Blue Trans Bolt Heads, but what is case design?
Old May 20, 2010 | 07:38 AM
LincolnTLS's Avatar
Got a quick question (and yes, I searched) about the Acura rebuilt transmissions. I understand that if your bolt heads are blue, you've had an Acura rebuild, but how do you know if you have the '05+ case? Is there a way to differentiate the older with the '05 redesign? BTW, have an '03 TL-S purchased in '07, transmission has the blue bolts, so I have no idea which case I'm running.
Old May 20, 2010 | 07:44 AM
MurdaZ's Avatar
as far as i know they reused the same bell housing, just internals are different..........did that with mine.......also didnt know about the blue bolt, whered u hear that from?
Old May 20, 2010 | 09:35 AM
LincolnTLS's Avatar
I've read it in a few spots; I think it's in the tranny failure thread somewhere. 01tl4tl has stated it. Here's a thread, post #2: https://acurazine.com/forums/2g-tl-1999-2003-98/does-2003-tl-have-tranny-issues-767189/
Old May 20, 2010 | 10:49 AM
01tl4tl's Avatar
its true- acura warranty rebuilts have blue painted bolt heads'
look at end of trans from underneath- the main bolts that go thru trans-blue
the new case design in 05 can be determined by looking at the top of the trans at filler hole
If you have a large bolt marked ATF on it- thats the new case
If you have an external oil jet kit in that hole instead, you have a pre 05 change trans
or call acura 1-800-382-2238 x5 register as owner, need car vin- they can tell you when trans was done
Old May 20, 2010 | 12:25 PM
LincolnTLS's Avatar
Looks like I have the '05+. Thanks for the info; as always more than helpful 01tl4tl.
Old May 20, 2010 | 02:19 PM
01tl4tl's Avatar
I live to serve~
Old May 20, 2010 | 02:21 PM
01tl4tl's Avatar
everyone should register with the 800- thats `acura care`- it sends out recall notices to last known owner address,,that wont be you unless you tell them
can also ck for any open recalls and explain any extended warranty like srs
Yikes
May 3, 2021 04:29 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
justin7779
Dec 25, 2015 10:33 PM
EvilVirus
Aug 31, 2015 05:24 PM
