3 unit. I chose to install it in the trunk to my XM Tuner unit. I have a 2006 TL w/ Navi. I learned that if you have a 2007 or 2008 TL then you need the BT45-ACU not the BT45-HON3 (double check that info). The unit comes with clear instructions with how to install but this is just a quick and I repeat QUICK write up DIY whatever you wanna call it, with photos. The operation/set up is easy to do.
Here are some photos of the BT45-HON3 Unit to familiarize yourself with 2pages of instructions
If you are installing this unit in the trunk then you do not need this cable it's already connect to the harness just remove it. You only need it if you're going to install it to the back of the radio. it should be labelled as "CAS-H3t"
Here is the photo of where the XM Tuner unit is located in the trunk of you 2006 Acura TL with Navi with the carpet and everything else removed. Removing the carpet is very simple and quick.
Now just reach your hand in and unplug the factory harness from the unit.
Next connect the original XM tuner harness into the 14-pin female adapter of the BT45-HON3 unit as shown
Then Plug in the 14-pin Male connecter of the BT45-HON3 into the XM Tuner. The connection is the exact same size as the original connection to the XM tuner. Since you can't see what you're doing you need to just feel it out but it should go right on in. When you finish plugging in the unit the instruction manual tells you how to set your dip switches (the dip switches are shown in the 2nd photo of this write up) which should be 1&3 ON and 2&4 OFF
and WALLLLAAAAHHHHHH! All you need to do now is just mount the BT45-HON3 Unit some where in the trunk where it won't be damaged. The unit comes with a microphone that you need to run all the way from the unit to the front of the car in order to use the Hands-free calling on the unit. Call audio comes in from the unit to your car speakers but your voice will not be heard unless you plug in the microphone. You can also connect the auxiliary cable and run it from the back of the car to the front of the car which is what I'm in the process of doing, soon.. lol Then just put your carpet back into place and you're done. When plugging in the unit to the XM tuner to make your life easier you can unscrew the XM unit but thats completely up to you! I chose not to!
The following 2 users liked this post by williamv_ovoxo:
hannamand (04-04-2017), LoveMyTL-S (05-06-2019)
Old 03-19-2017, 03:17 PM
hpcacura's Avatar
Cool writeup, thanks! Do you know if the factory handsfree calling still works? This would negate the need to run the microphone wire to the front of the car (I"m looking for SIMPLE!).
Old 03-24-2017, 08:54 AM
Le7316's Avatar
so I guess whenever you streaming , you are using your data from your phone ?
Old 03-24-2017, 10:33 AM
jzhu625's Avatar
i'm thinking to order this but how does "LIVE TRAFFIC" work?
Old 03-25-2017, 04:42 PM
swimgeek44's Avatar
So I got the unit plugged in the rear last weekend and loved having it to play music and audiobooks on commute! My tape player broke, and the FM tuner Bluetooth thing I got was terrible.
today I pulled apart the car more and ran the microphone, but there wasn't enough length to get it to the rear view mirror. Ugh. Right now it's kind of clipped below the tape player on one of the little cubbys.
im hoping to extend the cable, cut the mic off, and hook into the mic that was used for HFL at some point. Gotta have goals!
anyone else try to hook into the HFL mic?
Old 04-04-2017, 09:54 AM
hannamand's Avatar
This is awesome, thank you. I've been thinking about ordering one of these, but can't seem to find any videos on function or install (for our cars) on YouTube. All this time I've been thinking it hooks up to the back of the radio.
Old 04-07-2017, 12:41 PM
donkiboy's Avatar
Smile
I also installed the BT45-HON3, and plan on attaching the mic. Would you say that it's long enough to at least reach the steering wheel column?
Tapping into the existing HFL mic line seem like a cleaner setup only if I knew where that was located.
Old 04-10-2017, 09:42 PM
swimgeek44's Avatar
Probably, just install the box more towards the front and don't leave slack. And don't button everything up until you figure out how far it can go haha!
