Need help with wheel hop problem
Hey guys, new to this foroum, just my little story i have an 03 cls 6 speed with intake, XS headers and comptech pipes, i have raced the car from a 40 roll and its always ran really hard, last week i took it to the track nearby for the 1st time and it was horrible. The car would hop all the way through 1st gear and i was only launching at 2k rpms, it ran a 10.00 in the 1/8 with like a 2.65 60ft. It shakes the tires rally bad where i just cant even step on it, what could this be ?
Motor mount problem, suspension, tie rods, axles ?
Im hoping to get some help before i spend a bunch of money thanks
justnspace (02-18-2015)
Motor mounts a big one, especially if old or broken which happens frequently. Suspension is another. After upgrading suspension (shocks/springs/sways) i have zero hop 98% of the time.
The following 2 users liked this post by fsttyms1:
03 tls nc (09-18-2015),
thanks for the response guys,
I have tokico shocks and eibach springs lowered 2" in the front, and 18 inch rim very lightweight with brand new 225/40/18 cooper tires, but its not spining the tires, i know the difference of the car just hooping and shaking the entire car, this is gettting frustrating lol
mike88se (08-23-2015)
teh CL (02-18-2015)
I had an 01 cls before and it spin the tires but wouldnt hop, i know the 6 speed hops a little more but this much cant be normal there has to be something that helps a whole lot more
Yes iam open to anything at this point
How do i know if the motor mounts are bad ? How do i know if its suspension ? How can i tell if the bushing are bad ? I just dont wanna buy things for no reason i dont have money like that lol
And how much you want me feather the throttle launching at 1500 rpms and going a quarter throttle all the way through 1st gear ????
3.5 psi
have someone rev the car while you look at the engine. A lot of movement is not good. How many miles on the car? You can see the bushings and they may look worn and cracked. Xlr8 has poly mounts.
Not sure if you mentioned, how wide are your rims?
cooper zeon 225s..
TacoBello (02-18-2015)
Obviously you don't just want to mash down the gas pedal in first, and need to feather it. This is an issue for most people, especially now since everything comes with launch control. You can install an aem stand alone that has launch and traction control.
Things to help with wheel hop include:
Motor Mounts
Stiffy Mount
Torque Dampers
Radius Rod Bushings
Shocks/Springs or Coilovers
Poly/Spherical Bushings
If that is not enough try traction bars and slicks.
The reason you get wheel hop is because the car is compromised for comfort, not because it is fwd. Rwd cars can also suffer wheel hop, but not as much of an issue as fwd in commuter vehicles.
3.5 psi
The ingalls stiffy mount helps. You can also search here for NRG dampers. The 6speeds have 2 dampers, front and rear. It's a pretty cheap upgrade. I can't remember off hand, but some civic model works. With poly mounts, dampers and a stiffy mount your engine shouldn't move much at all.
Also the 2 damper move a little can they be thigthend up a bit ?
I listed my response without wasting my time reading other responses I won't learn anything from.
Atleast I am not the one blaming tire size or whether summer tires or not for wheel hop.
My cousin had 235 and they would rub when he turned tight i guess it depends on the rims, but i dont think tire width has anything to do with the hop it will grip better but not make a difference weather it hops more or less
I would think the offset would have something to do with that as well.. my stock offset was 55+ and I moved to a rim with a 33+ offset and have 225's on them and there was no issue with rubbing until I lowered the car
There are ways around it. you can hook up good without wheel hop, or spin tires without wheel hop.
Motor Mounts
Stiffy Mount
Torque Dampers
Radius Rod Bushings
Motor Mounts
Stiffy Mount
Torque Dampers
Radius Rod Bushings
And YES, wheel width does have something to do with it. The narrower the tire the easier it is for the motor to keep them spinning without hop, problem is, is spinning tires doesnt make the car go fast. The wider tire will give you the traction and help keep the tire from spinning and allow it to hook up (also better tires that have better grip as well) but when they do break loose because of the higher grip level they can cause hop.
gnuts (02-19-2015)
brandnewcolony
09-12-2015 10:39 AM
