Show us your aftermarket and OEM wheels on your RL
Old Nov 24, 2015 | 10:23 AM
  #401
oo7spy's Avatar
Should be ( | )ss, no?
Old Apr 3, 2016 | 06:07 AM
  #402
tla11384's Avatar
Bigger is better :D
Here are my new shoes. Ace Convex 19x8.5 with ET30 wrapped in 245/40/19 Continental ExtremeContact DWS06.
Attached Thumbnails Show us your aftermarket and OEM wheels on your RL-20160401_220849.jpg   Show us your aftermarket and OEM wheels on your RL-20160401_204531.jpg   Show us your aftermarket and OEM wheels on your RL-20160402_104055.jpg
Old Apr 3, 2016 | 07:54 AM
  #403
oo7spy's Avatar
Those are really clean!
BTW, you can embed pictures directly to the site now. You don't have to attach them to avoid hosting them externally.
Old Apr 3, 2016 | 02:26 PM
  #404
tla11384's Avatar
Good to know. Cause the url was a pain!
Old Apr 4, 2016 | 03:34 AM
  #405
tla11384's Avatar
Old Apr 5, 2016 | 01:25 AM
  #406
kcjohnnyboy's Avatar
^^those are nice
Old Apr 28, 2016 | 05:47 PM
  #407
1CLNRL's Avatar
New Shoes
20x9 +35 Niche Ritz
245/35-20 Falken Tires
Old Apr 28, 2016 | 07:37 PM
  #408
oo7spy's Avatar
Old Jul 10, 2016 | 01:45 AM
  #409
Kb1_Laoxxkidd's Avatar
4th Gear
19x9 +20 235/35 concept 1
Old Jan 4, 2017 | 03:59 PM
  #410
Shoxrider's Avatar
Acura OEM wheels Pictures
Looking for ideas on OEM Acura wheels for the 05 RL. Stock 17's might get the dedicated snow tire treatment.
Old Jan 4, 2017 | 04:23 PM
  #411
MSW 6SP's Avatar
Old Jan 4, 2017 | 07:31 PM
  #412
oo7spy's Avatar
MDX, ZDX, 4G TL, 3G TL (redrilled), and RLX have all been done. Find the "search this forum" toolbar just above and to the right of the threads when you are in the wheels section.
Also, instead of talking about them again in a new thread, I am going to merge this thread with the aftermarket wheels thread.
Old Jan 4, 2017 | 07:33 PM
  #413
oo7spy's Avatar
Also, I stuck the thread so it will remain at the top of the forum.
Old Jan 18, 2017 | 08:53 AM
  #414
ksu1018's Avatar
05 RL Wheel Option
Show us your aftermarket and OEM wheels on your RL-09-acura-tl-wheel.jpgDoes anyone know if these wheels would fit my 05 RL? I know the offset has to be big enough to clear the front rotors. I checked online and what I find is that the offset on the wheels in the picture is 55. These wheels I am interested in are from a 09 Acura TL.
Old Jan 18, 2017 | 08:57 AM
  #415
Generally, Acura wheels will fit on other Acura's provided same lug nut pattern...
Old Jan 18, 2017 | 09:01 AM
  #416
quick google search found this: https://acurazine.com/forums/2g-rl-t...ke-fit-803851/
https://www.google.com/search?q=09+a...hrome&ie=UTF-8
Old Jan 18, 2017 | 09:04 AM
  #417
^thanks brotherman!
OP will need 6mm spacers in order for the TL wheels to clear the BBK
Old Jan 18, 2017 | 09:24 AM
  #418
Old Jan 18, 2017 | 09:43 AM
  #419
ksu1018's Avatar
So than i will need 6mm spacers to make the wheels clear my front rotors? Where is a good place to purchase some? Also, would i need the spacers for the rear?
Old Jan 18, 2017 | 09:45 AM
  #420
Did you read the posts we linked..
Old Jan 18, 2017 | 09:50 AM
  #421
think about it....
the only thing preventing the wheels from clearing is the BBK.
Do you have BBK in the rear?
you can even measure how much of a spacer you need, by stacking washers on the hub until the wheel clears the caliper...then measure the stack of washers. pull them off and replace with a spacer.
some one has already done this for you and came up with 6mm.
Google 6mm spacer.
Old Jan 18, 2017 | 11:02 AM
  #422
ksu1018's Avatar
my rear doesn't have the big calipers like the front. Where is a good place to purchase spacers?
