RL JDM Headlights
RL JDM Headlights
I've noticed a few RL owners have JDM Headlights. Now I've seen some for sale and I am in the process of getting a set, but they seem to be missing the oem hid setup as well as the motor.
I want to know from the people who know or that have already purchased, if they came with or without, and whether you were able to utilize the setup from your USDM/OEM lights?
That's not right. The only differences between JDM and USDM are the clear corners and the passenger/driver cut-off and calibration are switched. The motor and HID are still there.
ichi d (02-23-2014)
![RL JDM Headlights-jdm-headlight2.jpg](https://acurazine.com/forums/attachments/2g-rl-2005-2012-76/19295d1464117517t-rl-jdm-headlights-jdm-headlight2.jpg)
The seller chopped that piece and sold the other parts. Many people have swapped here, and no one has ever reported adding parts. JDM comes with HID and AFS motors.
StReCh4130 (02-17-2014)
@oo7spy
What do you mean with "...passenger/driver cut-off and calibration are switched"
Regards
Regards
AM Flakes still Drippin'
^ The driver side cutoff is lower as to not blind oncoming traffic. Since the roads and driver positions are opposite in Japan(right hand drive), the headlight configurations are opposite as well.
NExt time when I come to U.S.A. I think it's better to remove my lights and bring with me...
Everybody wants what they do not have.
I like orange sidemarkers
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
Türk (02-17-2014)
The following 3 users liked this post by oo7spy:
Türk (02-17-2014)
If you give one set of USDM headlights, 1 set of Acura grill, 1 ebony Acura airbag, 4 Acura center hub caps, one iPhone 5s, one Sony PS4, one 4K Tv; I may think to swap
I'm the salesman...
HEAVY_RL (02-18-2014)
Turk, IIUC, the cutoff comes from a shield behind the lens. The headlights are aimed the same, but the outside shield is different.
The following 3 users liked this post by M T L T L:
Former Sponsor
Mine came directly from Japan, rather than through a third party vendor. All I received was the empty headlight shells. You'd need to transfer all the working components from your old headlights to the new ones.
1) Rubber grommets around DRL area.
2) Turn signal bulbs/sockets.
3) Parking light bulb/sockets.
4) Cover for the AFS motor, some headlights may come with this.
5) HID ballasts, ignitors and HID bulbs.
6) Low beam projector cover.
7) Rubber gasket around the HID ballast.
As others have mentioned, JDM headlights or EDM headlights will have cut off made for RHD cars where as USDM headlights have cut off made for LHD cars.
JDM headlights cut off
''''''''''''''''''''''''\________
USDM lights cut off
_________/'''''''''''''''''''''''''''
You can swap the JDM cut off shields within the projectors with the USDM ones, requires opening the headlights though.
Here is a link with better pictures.
https://acurazine.com/forums/showpos...8&postcount=55
USDM lights cut off
The following 4 users liked this post by JnC:
JnC (03-26-2014)
USDM lights cut off
USDM lights cut off
My lights are all equipped and traffic direction is same as USA.
I will sell them to StReCh4130
StReCh4130 (02-18-2014)
Have any link or anything where we can order the same??
USDM lights cut off
USDM lights cut off
USDM lights cut off
USDM lights cut off
Now, will I be able to use my AFS motor on the new lights, and is it a plug/play kind of thing?
The following 2 users liked this post by JnC:
oo7spy (02-19-2014),
StReCh4130 (02-21-2014)
To each his own but the bulb is the same, I don't like a sharp cut-off and the beautiful hue is not only BS but can easily be fixed with alcohol.
That set you found would surely work with some extensive rebuilding, but they shouldn't be even a 1/4 of the price. You will likely have to crack them open too.
HEAVY_RL (02-21-2014)
Mines came as a whole unit and it was plug and play.
UPDATE: So, I installed the headlights this weekend and ran into an issue. The USDM directional/ turn signal light and bulb dont fit in the designated opening on the JDM headlight.
Anyone else with these headlights encountered this issue? Anyone know what light socket and bulb combination I can use?
StReCh4130 (03-25-2014)
