Accessory drivebelt tensioner removal
Old 12-02-2014, 07:47 PM
charmer37's Avatar
Hello, I own a 1999 Acura tl and I would like to know if there are any "diy's" or instructions on how to remove the accessory drivebelt tensioner? Thank's...
Old 12-02-2014, 08:04 PM
Skirmich's Avatar
Received 1,016 Likes on 867 Posts
Remove the belt > Remove the 3 bolts holding the tensioner to block > done!
It's relatively easy to do it but the space is tight! Don't be afraid to get into it, it's pretty simple.
Old 12-03-2014, 01:04 AM
Unregistered Member
Karanx7's Avatar
The pulley bolt is clockwise open, if you need to open that. Also make sure to open the bolt going through the middle of the tensioner (not the pulley bolt).
Old 12-03-2014, 06:04 AM
Received 16,260 Likes on 11,971 Posts
dont make the same noob mistake I made!!!
use a wrench. lol
Old 12-03-2014, 10:49 AM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
Claaaaaaasic~
look in the DIY section, everything we know how to do is there,,well most of it~
link is at bottom of main page after sign in - look for Off Topic as section name
Old 12-04-2014, 07:40 PM
charmer37's Avatar
Thanks guy's.
Old 12-05-2014, 03:54 PM
acutee's Avatar
It is not hard to replace tensioner, but problem is the space to remove the middle bolt. You will have to do it through the wheel well. Don't remove the belt first. First is to try if you have a way to remove those 3 bolts, once you have the plan in mind, then remove the belt and proceed. That way you don't have to put the belt back and drive to the store to get tools or whatever you need if that is your only car.
Old 12-08-2014, 04:10 PM
shamal's Avatar
Originally Posted by 01tl4tl
Claaaaaaasic~
This has me confused, I usually go to the TL section and then correct generation. I could not find a thread on this issue in Off Topic section? I'm guessing there is a thread I've not found ?
Old 12-09-2014, 07:50 AM
3.2TLc's Avatar
^^^ Spend some time learning how to utilize the site's "Search" feature. It's all in here !!!
Old 12-09-2014, 02:47 PM
uʍop ǝpısdn ǝdʎʇ uɐɔ ı
thelastaspec's Avatar
https://acurazine.com/forums/second-...thread-706083/
shamal (12-13-2014)
Old 12-13-2014, 04:45 PM
shamal's Avatar
This is the thread I was talking about with the pics gone, from the New official page, it's that image shack site, I'm gonna post some so others will have a better pictorial experience
https://acurazine.com/forums/second-...ogress-643700/
3.2TLc (12-13-2014)
Old 12-13-2014, 05:53 PM
3.2TLc's Avatar
Very thoughtful.....thanks for taking the effort and time to help others.
Unfortunately, as our cars are getting older.....so is the hosting for pics within the "DIY"s.
iRaw
ILX Photograph Gallery
30
08-05-2016 04:41 PM
Euro4gen
12-12-2015 03:14 AM
AJRozsa
10-05-2015 07:50 PM
Quick Reply: Accessory drivebelt tensioner removal
