Blue Trans Bolt Heads, but what is case design?
Got a quick question (and yes, I searched) about the Acura rebuilt transmissions. I understand that if your bolt heads are blue, you've had an Acura rebuild, but how do you know if you have the '05+ case? Is there a way to differentiate the older with the '05 redesign? BTW, have an '03 TL-S purchased in '07, transmission has the blue bolts, so I have no idea which case I'm running.
I've read it in a few spots; I think it's in the tranny failure thread somewhere. 01tl4tl has stated it. Here's a thread, post #2: https://acurazine.com/forums/2g-tl-1999-2003-98/does-2003-tl-have-tranny-issues-767189/
its true- acura warranty rebuilts have blue painted bolt heads'
look at end of trans from underneath- the main bolts that go thru trans-blue
the new case design in 05 can be determined by looking at the top of the trans at filler hole
If you have a large bolt marked ATF on it- thats the new case
If you have an external oil jet kit in that hole instead, you have a pre 05 change trans
or call acura 1-800-382-2238 x5 register as owner, need car vin- they can tell you when trans was done
I live to serve~
everyone should register with the 800- thats `acura care`- it sends out recall notices to last known owner address,,that wont be you unless you tell them
can also ck for any open recalls and explain any extended warranty like srs
cycdaniel
12-17-2019 10:58 AM
justin7779
12-25-2015 10:33 PM
