Side mirror lights
Old 03-22-2021, 11:06 PM
nycez's Avatar
Side mirror lights
Not a big issue but when I used to unlock/walk next to my car the lights on the side mirrors would come on. Now they don’t turn on at all. Any idea on how to toggle this feature.
Old 03-23-2021, 11:00 AM
Mikey319's Avatar
They are probably honestly broken and need to be replaced. Happened to mine too. They put new lights in and so far they are working.
RENARELLO (04-16-2021)
Old 03-23-2021, 11:22 AM
DLM1213's Avatar
Same here.....I will see about getting them replaced on my first service visit.
Old 03-23-2021, 11:27 AM
ELIN's Avatar
Received 1,246 Likes on 904 Posts
I would check with the dealer...unless it coincided somehow with an OTA update...
Old 03-23-2021, 11:33 AM
Mikey319's Avatar
it’s probably not an update. They didn’t mention one when they fixed mine last week, and told me they had to replace the lights themselves.
ELIN (03-23-2021)
Old 03-23-2021, 12:52 PM
nycez's Avatar
This legit just got this car last month lol 😂 can’t be broken. I’ll have them look at it my next service day.
Old 03-23-2021, 12:54 PM
ELIN's Avatar
How often do you fold your mirrors? Never?
Old 03-23-2021, 07:39 PM
Mikey319's Avatar
have you read my thread? 🥴 it’s def possible LOL. Hopefully it’s an easy fix
Old 03-23-2021, 10:20 PM
nycez's Avatar
yeah... I don’t doubt it... lol 😂 I’ll look into it during my next service check. But thanks.
also, wondering if we can make it brighter! Lol
probably every time i park if I remember too. But usually just the street side. 🤔 🤔
Old 03-23-2021, 11:11 PM
Mikey319's Avatar
not that I’m aware of sadly. I wish they stayed on while reversing to give the camera light when it’s dark out for the mirror cameras.
nycez (03-24-2021)
Old 03-24-2021, 08:00 AM
ELIN's Avatar
So both lights are out? Too much coincidence not to be software-related.
Old 03-25-2021, 01:12 PM
BEAR-AvHistory's Avatar
Received 2,599 Likes on 1,581 Posts
Can you set your mirrors to fold when the car is locked?
Old 03-25-2021, 01:16 PM
Mikey319's Avatar
that's exactly what happened to mine. They both just randomly stopped working one night. I don't think it is software because I had the welcome lights installed and they would still go on and are essentially linked together.
Yes, it is in vehicle settings . There is also a button that can be pushed to fold them at any point.
Old 03-25-2021, 01:39 PM
CPR
CPR's Avatar
Mine work great, as advertised!
Old 03-25-2021, 01:47 PM
ELIN's Avatar
Only the Advance trim gets the "magic mirrors." nycez is stuck like me manually folding the mirrors...when we remember.
The following 2 users liked this post by ELIN:
BEAR-AvHistory (03-25-2021), Mikey319 (03-25-2021)
Old 03-25-2021, 03:03 PM
nycez's Avatar
yeah both lights its weird.
yeah I got ASpec model. So the folding mirrors is a manual labor for me hehe. But too ironic that both light just stopped working.
Old 04-06-2021, 07:14 AM
6th Gear
LaxBrah20's Avatar
Got an Aspec model last month and my driver side mirror light randomly stopped working over the past few days. The light will flicker at first, but doesn't turn on.
Old 04-06-2021, 07:48 AM
ELIN's Avatar
Probably won't be long before a TSB about this shows up.
Hopefully we all knew what we were getting into buying into the first MY of a new gen.
Mikey319 (04-07-2021)
Old 04-06-2021, 08:43 AM
leomio85's Avatar
You’ve run out your trial subscription for active side mirror lights.
=P
The following 4 users liked this post by leomio85:
Chix (04-19-2021), ELIN (04-06-2021), LaxBrah20 (04-06-2021), Mikey319 (04-07-2021)
Old 04-07-2021, 12:50 AM
Mikey319's Avatar
the ASpec loaner that I was in had 700 miles on it and they weren’t working at all LOL
Old 04-17-2021, 07:19 AM
Chix's Avatar
Mine went out.
Old 04-17-2021, 09:05 PM
MIKEYDRED's Avatar
Originally Posted by Chix
Mine went out.
Our 2017 passenger puddle lamp.went out about a year ago and its not covered under warranty. Looks like Acura may have selected a bad batch of bulbs or bad supplier. I havnt had it replaced just yet, but bulb is $90 apparently.
Old 04-22-2021, 12:43 AM
mapleloaf's Avatar
I have had my Puddle Lights on the mirrors on my 2018 TLX ASpec Elite replaced on 3 occasions, under warranty, in just under three years, which is the only issue I have had with the car. This most recent time, the service tech noted that the light is seated in such a way that water collects around the base of the bulb and likely shorts it out. To address this apparent design flaw, they put some grease in that area to protect the bulb. I am a frequent car washer, so there is likely a correlation between light issues and washing, given this issue. I will now avoid spraying the front of the mirror directly to also help prevent a reoccurence. The bulbs are LEDS and shouldn't be the problem.