Old 04-10-2017, 09:49 PM
Sorry for the late response, I installed my microphone in the upper left hand corner of the windshield and just tucked in the wires in the dash in between the cracks and they are completely hidden. I've tested the microphone and it sounds very clear and do not have to speak loud for it to pick up my voice.
Old 05-28-2017, 08:17 PM
axesd's Avatar
After reading this write-up, I am going to buy the unit now. I got two questions thou
1. What's the cleanest way to hide that microphone? (How to route it cuz I don't really know my car lol)
2. I can still buy a long enough AUX jack to play music right? Which channel will it be and how long do I need to get that AUX cable?
Old 06-02-2017, 12:56 AM
Dingo's Avatar
Originally Posted by hpcacura
Cool writeup, thanks! Do you know if the factory handsfree calling still works?...
This question was never answered and I'm wondering the same thing... all I want to do is add Bluetooth streaming capability from my iPhone - is this the wrong product?
Old 06-04-2017, 09:39 PM
axesd's Avatar
Attachment 40808
Attachment 40809
Attachment 40816
Attachment 40810
Attachment 40811
Attachment 40812
Attachment 40813
Attachment 40814
Attachment 40815
I have such a tough time to unplug the factory harness from the unit..any tips?
I believe you have to use the mic that come with it. Button should all work
Old 06-09-2017, 09:42 AM
mazen222's Avatar
Per the product spec, this unit will maintain all original features. You can even use the steering wheel musci controls with it
I think i'm going to get me one!
Old 06-09-2017, 10:24 AM
mazen222's Avatar
Alright, i just bought it... $150 CAD off amazon, pretty good compared to $250 USD stock price. Looking forward to install it.
Old 06-09-2017, 04:12 PM
djlars3's Avatar
Installed the ACU version in 2008 TL and it works great. So nice to still have all the steering wheel functions and to be able to see the name of the song and artist on my nav screen.
Old 06-09-2017, 06:57 PM
DjKeebz's Avatar
I just got an '05 TL with navigation Do you have to have the livetraffic subscription for this to work?
Old 06-10-2017, 01:11 PM
djlars3's Avatar
No you do not. Just install into xm module in the passenger side of trunk and your ready to go.
Old 06-13-2017, 12:25 PM
mazen222's Avatar
Do you guys know how to check the firmware/software of this unit? I would like to ensure that i have the latest version.
thanks,
MM
Old 06-16-2017, 09:01 AM
mazen222's Avatar
So i contacted USA-Spec and using the code on the module they were able to tell me that i do not have the most up to date software in my unit... they suggested i return it to where ever i bought it and buy a new one from their recommended distributors. I've asked what's the difference in the software have and the latest one so see if it's worth it... I'm waiting for a response.
I must admit i dont full buy this story from them... but we'll see what their response is.
Old 06-16-2017, 09:03 AM
Latent car nut
horseshoez's Avatar
Received 2,036 Likes on 1,423 Posts
Just curious; who did you buy your device from? I'm about to pull the trigger on a BT45-HON3 from Amazon.
Old 06-16-2017, 03:53 PM
mazen222's Avatar
I bought it off Amazon from Naturalsound.
USA Spec came back with this:
The software upgrade allows the BT45-ACU to run more smoothly. In addition it resolves some of the unexpected issues, such as muted audio
i will try to return it and get one from their distributors:
The best way to guarantee you buy the latest one, is to …
1. buy it from our only online authorized reseller https://www.crutchfield.com/p_581BT4...g&awug=9031227
2. a car-electronics specialty retail shop with our product in stock. Or…
3. Directly from us.
It doesn’t only guarantee you are getting one with the latest software but it also gives you a full 1-year warranty (from purchased date).
The following 2 users liked this post by mazen222:
horseshoez (06-16-2017), LoveMyTL-S (05-06-2019)
Old 06-16-2017, 04:04 PM
truonghthe's Avatar
Received 1,694 Likes on 1,308 Posts
does any one experience with the BT45-Acu has static noise come from the front tweeter?
Old 06-27-2017, 07:21 PM
mazen222's Avatar
So after many back and forth with the manufacturer, it turns out that these units require software updates from USA spec. Unless you buy it from their authorized dealers they refuse to provide the software updates for free.
