Show us your aftermarket and OEM wheels on your RL
#401
Should be ( | )ss, no?
#403
Those are really clean!
BTW, you can embed pictures directly to the site now. You don't have to attach them to avoid hosting them externally.
tla11384 (04-03-2016)
#404
The following 2 users liked this post by tla11384:
kcjohnnyboy (04-05-2016),
Ratheruneeq (01-30-2017)
The following 2 users liked this post by 1CLNRL:
Lowpass (11-23-2018),
#408
#412
MDX, ZDX, 4G TL, 3G TL (redrilled), and RLX have all been done. Find the "search this forum" toolbar just above and to the right of the threads when you are in the wheels section.
Also, instead of talking about them again in a new thread, I am going to merge this thread with the aftermarket wheels thread.
#413
Also, I stuck the thread so it will remain at the top of the forum.
projektvertx (01-04-2017)
#414
quick google search found this: https://acurazine.com/forums/2g-rl-t...ke-fit-803851/
https://www.google.com/search?q=09+a...hrome&ie=UTF-8
The following 3 users liked this post by thoiboi:
#418
So than i will need 6mm spacers to make the wheels clear my front rotors? Where is a good place to purchase some? Also, would i need the spacers for the rear?
#420
Did you read the posts we linked..
#421
the only thing preventing the wheels from clearing is the BBK.
Do you have BBK in the rear?
you can even measure how much of a spacer you need, by stacking washers on the hub until the wheel clears the caliper...then measure the stack of washers. pull them off and replace with a spacer.
some one has already done this for you and came up with 6mm.
Google 6mm spacer.
teh CL (01-20-2017)
#424
Hit the nail on the head boys! Merged this with the wheel sticky in this subforum.
teh CL (01-20-2017)
#426
9th Gear
Legend KB1 H&R and ADR 19x8.5 ET15 with 225/40/19. The tail is raised some 5mm with a rubber under spring to more balanced looks and avoiding scratching on rear tires.
The following 2 users liked this post by KB1_007:
Maintenanceman (05-15-2017),
#429
2016 oem rlx 19x8 245/45/19 tires
got them brand new in boxes from local acura dealer
so far only mounted one
had to do some customizing and cutting and drilling with 15mm spacers
wilspainar (05-30-2017)
#434
Hi all, i was looking to buy the wheels below which are 20'' x 8.5" with ET 38 along with 245-35-20 or 255-35-20 tires. My question is would they rub if i have passengers in back. 1010 tires confirmed that they clear front calipers. How is ride quality with 20's?
verde Saga Satin Black 20x8.5, 5/120 (Offset 38) Wheel | 1010Tires.com Online Wheel and Tire Store
#435
#436
Lu Diam
19s tsw brooklands
<img src="https://image.ibb.co/jAnqUa/20170610...7207206152.jpg" alt="20170610 180011 1497207206152" border="0" />
<img src="https://image.ibb.co/gc5Kpa/20170610...7207205686.jpg" alt="20170610 180025 1497207205686" border="0" />
<img src="https://image.ibb.co/iNzJhv/20170610...7207205335.jpg" alt="20170610 180059 1497207205335" border="0" />
