PO847 - 3rd Clutch Transmission Fluid Pressure Switch Circuit Short B
Yesterday while driving the Check Engine Light and drive letter "D" was flashing. I plugged in my code reader and P0847 came up. I saw an older post from 2010 about this issue. Does anyone know where the sensor is located? I am going to order a sensor on RockAuto today. Does anyone know if this is the correct sensor? More Information for PA CARGO 98927B
awesome that you found that!
it doesnt say to take the wheel off, so it may be in a different position than the TL's. but still in the same general area!
good luck!
I believe this one is on the front of the trans wich is facing the front of the vehicle. Take the under tray off, drivers side, should be a few inches up facing the back of the bumper. Pretty easy to get to. Switches are about $25 from company I can't remember name of but can be found many places online.
good luck!
I took wheel off and can’t see it so that’s a negative friends