Old Jan 18, 2017 | 11:28 AM
  #423
^ you can google where to buy 6mm spacers...
Old Jan 18, 2017 | 01:16 PM
  #424
projektvertx's Avatar
Hit the nail on the head boys! Merged this with the wheel sticky in this subforum.
Old Jan 20, 2017 | 04:38 PM
  #425
teh CL's Avatar
Old Jan 26, 2017 | 04:47 AM
  #426
KB1_007's Avatar
9th Gear
Legend KB1 H&R and ADR 19x8.5 ET15 with 225/40/19. The tail is raised some 5mm with a rubber under spring to more balanced looks and avoiding scratching on rear tires.
Old Jan 30, 2017 | 12:44 PM
  #427
Ratheruneeq's Avatar
Nice setup!^ are those tires stretched?
Are there any photos or is anyone running those factory option Diamond cut TL 4g wheels on the Kb1? I'd love to see what they look like....
Old Feb 21, 2017 | 07:36 PM
  #428
davidevo16v's Avatar
3rd Gear
BMW/Ronal Z4 wheels
Have both cars out on a beautiful day
19 x 8 & 9
225/35/19 & 255/30/19
Old Apr 26, 2017 | 08:18 AM
  #429
Lowpass's Avatar
New wheels. Dezent TX 18x8 ET45 with Goodyear Eagle F1 Assymetric 3. 235/45-18.
Nothing special, I wanted to keep the OEM-look but a little bit bigger.
OEM 17x8" wheels will be used for wintertires.
Old May 13, 2017 | 03:08 PM
  #430
Dj Mixin's Avatar
Wow
Originally Posted by rondog
Some from the RJ gallery:
19" RonJon Vega:
20" RonJon Harrows (Wh1t3r0b's car posted above):
19" RonJon Legends:
WOW! Absolutely beautiful.
Old May 15, 2017 | 11:08 PM
  #431
Maintenanceman's Avatar
Thumbs up
Hi fellow Finlander
Old May 15, 2017 | 11:10 PM
  #432
Old photo, still have these but now powder coated due the poor quality of the original clear coat, will update the photo soon...
File Type: jpg
Old May 26, 2017 | 10:07 PM
  #433
fuzzysig's Avatar
2016 oem rlx 19x8 245/45/19 tires
got them brand new in boxes from local acura dealer
so far only mounted one
had to do some customizing and cutting and drilling with 15mm spacers
Old Jun 1, 2017 | 06:32 PM
  #434
deepa1600's Avatar
Hi all, i was looking to buy the wheels below which are 20'' x 8.5" with ET 38 along with 245-35-20 or 255-35-20 tires. My question is would they rub if i have passengers in back. 1010 tires confirmed that they clear front calipers. How is ride quality with 20's?
verde Saga Satin Black 20x8.5, 5/120 (Offset 38) Wheel | 1010Tires.com Online Wheel and Tire Store
Old Jun 1, 2017 | 06:36 PM
  #435
deepa1600's Avatar
Originally Posted by SVTruong
Nothing special on the build list.
05 RL A-Spec
- All stock engine/performance
- H&R Springs (Cut)
- 20" Niche Targa wheels
- 255/35/20 rubber
- Lip guard
- Sunroof Visor (I may remove this)
More photos to come
Do they rub?
Old Jul 6, 2017 | 03:03 PM
  #436
Lu Diamond's Avatar
Lu Diam
19s tsw brooklands
<img src="https://image.ibb.co/jAnqUa/20170610...7207206152.jpg" alt="20170610 180011 1497207206152" border="0" />
<img src="https://image.ibb.co/gc5Kpa/20170610...7207205686.jpg" alt="20170610 180025 1497207205686" border="0" />
<img src="https://image.ibb.co/iNzJhv/20170610...7207205335.jpg" alt="20170610 180059 1497207205335" border="0" />
Old Jul 6, 2017 | 03:24 PM
  #437
Lu Diamond's Avatar
Lu Diam
19s TSW Brooklands
Old Jul 11, 2017 | 08:05 PM
  #438
deepa1600's Avatar
So, finally i git her new shoes:
Advanti Racing N727 ET:30 with Yokohama Avid Envigor A/S 245-40-19
Old Jul 15, 2017 | 08:53 AM
  #439
teh CL's Avatar
Looks good.. Where in Ontario are you?
Old Jul 16, 2017 | 04:19 PM
  #440
deepa1600's Avatar
I am in Kitchener.