Old 07-21-2021, 09:55 PM
Ghostof TypeS Past's Avatar
Driver door puddle light under mirror on Type S no longer works. 6 days of ownership.
Old 07-22-2021, 10:12 AM
jpsi2002's Avatar
Both of mine were out on my type S from day one
The following 2 users liked this post by jpsi2002:
Furnace (07-25-2021), Ghostof TypeS Past (07-22-2021)
Old 07-23-2021, 02:00 PM
7th Gear
ByteCrawler's Avatar
I'm a victim as well. My driver side light has started to flicker. Right after I brought it in for an oil change of course... 2021 TLX A-Spec
Ghostof TypeS Past (07-24-2021)
Old 07-25-2021, 01:20 AM
863aspec's Avatar
TLX A Spec AWD
I too recently got my TLX A SPEC in the middle of June, a few days later it was at the dealer because of these same lights. Two days out both sides were out again, took it back to the dealer and it will be four weeks this upcoming Monday with a loaner. Apparently lights/mirrors were ordered from Japan. Putting miles on the loaner!
Ghostof TypeS Past (07-25-2021)
Old 07-25-2021, 02:11 AM
The Service said it will be a few weeks at least, I had the service agent call parts, will be here Monday. Service manager said they’d have to replace the entire mirror.
I asked if I could buy the carbon fiber inesrts for the doors since they’re already taking the panel off, was told the panel will not be fully removed for this fix. Only top corner will be pulled back to make room for connecting the harness…
Old 07-25-2021, 11:02 AM
7th Gear
Thanks for the info but this is exactly what I was afraid of. Last thing I want to do is go back and forth for temporary fixes. Considering it’s a puddle light it’s not the biggest deal that it’s not working. However, considered the price paid for the car it should be remedied with a permanent fix.
Has anyone gotten a permanent fix to this issue from the dealer yet?
Old 07-26-2021, 06:59 PM
ApexBlue21’'s Avatar
If you do a search, I also made a post about the lights…specifically how do you actually replace them. No one really answered the question fully but I am guessing somehow the mirror glass comes off….My dealer ordered the lights….SIX WEEKS AGO….still on back order. But at this point, I’m going to wait because my guess is, if we are all having this problem, and many have posted that the “fix” only lasted a few days….then I’m going to wait and not be a test subject. My only gripe about the car, otherwise it’s perfect!
Old 08-04-2021, 11:54 AM
3rd Gear
Isaack6's Avatar
I know it’s only been a week and some change. Any updates for you? Currently my driver side puddle light is out (21 tlx)
Old 08-16-2021, 03:59 PM
3rd Gear
Isaack6's Avatar
My driver side went out as well.. Any luck with the repairs?
Old 08-18-2021, 11:46 AM
jeeper31's Avatar
The passenger side was flickering and the deriver side didn't work at all on my new ASpec. Brought into the dealer and they are ordering new lights. No happy with Acura service at all.
I know this is not the place but my rear passenger door didn't sit flush with the rear fender. Noticed this when I got the car home right after delivery. Service writer said it can't be fixed.
Old 08-18-2021, 01:52 PM
ELIN's Avatar
That stinks.
You couldn't even blame that on a first MY of a new gen problem. Fit and finish impacts any given year. This is one of the reasons I prefer not to take delivery of a car at night.
Old 08-18-2021, 03:20 PM
Steven Bell's Avatar
Received 6,470 Likes on 5,162 Posts
Just had my driver's side puddle lights fixed and replaced under warranty at the dealership.
Old 08-18-2021, 03:33 PM
3rd Gear
Isaack6's Avatar
was it quick and easy?
Old 08-18-2021, 06:57 PM
6G TLX-S
Edward'TLS's Avatar
Received 1,146 Likes on 818 Posts
Will it help if your adjust the height of the rubber bumpers located at the inside of the door ?
Old 08-21-2021, 10:44 PM
AZ Community Team
KrylonBlue's Avatar
I remember the hood on my 2019 TLX ASPEC wasn’t flush on one side so the service manager adjusted that to fix the issue.
Old 09-12-2021, 01:49 PM
KB1Spec's Avatar
So my driver side puddle light when out YA!!!!!
The culprit: High Pressure Washer
I suspected that using high pressure washer directly onto the mirror might be the cause of having water seeping into the some openings.
I never had any issues while washing my car with a regular garden hose nozzle.
So far my passenger side and my welcoming lights on the side skirt are working. When I call the dealer this week, I will bring it up to them
as to what causes the puddle light not working and I'll bring this up to my friend at Honda HQ who is the engineer there.
Old 09-12-2021, 01:57 PM
CheeseyPoofs McNut's Avatar
Received 1,405 Likes on 636 Posts
My driver side puddle light went out after the first car wash - the passenger side still works. I'm going to wait a bit before talking it in to see if the passenger side goes out as I suspect it will.
Quick Reply: Side mirror lights
