NJ DMV inspection (new law)
this is goes out to all the people living in NJ with tints on the front window (ignore if this is not you)
we all know that tints on front window and NJ law dont mix, just like oil and vinegar.
as of august 1st 2010, state of NJ motor vehicle commission has made changes in their inspection stations.
the new headline reads: [IMG]file:///C:/Users/FRED%7E1.MAH/AppData/Local/Temp/1/moz-screenshot.png[/IMG][IMG]file:///C:/Users/FRED%7E1.MAH/AppData/Local/Temp/1/moz-screenshot-1.png[/IMG]
Changes effective August 1, 2010: emissions check only
Does this mean they are not checking for tints or anything else that is not emission related? So if i take my car with 20% in the front window, will it fail?! or do they not check for that anymore?!..?
here is the link to the NJ MVC website
http://www.state.nj.us/mvc/Inspectio...erstanding.htm
cheers
cheers
I believe, if your car is 5 years or older, you need an emissions inspections every two years. They are no longer doing a visual or mechanical check on anything other than your emissions.
cheers
cheers
I took my car for inspection this month. PASSED. What they don't bother with anymore is the safety aspect of the inspection. They only scan your car for codes aka emissions.
Lowered, exhaust, tints, intake ect.. I got in and out within 5 mins passed.
A lot of you guys here are not so bright. Check engine light will fail you, it's part of emissions.. When they scan your car "OBD II Scan for emissions" and you have a light on you will fail.. That's what emissions is, not just your muffler hahaha.
Yes, it's part of emissions. You will fail if the light is on.
They will elimate the SAFETY part of the inspection... Which is your wipers, windshield, headlights and taillighs condition and operation, window operation, tire wear, front suspension play, brake performance, dummy warning lights excluding CEL ect.
I work for the inspection station in NJ. YES WE ARE still checking check engine lights. The light is check using the key on engine off test to make sure it works, then it is checked again with the car running. Also, It is still a NJ state law about not having tint on the two front door windows, or below the AS-1 line on the windshield. I don't even want to get started on the junk thats come in to my place of employment since the Gov. put the new rules in place. Remember, just because we cant fail it on Passenger vehicles anymore doesnt mean a cop can't ticket you for it. I know I don't want to be behind a car that doesnt having working brake lights, or in front of one that has no brakes. Commercial vehicles will still get a full safety check. Don't mean to sound grouchy, but I just want everyone in NJ to be as safe as possible and this new law is crap.
This is now going to save the state of New Jersey $17 million dollars a year, which can now be used for other areas that need improvement. Also, of the 2 million cars inspected by the state annually, only 6% failed for mechanical issues such as brakes, suspension, steering and tires.
I am totally for this new procedure and hopefully the extra money will be used elsewhere where needed.
Yes the cost to do 4 tires, overhaul brakes, ball joints, tie-rods ect ect typical shit NJ cars in this area go through people didnt have the money. The roads would be safer with the LAW before but I am all for it now since Most that sold you the things needed where bad calls. How many times did DMV send us failed cars for brake failures and all it needed was a rear brake drum adjustment.. Plenty of life on the shoes but they were out of adjustment. Failed wipers and brakes it was crazy, they werent legit failures. Dont get me started on tires... the damn things are at the T-bars the state still passes it unless theres steal showing, but for drums to be slightly out of adjustment is a failure...
I took advantage and got my car inspected for free, and passed just fine.
And on the flip side I was an automotive technican for a reputable shop which did private repair/inspection as well. I would have to do to safety check list to each vehicle and pay close attention to those that are getting inspected. I knew what to check and what would fail or pass within state specs. Thing is nobody wants to hear "Your tires needs replacing, its XXXX amount" "Your brakes are metal on metal thats going to be pads and rotors to start and its XXXX amount"
so i am now interested in tinting my car (including the 2 front windows) because of this tread....who all has had issues with cops and your tinted windows?? would you recommend getting tints or not because of the treat of cops giving your trouble? i have heard that a cop could make you take the tint off the windows on the spot on the side of the road before you can leave and also give you a ticket...is that true or bs??
who all has had tickets regarding your tints in NJ??
I had about 2 tickets from cops that don't care about my FOP,PBA and such but I get off as warnings all the other times which I can say about 6-8. I do get pulled over A LOT for them.
I don't get it because cops hate tints because they "feel unsafe" when walking up to the car, but they LOVE to pull people over for tints.
didn't even know about this new law... i guess it is a double edged sword... for most of us on this board who are car enthusiasts and keep up with our car's maintenance, then safety really isn't an issue as our biggest problem is wanting to have tints on the front doors...
but i can understand from the perspective of truly unsafe cars that are out on the road which shouldn't be...
They have them in almost every town in NJ. They do local check points, if your due for inspection they will inspect your vehicle right there and then, if your over due you will get a ticket for failure to inspect which is 150-200 range and again, will inspect right on the spot.
so i dont think that we'll ever get a petition going that can jeopardize the safety of cops.
there is only one way i know of to get out of tickets for tints. MEDICAL EXCUSE!!
i attached the file that you need filled out by a doctor. My cousin in Maryland has this note from his optometrist that says he suffers from photophobia, he says hes been pulled over and asked about the tints, but showed the note and he wasnt ticketed.
That being said there are limits from a safety standpoint. 5% tint is just not safe at night, especially on a rainy one. You can't see properly around the car. So I get that. It would be nice if they could at least LAX the law to 35%. I don't see how that is not reasonable. If not, how about at LEAST 50%? How does that present a "safety issue"? But they say nope, NO TINT. Give me a break.
If I REALLY was a criminal, I wouldn't be in a regular 4 door sedan with 35% tint. Or a flashy car that attracts attention. That makes no sense. I would be in a low key SUV (where tinted windows are not a problem) or a panel van. Oh SURE! You can see into those cars REAL well can't you? Makes no sense. Shoots down their entire argument of "safety".
When I get pulled over at night they use those heavy duty spot lights. Trust me, that thing is like an X-ray, lol. They can see through my car just fine with 30% tint. I turn on my interior lights too, they appreciate this and they will let you slide about tint if you are nice. They don't even mention it.
But actually my car is registered out of state where the limit IS 35% (thank you!). This is my loophole. Because it's not about safety, it's about money for them. Zero tickets ever.
SidhuSaaB
May 30, 2020 12:40 AM
Abe_Froman
Sep 16, 2015 01:27 PM
all you need to do is pass emissions
