Transmission Replacement
Looking at buying an 03 TL with a bad transmission. I've found a few replacements around and was wondering when replacing the transmission is it necessary to take the car to the dealer for re-programming/relearning?
Also, what is the typical cost to just have the transmission rebuilt?
Thanks in advance.
Thanks in advance.
Latent car nut
Received 2,005 Likes
Thanks in advance.
Thanks in advance.
Regarding the transmission fix, you have a couple of options:
- Have the existing tranny rebuilt; as I understand it, there are several overhaul kits out there which range from about as robust as the factory setup (i.e. not robust at all), to reasonably robust.
- Buy an operational transmission from another 2G TL (or CL if I am not mistaken).
- Buy an 2006-2007 Accord V6 (aka. AV6) transmission; this transmission is a plug in replacement for the 2G TL unit, but internally upgraded and much more robust.
sonicc (03-07-2018)
https://acurazine.com/forums/second-...n-swap-905115/
https://www.google.com/search?q=site...hrome&ie=UTF-8
The AV6 is a much better solution if you want to keep the car long term. Tried and true method
sonicc (03-07-2018)
Latent car nut
Fetching one from an Accord V6 model might actually cost less. Why? There were a heck of a lot more of them made than of the 2G TL. I've read on this board some folks have sourced low(ish) mileage used AV6 transmissions for as little as $500; buy it, slap in in, and go.
sonicc (03-07-2018)
I don't know why anyone would even consider another TL trans when the Accord/Odyssey option is plug and play, easier to find, usually cheaper and has no known issues. Saying "AV6 swap" scares people because they assume its all kinds of custom work and wiring when in fact, it's identical, literally plug and play. Here's a good analogy. You have a sexy set of identical twins in front of you and can only choose to take one home, one has AIDS and the other doesn't, which would you choose?
sonicc (03-07-2018)
I've been reading about the AV6 swap, but I am not planning on keeping the car for very long so to me it doesn't seem worth it. If I was keeping the car, I would most likely go with a manual 6 swap from a CL.
I like to live my life on the edge
Latent car nut
The difference is the AV6 swap is easy to do, pull the old tranny, put in the new one. The 6MT swap is a beast and can cost a lot of money.
I'd urge you to look into the AV6 as well..
FWIW" I recently took a friends 2003 TLS to a Quality local transmission shop, and requested an estimate to repair the failing transmission. After requesting an estimate to install an AV6 transmission, the shop advised, they would not recommend, nor warranty the AV6 swap! I accepted their reluctance to do the swap, and presented them with the detailed instructions, and positive results, as listed on this forum. THEY WERE NOT IMPRESSED, nor persuaded, that the swap was a good idea, nor would they do it. The shop INSISTED, they were very familiar with the 2G TL failure issues, and could rebuild the 2G transmission with redesigned components, which would make it considerably more durable than the original!!! Cost of the rebuild, of course depends on the condition of the case, and all internal parts, with most rebuilds averaging $3200.00, according to them. My experience is, that even if you paid top dollar for a low mileage AV6 transmission, around $900.00, and an additional $600.00 for installation, the end result, would be a far superior transmission, for less than Half The Cost, of a rebuild. Please note: the cost benefit of the AV6 is made, under the assumption that the Donor transmission is warrantied, of high quality, and serviceable! Should you, by chance, stumble on a bad AV6, which is a remote possibility, both your swap costs, and time involved would be increased.
You guys are killing me
While it makes sense if you're keeping the car to put in a better transmission, it is also more work compared to swapping in a working TL transmission. I know some of you are saying it's plug and play, but it's not...putting in a TL transmission is plug and play. Putting in AV6 transmission is plug - do some extra swapping - play
ehh it's the person that is buying your car after that will deal with that problem
we gave you the best solution, you're welcome to not take it
Why throw yourself under the bus? ITS IDENTICAL. Bring your Accord trans and drop it off as the replacement without even mentioning its from a different car, they'll never know. Advise them to use all of the accessories from the old one or, just remove all of the ones from the Accord trans so they HAVE to without you saying anything??? Its not difficult, step outside of the box a bit. Besides, if the shop needs all of this forum proof and a diy to get the swap done, definitely take your business elsewhere anyway.
True, I think I spent three hours swapping parts and that's mostly due to the gasket for the passage body being extremely stuck on requiring a lot of clean up, and I moved over absolutely every bracket bolted to the tranny because they all have clips for the wiring harness that differ (even the dipstick tube).
Ahmed Nomaw
07-20-2017 04:06 PM
skyeflye
11-30-2001 01:41 PM
