K-002: Window control/window won't roll down/window reset procedure
Old 02-01-2016, 11:21 AM
  #201
oo7spy's Avatar
Received 7,244 Likes on 4,855 Posts
You have to do the reset at the affected doors, not from the master panel.
Old 03-18-2016, 09:43 PM
  #202
DJ 57's Avatar
rear windows will not go down
some time last week i killed my battery and now i can not lower my rear windows from driver control unit. They will go down if operated from window switch next to windows. this happened once before when my old battery was beyond replacement but once i replaced it worked fine. any help thanks
Old 03-18-2016, 10:01 PM
  #203
NathanJax's Avatar
Did you try the reset?
Press and hold the button to roll each problem window all the way down, then hold for 5 seconds after the window is down. Let go of the button. Press and hold the button to put the window the whole way up then hold for 5 seconds after the window is up. your windows should now be reset and can be controlled from the drivers window controls.
The following 3 users liked this post by NathanJax:
DJ 57 (03-18-2016), projektvertx (03-19-2016), teh CL (03-18-2016)
Old 03-18-2016, 10:37 PM
  #204
DJ 57's Avatar
thank you so much shit was driving me crazy !!
Old 03-19-2016, 10:12 AM
  #205
oo7spy's Avatar
Holy hell that was easily the issue with the least attempted searches. I merged 22 threads. Please do a search before starting a new thread.
Old 04-15-2016, 11:08 PM
  #206
idatarbell's Avatar
I didn't quite hold with all of the answers, because some answers contained variations on my situation. The right answer was among those above but I wasn't sure. I got the manual for my 2004 Acura TL and read everything about keys. I wasn't sure how 4 of my windows got rolled down at the same time and my sunroof rolled back. I recalled solving the mystery once before years back, but couldn't remember how. Having read the manual, I deduced I had pushed the open door button twice while approaching the car. I drove 30 miles home with those windows down knowing I'd have to solve this myself on a Friday night. The correct answer is I must have pushed the open button a second time and held it to cause the 4 partially rolled down windows and open sunroof. I was slightly afraid someone had hacked my car. After reading the manual I walked to the car, put the key into the car door, turned the key counter-clockwise in the lock, held it there for 5 seconds, all the windows rolled up and the sunroof closed perfectly. Thanks for your help everyone!
Old 04-21-2016, 07:53 AM
  #207
swanscn's Avatar
Worked like a champ for me
I noticed some time ago that my rear windows not working, I always planned on looking into it and never did. Yesterday, I decided to see if there were Forums for Acura like there are for Lexus. I found this site and just started looking at the post titles, I came across this post tried what was documented and it worked great. After reading through I determined it was due to replacing the battery a few months back. So thanks everyone you saved me probably hours looking at all the physical side of things that would not have lead me anywhere. BTW, I have seen some complaints about battery life and this was my 1st battery on a 08 RL with 100k miles or so, I do not think this is bad for a PA car and he had some bad winters over the previous years.
Old 07-06-2016, 12:16 AM
  #208
wields's Avatar
My rear passenger window won't go down using either the master unit or the rear. What can be the problem? I believe my regulator still work because I hear a clicking noise when I try to putting down the window.
Old 07-06-2016, 09:28 AM
  #209
oo7spy's Avatar
Did you do the reset?
Old 07-06-2016, 08:18 PM
  #210
wields's Avatar
reset? Holding down the unit in the rear for 5 sec for window to go down? Window does not roll down or up. Is there another way to reset
Old 07-06-2016, 09:39 PM
  #211
oo7spy's Avatar
The reset described in this thread over and over again. Turn the car on. Go to the door with the window in question. Hold the button down until the window goes down and keep holding for 5 seconds. Pull the button up until the window goes up and keep holding for 5 seconds.
If your window does not respond, the button may be broken.
If the reset does not fix the issue, you may have pushed and pulled too hard. There are two thresholds for the window button. The first stops when you release. The second goes into auto mode. You want "stop on release" pressure.
If that doesn't work, go for "auto mode" pressure because I got it backwards.
Old 07-23-2016, 11:54 AM
  #212
cib16waker's Avatar
automatic window opening not working
For some reason my automatic window feature is not working. When you push unlock once and push it again and hold it all for Windows unlock and the sunroof opens. It was working up until a few days ago and now when I push it nothing happens. Also on the inside, my back right driver window switch is not working. It works from the passenger rear right side but it doesn't work from the driver side window panel. Any ideas?
Old 07-23-2016, 11:56 AM
  #213
Received 8,584 Likes on 6,630 Posts
They go hand in hand. You have to replace he rear driver side window actuator if it's not going down. Then your auto down will work again
Old 07-23-2016, 11:58 AM
  #214
cib16waker's Avatar
Damn, okay....how hard is the install to do?
Old 07-23-2016, 01:36 PM
  #215
cib16waker's Avatar
Now it's working perfectly fine. It stopped working for 2 days and now it works I just tried it. I'm going to get a new one anyways cuz it's got to be going bad
Old 07-23-2016, 02:04 PM
  #216
Not hard at all, there should be DIY's on here to remove the door panel and it should just be a bolt or two
Old 07-23-2016, 02:05 PM
  #217
cib16waker's Avatar
Well it decided to work now lol
Old 07-23-2016, 02:41 PM
  #218
oo7spy's Avatar
Please, please, please, do a search. The complete thread about this is on page one. I'm merging your thread into it.