With that being said, i would stay away from them. I am returning my unit to Amazon and will not purchase from USA spec ever again due to their very poor customer service.
Old 09-29-2018, 02:47 AM
5th Gear
marty.zigman's Avatar
I just posted a thread on how to install this unit in a 2006 MDX. The left rear panel removal was difficult. I hope it helps others.
Old 09-29-2018, 01:07 PM
Tycoon
robowarrio's Avatar
Did mines about a month ago.. Went with USASpec from Crutchfield just because of the warranty if I run into any issues..
What a huge upgrade for me! Very happy with it!
Old 11-25-2018, 12:53 PM
ghernz's Avatar
Have a couple of questions?
2006 TL Navi with tape deck: Will this still work if Navi hard drive is not working “cd error”?
2007 Mdx with cd: Will this still work with HF disconnected “HF drains battery when connected”?
Old 03-14-2019, 03:11 PM
7th Gear
NIL8er's Avatar
Hello alll, ive put this unit in my 3g 06 with navi and cant figure out how to still get my XM to work. Have a subscription but blue tooth takes over both xm1 and xm2 fuunctions. tried all combinations with the little switches on the hon 3 but no luck. Anyone know how to remedy this, im pretty sure i read somewhere its possible to retain XM function with this unit.
Old 03-14-2019, 09:10 PM
truonghthe's Avatar
If you switch to XM2 then all the channel still there... I got Acu and Hond3 and all of them works like it should be.
Old 03-14-2019, 09:14 PM
Latent car nut
horseshoez's Avatar
Not that I really care as I don't use XM, but my BT45-HON3 does the same thing, both XM1 and XM2 are blocked by the USASpec device.
Old 03-21-2019, 03:19 PM
7th Gear
NIL8er's Avatar
Hmmm mine doesnt . the blue tooth is there. ive installed it in back to the xm tuner and directly to the radio. Must be a XM issue?
Old 03-21-2019, 03:25 PM
Latent car nut
horseshoez's Avatar
I doubt it is an XM issue, my XM worked perfectly before I put the BT45-HON3. That said, I don't use XM so I don't really care. The only reason I know the XM works is because I did a 3-Month trial, didn't like it, and bought the HON3 immediately after the trial period ended.
Old 03-21-2019, 04:12 PM
truonghthe's Avatar
I will take a pic or video later show my 05 which has HON3 work perfectly fine between BTA and XM radio.
horseshoez (03-21-2019)
Old 03-21-2019, 07:03 PM
7th Gear
NIL8er's Avatar
So i take it .....YOU DONT CARE?
Old 03-21-2019, 07:17 PM
Latent car nut
horseshoez's Avatar
You think?
Old 04-20-2019, 06:15 PM
Hiryuu's Avatar
Thanks, this is very helpful as my HFL just went bad
Old 04-29-2019, 03:45 PM
-------Tim-------
Slpr04UA6's Avatar
So this unit will work with a non Navi TL? Plugged in the same way (in trunk to XM)? Do you retain any steering wheel functions? What is the benefit of putting it behind the head unit up front? I really don’t care to hook up the mic for HFL....if that makes it easier or harder...
Old 05-01-2019, 05:47 PM
-------Tim-------
Slpr04UA6's Avatar
Anyone?
I guess for the Bluetooth capability (and ease of use), it’s between this and the USA spec.....from what I’ve read. Thanks for any input for a 2004 non Navi....
Old 05-02-2019, 09:39 AM
truonghthe's Avatar
Originally Posted by Slpr04UA6
Anyone?
yes this will work even your TL is a non-Navi model, for people who has XM subbed they retain the XM radio while enjoy BT streaming. Beside plug in the XM is easier to install compare to remove the radio.
Slpr04UA6 (05-02-2019)
Old 05-02-2019, 09:46 AM
-------Tim-------
Slpr04UA6's Avatar
^Thanks!
I’ll make sure to purchase through an authorized seller!
Old 06-10-2019, 01:05 PM
Storm's Avatar
Will this work if my Navi is not working?