Old 07-23-2016, 02:46 PM
  #219
cib16waker's Avatar
My bad. I am doing it while driving so I don't have much time to search around. I did a couple quick searches but I kept leading me to non related things
Old 07-23-2016, 03:46 PM
  #220
should probably stop doing that..
Old 07-23-2016, 04:59 PM
  #221
cib16waker's Avatar
...then it wouldn't be such an active forum...it would be like a library....quiet, used for research only. It's good people socialize even if it's a repetitive issue...no prob....I wanna hear about this dang supercharged acura RL
Old 07-23-2016, 11:15 PM
  #222
oo7spy's Avatar
I hope he meant posting and driving.
Old 07-24-2016, 07:24 AM
  #223
cib16waker's Avatar
LOL yeah
Old 08-01-2016, 10:28 PM
  #224
4th Gear
Efu2d's Avatar
Thank you,
I was able to preform this tonight and success,. I am off to find why my remote or key will not open all windows and doors with the all function. Thank you.
QUOTE=jfarabaugh;10303956]you can reset the windows yourself. press and hold the button to put the window the whole way down then hold for 5 seconds after the window is down. let go of the button. press and hold the button to put the window the whole way up then hold for 5 seconds after the window is up. your windows should now be reset and can be controled from the drivers window controls. I had to perform it just tonight to be able to control the passenger windows from my drivers door controls[/QUOTE]
Old 08-02-2016, 06:28 AM
  #225
cib16waker's Avatar
[/QUOTE]
My window all of the sudden started working. So weird
Old 09-19-2016, 05:37 PM
  #226
abercash's Avatar
I know this thread is 8+ years old but I have to say thanks to everyone that posted on the "reset" procedure. I was ready to rip the door panel off and start testing switches.
My exact issue was I couldn't control the two rear windows from the driver side master control but the rear windows would travel up and down by the switch in each door. Based on what was written here it worked and all is right in the world (at least my car windows world).
For those who may still be looking for exact instructions (This was on my 2008 RL)
1- started car
2- opened the drivers side rear door
3- using the drivers side rear door switch I held the window control button down until the window was completely lowered and while still holding it I counted out load 1..2..3..4..5..6..7...8
4- I took my finger off the drivers side rear door switch
5- Then I put my finger on the same button and pulled up to raise the window to the fully closed position and while still holding it up I counted out loud 1..2..3..4..5..6..7..8
6- I let go of the drivers side rear door switch
7- I shut the drivers side rear door
8- I opened the drivers door and on the drivers door master switch I press the switch for the rear drivers side window and it worked. I tried up and down.
I then repeated steps 2-8 for the passengers side rear door
I then turned the car off and went inside to write a big thank you to everyone post.
I hope this helps the next reader.
RL09 (09-19-2016)
Old 09-19-2016, 06:27 PM
  #227
oo7spy's Avatar
The thread isn't really 8 years old. I got tired of the same question coming up so I merged the ten or so threads on the same topic together. Thanks for searching.
Old 05-04-2017, 02:15 PM
  #228
Walfunk's Avatar
Made an appointment to take my car back to dealership because rear windows not going down from drivers seat. There was talk about replacing the switch, etc. Glad I came to Acurazine first. Reset fix worked flawlessly. Appointment cancelled.
Thanks once again Acurazine
projektvertx (05-04-2017)
Old 01-09-2018, 12:00 PM
  #229
Tayron Stepney's Avatar
One more thing...
Thanks to everyone on this site! I performed the window reset function, from each window, and everything is good to go...the only thing now is the driver window doesn't work...is there a special reset procedure for that? Sorry in advance if this has been answered already
Old 01-09-2018, 12:30 PM
  #230
If it doesn't work at all, it could just be the window regulator is bad.
Old 01-09-2018, 05:56 PM
  #231
projektvertx's Avatar
This, or a bad master switch/connection at that switch? If you have a multimeter, you could check that the input to the regulator is getting power. That would rule out a switch or wire issue and pin it to the regulator.
Old 01-12-2018, 10:10 AM
  #232
Maintenanceman's Avatar
Reset worked for me also yesterday, due the timing belt job battery was connected off and after that rear windows didnt work.
Old 11-28-2018, 03:25 PM
  #233
3rd Gear
Brandon McFeron's Avatar
my driver's side won't go down, and when i hold the button and it just double clicks. all the other windows work fine.
I have recently replaced the battery and everything else on the car seems to be ok.
Old 03-23-2019, 04:03 PM
  #234
D Lopez's Avatar
You are the best
This really works! And tou rocks! Tks
Old 03-30-2019, 12:39 PM
  #235
bwrsro's Avatar
I have the exact same problem. Did you have any success in solving it?
Old 05-15-2023, 02:06 PM
  #236
Michael.81's Avatar
I am confuses, hold down which window button?? The reear window on my ILX will not open from the back or master, so what do I do?
tommypenguin
3G MDX (2014-2020)
23
04-12-2023 05:27 PM
RL09
09-16-2018 10:53 AM
drakescherer
1G RDX DIY & FAQ
06-03-2017 01:21 PM
A4orce84
01-01-2017 08:06 AM
mellsonnj
3G MDX (2014-2020)
11-04-2016 07:35 AM
Quick Reply: K-002: Window control/window won't roll down/window reset procedure
